Drunk Off Pancakes
Member # 159011
Gen IV 5.3l cams?
Just wondering if anyone is running an aftermarket cam on a gen 4 5.3l engine? Looking to do a swap for some more ponies, but haven't seen any for a gen 4...
Am I blind, stupid, or looking in all the wrong places? Anyone running one? Where did you get it? Worth the money/time? I understand that I'll have to get it tuned, which won't be a prob, I've got a good dyno guy. Just looking for some direction and input. The engine and comp are out of an 08 silverado 1500 With active fuel mgmt, if that helps. And I'm looking for something streetable, but barely ![]() Thanks in advance and flame away
almost know what im doing, I think... |
#2 (permalink) | |
Vortec Scout II
Just pick one of these. http://www.vincihiperformance.com/ca...s%20truck.html Just make sure to tell them your Gen IV. I would also remove the AFM if it was me. But that means pulling the heads to remove the AFM lifters. The good thing is you have good heads stock.
'73 Scout II Vortec 6.0L 4L65e np241 '73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's '01 VW Beetle TDI-50mpg or better! ![]() GM Gen III/IV V8 swap info TECH: Gen III/IV "LS motor" to Early GM Auto Trans |
Drunk Off Pancakes
Member # 159011
Right on. Thanks! Haven't torn a gen 4 down yet, didn't think it was too different. Just didn't want to order the wrong part.
#6 (permalink) | |
Vortec Scout II
There are 8 AFM lifters. I have heard of them failing. But I wouldn't worry since all your running is a cam. You should be OK.
Vortec Scout II
Also to use a Gen III (three bolt timing gear)cam in a Gen IV (single bolt) you need the LS2 three bolt 4x cam gear.
