Divorced Doubler Transfer Case - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-01-2010, 08:01 PM   #1 (permalink)
Member # 175708
I have and 87 chevy long wheelbase with a mild 350, TH 400, dana 60, and a 14 bolt. I want to divorce a doubler transfer case. I was told that the transfer case should be mounted on rubber mounts. Is that true? If so what is the purpose? Any ideas on how to mount this thing?
NscrRdnck3 is offline   Reply With Quote Quick reply to this message
Old 12-01-2010, 08:02 PM   #2 (permalink)
Corey Young's Avatar
Member # 21622
What is your wheelbase measurement? Are you going to make the TH400 a fixed yoke and make a divorced 203/205? Or do a married and divorced case? If you do married and divorced the front driveline probably wont clear the married case.
Old 12-01-2010, 08:06 PM   #3 (permalink)
Member # 175708
Not sure about that one I would have to check that out.
Old 12-01-2010, 08:07 PM   #4 (permalink)
Member # 175708
it would be a fixed yoke with a divorced 203 205
Old 12-01-2010, 08:10 PM   #5 (permalink)
Member # 21622
That will be a long setup. What is you wheelbase?
Old 12-01-2010, 08:12 PM   #6 (permalink)
Member # 175708
im not sure i would have to measure it
Old 12-01-2010, 08:21 PM   #7 (permalink)
Member # 175708
I will measure the wheel base in the morning being the truck is at our shop and I will let you know.
Old 12-01-2010, 08:40 PM   #8 (permalink)
DWitcher's Avatar
Member # 40308
How about doing a married Trans/T-case to a divorced T-case? Poor boy doubler.
Liberty against government over man.
68 FJ55, 70 FJ44.75, 72 FJ55. 96 FJZ80.
DWitcher is offline   Reply With Quote Quick reply to this message
Old 12-01-2010, 08:48 PM   #9 (permalink)
'Merica. Fuck Yeah!
86k30's Avatar
Member # 25703
136" WB here. using the stock engine mount location with an SM465 and a married flipped 208 with fixed yoke output to a divorced 205. Pretty tight fit with this monster wheelbase even! course I run a 2 piece front shaft, but the rear is getting kinda short. I bet yours will turn out alot tighter than mine. I think the 400-203 combo is a bit longer than my 465-208. And I'm a bit stretched from stock
The facelift:
86k30 is offline   Reply With Quote Quick reply to this message
Old 12-02-2010, 06:27 AM   #10 (permalink)
Member # 175708
Well, I already got the 203/205 on order. Going to have to make it work now!
Old 12-02-2010, 04:30 PM   #11 (permalink)
Member # 175708
I have a 130" wheelbase on the truck.
Old 12-02-2010, 04:55 PM   #12 (permalink)
Member # 121293
It will depend on how tall it is/is going to be also, If the angle isn't to bad the driveshaft can be shorter.
My S10 has a 132" wheelbase and the Duramax/Allison combo that I'm running is Looong, then I've got a 241/241 doubler with the factory slip yoke on the rear one setup behind the Allison and my rear shaft is 50 some odd inches long.
I think if you keep the shaft from your 400 to the 203 as short as possible you will be able to pull it off.
'85 4wd S10, ECLB with an '05 LLY Duramax/Allison, Locked 1 ton's, air-ride, 38's, & twin 241'.s
DieselS10 is offline   Reply With Quote Quick reply to this message
Old 12-02-2010, 05:01 PM   #13 (permalink)
Member # 175708
Ok so now I know it is possible. Now how should it be mounted. I was told that it should be mounted on rubber mounts. Not on solid mounts. Is that true?
Old 12-02-2010, 06:40 PM   #14 (permalink)
Member # 118893
Do you already have a divorced 203??? They seem rare as shit and I couldnt dig up a pic. Guess I cant picture how you will make it work ussing a married 203.. Seems like will need a different input for the 203
chev85k10 is offline   Reply With Quote Quick reply to this message
Old 12-02-2010, 07:13 PM   #15 (permalink)
Member # 175708
It is a 203/205 doubler. Both transfercases are combined to make one. www.offroaddesign.com/catalog/doubler.htm
Old 12-02-2010, 07:17 PM   #16 (permalink)
Member # 121858
I got a divorced 203 if you need pics or need it
dedmetal is offline   Reply With Quote Quick reply to this message
Old 12-02-2010, 07:28 PM   #17 (permalink)
Member # 118893
Yea Im aware of that...What I was getting at is What 203 RANGE BOX will you be using? Or have you planed out how to turn a married 203 into a divorced unit.
Old 12-02-2010, 07:35 PM   #18 (permalink)
Member # 21622
Ford offered a divorced NP203 in the 1970s. I would mount the divorced 203/205 on 4 bushings.
Old 12-02-2010, 07:48 PM   #19 (permalink)
Member # 175708
Thanks Corey. This is my first build and Im just trying to feel my way through it.
Old 12-02-2010, 08:10 PM   #20 (permalink)
Member # 23452
Yes they did and I have the input gear for sale, check out the for sale section for details if your interested OP.
Jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money.
420willys is offline   Reply With Quote Quick reply to this message
Old 12-02-2010, 09:56 PM   #21 (permalink)
Member # 103278
Reference material.
FrostBite07 is offline   Reply With Quote Quick reply to this message
Old 12-03-2010, 01:23 AM   #22 (permalink)
Member # 22868
I realize the torque loads are greater on your setup. I solid mounted my sami transfer case some years back, it worked great, never had any problems with it.
I have also solid mounted a 205 behind a c-6 never had any problems with that one either.
I would do a solid mount
I got a truck with some stuff
blazinzuk is offline   Reply With Quote Quick reply to this message
Old 12-03-2010, 05:46 AM   #23 (permalink)
Member # 175708
Thats what I was thinking too, but the people we bought it from swear that you will break stuff with it solid mounted.
Old 12-03-2010, 08:44 PM   #24 (permalink)
Red Chevy's Avatar
Member # 64526
U can solid mount a divorced case no problem, it's the married case that seems to destroy everything in front of it when solid mounted. Unless u run a front/midplate with a married one. I have a divorced 203 also I've been considering using for thus also
'94 k1500, 18" kings, 54" boggers and 57" r2's, 468 bbc, sm465, scs 12", 2.5's with overson's (BGMT)
'97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool,
38.5/11/16 boggers, awaiting 5.3 swap.
Red Chevy is offline   Reply With Quote Quick reply to this message
Old 12-04-2010, 01:16 AM   #25 (permalink)
Member # 22868
Well I still know guys that think an old set of camel hump heads will out flow vortec heads and even most aluminum heads so take it for what you will.
I am only going on experience I have on something much less powerful, solid mounting my zuk case solved all the problems I was having with it.
