Member # 177207
Fuel Gauge problems 79 scottsdale
I have always had problems with the trucks fuel gauge, the needle is always sitting at about 3 o clock way past the full mark no matter how much fuel it has.
I am looking to find a wiring diagram to figure out if its bad wiring or in need of another gauge. If anyone has had problems with the duel fuel tanks and can help |
#5 (permalink) | |
fuck off
Member # 102123
The wire does go into the cluster andI believe it to be pink. I'd have to look again. Been a while since I looked at mine |
Member # 177207
ok ill check it out.
what else could be the problem here? could it be the solenoid switching the tanks over? I have had someone under there and you cant hear anything when you flip the switch for the other tank but im assuming it works because it runs on the tank i have it on |
#7 (permalink) | |
fuck off
Member # 102123
Member # 51243
I use to run out of gas all the time cause my fuel gauge was all over the place.
Now i run a fuel cell in the bed and I have yet to run out of gas. But of course, it helps actually being able to see the fuel level....
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
#10 (permalink) | |
fuck off
Member # 102123
#13 (permalink) |
Member # 65442
GM gas gauges all the way to the right is an open circuit (broken wire). All the way left means the sender wire is shorted to ground somewhere.
Alaska sucks. Don't move here. It snows in July. Marauding Polar bears ate my neighbor. |
#14 (permalink) | |
Member # 177207
The wiring is pretty bad on the truck, so I'm thinking it's between the switch and the wires to the gauge |
#15 (permalink) |
Member # 65442
Short the tan wire (the wire to the sender) to ground with power on to test the gauge itself. If the needle moves left, then the gauge and the tan wire up to where you grounded it is OK.
I have seen two kinds of dual tank systems in your generation of truck. The older kind has a single-wire/3-port solenoid and the tank sender is selected at the dash switch. The newer kind has a (5?)-wire/6-port electric motor-activated solenoid and the sender is selected at the solenoid. The difference happened when return lines were needed back to the fueltanks.
Alaska sucks. Don't move here. It snows in July. Marauding Polar bears ate my neighbor. Last edited by Duallie; 12-17-2010 at 11:25 AM. |
#16 (permalink) | |
Member # 177207
And mine is the switch in the cab with the single wire to the solenoid and it's a 3 port
1979 Chevy Scottsdale sb350 sm465 NP205 625cfm Carter aft comp. Electric choke Lincoln locked rear. |
#17 (permalink) | |
Member # 177207
I'm not sure what wire from where.or where it's at, that tan one
#18 (permalink) |
Member # 65442
Power comes from the fuseblock to the selector switch, then turns the fuel solenoid ON for one tank and OFF for the other tank. I don't remember the color of the wire going to the solenoid. I seem to recall that ON was for drivers side and OFF for passengers side, but I could be wrong on that. A separate circuit on the dash switch also swaps the tan sender wire to the appropriate tank.
Does your tan level sender wire also plug into the fuseblock? I have seen that, but don't remember if its on GM cars or trucks.
#19 (permalink) | |
Member # 177207
The solenoid underneath is working I know for sure. But after that I'm lost on the wiring. From there after idk where they really go
#20 (permalink) | |
Member # 177207
The solenoid underneath is working I know for sure. But after that I'm lost on the wiring. From there after idk where they really go. I have a wire hanging with no idea where it goes. It has one of those 90 degree plug ins on it then it's bare. Wiring diagram would really help
#21 (permalink) |
Member # 65442
Where is it hanging? At the fuseblock, or under the cab? Is it a plastic-covered 1/4" spade?
#22 (permalink) |
Member # 177207
Yes, it was the sending wire. I did the ground and it went all the way down. It had also. Ripped apart by the starter in that wire loom. It works now. Thanks for the help everyOne
