Newbie
Member # 84483
5.3 aluminum ls motor
Just picked up an all aluminum 5.3 out of an 06 chevy. I am rebuilding the motor due to a loss of oil problem. What does anyone recommend for upgrades Its going in a wheeling rig and I am new to these motors. All recommendations will help I am looking to get about 400Hp to the ground.
CJ 7, one tons, and 44's |
Member # 163990
Not sure how accurate the calculators are but according to it, you will need about 519hp at the crank before drive train loss of a 4x4 to hit 400 at the wheels assuming an auto trans. 488 at the crank with a manual
67' Jeep Gladiator/84' K20 frame, 60/14, 383/465/205, 52/56 spring swap shackle flip, 37's Last edited by 383_Gladiator; 01-22-2011 at 09:44 PM. |
Member # 144396
its only an 8% loss due to parasitic loss.. so he would need about 450 hp to get 400 at the wheels.. its easy to do with the 5.3 with a slight cam, exhuast and a full tune.. your gonna have to get the ecu flashed anyway to get rid of the passlock system so you mine as well wait till you get it in the truck and ready to fire up. i can get 100hp out of a stock 5.3 with a few clicks on my laptop..
00 gmc jimmy, 4.3 dynoed at 350hp, 3 inch suspension lift, 31x50 dakota m/t, ion alloy beadlock rims |
#6 (permalink) | |
Vortec Scout II
I doubtyou will see 400hp at the wheels unless you run boost or nitrous. The good thig is you have good heads on it, 799/243. I would do a Cam, Fast intake a good tune. You will see 400-425 at the crank then. Any more and you really need to port the heads or have a power adder for any more HP gains.
'73 Scout II Vortec 6.0L 4L65e np241 '73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's '01 VW Beetle TDI-50mpg or better! ![]() GM Gen III/IV V8 swap info TECH: Gen III/IV "LS motor" to Early GM Auto Trans |
#7 (permalink) | |
Certified E-Thug
Member # 117771
You won't see more then maybe 30 to 45 hp with a HOT tune (93 oct, running maxed out tuned with a wideband). I picked up about ~20 hp on a 87 tune on my truck. |
Member # 88919
You're not going to see 400 rwhp out of 325 cubic inches in any usable form that a truck needs. These motors are absolutely great but the same rules apply to any engine for getting power: air in, exhaust out and give it enough fuel.
I'd lower your goals to something more reasonable for the 5.3L, such as 325rwhp (in a truck though you want low RPM torque and strong mid range). If you're looking for 400rwhp and you're stuck on that, increase the displacement. The L59 I built two years ago into a 382ci made 399.7rwhp and 413rwtq, all below 5500rpm's. That engine has 30k miles on it now and is getting 19-20mpg in a daily driven Yukon Denali. However, the biggest bore your L33 can go to is 0.005" over so a 4" crank would sit you at a 5.8-5.9L. That would make for a undersquare engine great for low end torque. Fast intakes are for cars, and you already have one of the very best truck intakes for low speed throttle response and max low end torque. These engines wake up with a tune. Removing all the torque management and tuning the VE tables alone will change the engine dramatically. I'd toss a very small, but intelligently ground, camshaft in there with LS6 valve springs and call the internal engine parts done (20x/21x, .55x/.56x on a 110-114lsa perhaps). After that, mid-length headers and a good 2.5" dual exhaust with free flowing mufflers. An L33 like that with a cam, tune and exhaust would easily see 300rwhp. If you want more than that, shave the heads into the 10.5:1 range and open up the ports a bit for 325rwhp. I wouldn't push the L33 any further than that.
[COLOR="Lime"][I]At 1300rpm's would you rather have 10 extra hp or 10 extra lb-ft of torque?[/I][/COLOR] |
#10 (permalink) | |
Member # 167042
#11 (permalink) | |
Member # 88919
I hope those drugs are worth it.
#12 (permalink) | |
Member # 177304
