241c 27spline to 32 spline - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-23-2010, 09:23 PM   #1 (permalink)
Member # 101130
Originally Posted by bggrnchvy View Post
Direct swap, just be careful about 88-91 p-drop cases to d-drop cases. I've heard the tooth pitch in the planetary set is different and as a result inputs from those two types are not swappable. Something I've heard but cannot confirm or deny immediately.
Does anyone know if this is true? I'm asking because I have a 1992 32 spline D drop 241c and a 1989 27 spline P drop 241c and I need the 32 input on the P drop. I didn't know that there was a difference between the years and the gear pitch.
turbosammy is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 03:59 AM   #2 (permalink)
Member # 46175
Those will interchange. Its not until 94-95 that you start to get the change in the cut of the gears.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 04:14 AM   #3 (permalink)
Member # 147891
from my under standing is that d and p drops have different gear pitch and 96 and newer d drops have a different pitch from all older d drops
may be wrong tho
mog-10 is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 06:24 AM   #4 (permalink)
pvkj454's Avatar
Member # 73302
I did this swap on my dually case. 87-94 has a BD50-8 wide input bearing and 94-on has a 6010N input bearing. The input gears are different between the two. Yours should work.
pvkj454 is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 10:29 AM   #5 (permalink)
Member # 43040
I did this swap also. I found during the swap, the 32 spline came from a full time 4wd vehicle which has a shoulder on the shaft that wont allow it to sit properly. 10 Minutes on the lathe, just like new.
95 S-10, one tons, 44's, 7lb pulley
Joshinator is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 01:43 PM   #6 (permalink)
oldrivers's Avatar
Member # 28570
its easy to identify the pitch change , the gear splines are either pointed on top or squared off ...
oldrivers is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 04:53 PM   #7 (permalink)
Member # 46175
Can you elaborate what the hell you are talking about.
Old 12-25-2010, 08:33 PM   #8 (permalink)
Member # 43040
There was a shoulder on the 32 spline AWD input at the base, right up next to where the gear splines are that wouldnt allow it to go in all the way. Once i cut it off, it went in completely. I'll see if i can find a picture.
Old 12-26-2010, 05:30 AM   #9 (permalink)
Member # 46175
The AWD input gear has me confused. Which AWD case are you referring to?
