Backfiring throughout the carb still - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-25-2011, 11:00 PM   #1 (permalink)
Member # 177207
So ever since I bought my truck if you punch the throttle right to the floor right away it would spit back out the carb and give me a good flame. To start with I...
Replaced spark plugs-- no difference.
Tuned air/fuel.. Which seemed to help to a point., also with the choke on over 3/4 of the time I Punch it to the floor it will take it with no backfire.
Then I did a compression check (all very close to 135 psi). If they are all Steady that should mean no burnt valve? Or am I wrong?
Next was intake gaskets just recently, and I just got it running again, what do ya know its still doing it. I just ran some seafoam ( intake/injector cleaner) through the intake to help clean up the valves also.
My next thinking is it HAS to be a warped intake.
If anyone can help that would be great. Thanks
1979 Chevy Scottsdale sb350 sm465 NP205 625cfm Carter aft comp. Electric choke Lincoln locked rear.
Dillon79scotts is offline   Reply With Quote
Old 01-25-2011, 11:14 PM   #2 (permalink)
Member # 87610
I'd check the timing first
heapxj is offline   Reply With Quote
Old 01-25-2011, 11:19 PM   #3 (permalink)
Member # 177207
Forgot to include that, but I did. I beleive it's at 8 or 9.
Old 01-26-2011, 05:26 AM   #4 (permalink)
muddindog's Avatar
Member # 150680
take some carb cleaner or either and spray around the intake and carb base when it is running and see if it makes any difference while it is running and if it does it has a leak somewhere.
75 k20 350/350/203, 14bff, dana 44, 63"/52" 39.5 tsl
My Build
Chevy Build Thread List
muddindog is offline   Reply With Quote
Old 01-26-2011, 06:04 AM   #5 (permalink)
Who?????
Gutter Runner's Avatar
Member # 64846
Possibly a worn lobe on the cam.
My Chevy Build......Going Commando
Try my soup!
Originally Posted by caffiend View Post
"Damn you Gutter Runner and your meddling tasty potato soup."
Gutter Runner is offline   Reply With Quote
Old 01-26-2011, 06:11 AM   #6 (permalink)
Member # 181023
Valve lash on the intake sides may be a tad too tight.
TnFocus is offline   Reply With Quote
Old 01-26-2011, 07:16 AM   #7 (permalink)
Member # 122868
Good on you for checking the basics first.
I would check the throttle shaft bushings before going too much further. A badly worn bushing or two will cause a decent leak. You can try blowing smoke around the carb to find the leak easily.
JOKER
I left the 4x4 world a while ago...
Thinking of going back.
JOKER4X4 is offline   Reply With Quote
Old 01-26-2011, 08:20 AM   #8 (permalink)
Member # 96496
Location: Flowery Branch, GA (yes.. like a branch with f**kin pretty pink flowers on it...)
What kind of carb? Sound to me like you're too lean off the bottom end and the motor is starving for fuel. Thats why it runs better with the choke on.
The 670 truck avenger I had ran like that out of the box on a very mild 350. Too lean off the bottom. Needed to add more "pump shot" with the optional accelerator cams
http://www.summitracing.com/parts/HLY-20-12/
My Cummins makes enough power to break a NV271...
mrdrinksalil is offline   Reply With Quote
Old 01-26-2011, 10:56 AM   #9 (permalink)
Member # 177207
Yeah, havent sprayed around the intake yet. But I believe I have changed th position and settin on the accelerator pump, bigger shot and smaller shot and I actually can't remember what happened but both ways it still wouldn't take it. I have adjusted valves with engine off, and tapped every nut so they shouldn't have moved.
I still think it's intKe, I'll try it later and give a update
Old 01-26-2011, 10:59 AM   #10 (permalink)
Member # 177207
It's a Carter 625
Old 01-26-2011, 12:03 PM   #11 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
its timing and only timing.
you may have a balencer that slipped, making you think that your setting the timing correctly.
you may have to put something in either #1 or #6 hole and crank it over by hand to find TDC and verify the timing mark is correct. this is a very common problem.
after you verify that the '0' mark is good then check to see that the timing advances with rpm.
you should have a total timing (with vacuume unhooked) of 32* @ 3000 rpm
i'm assuming its a large cap hei if you have a 79 scottsdale- these are really good at seizing the mechanical advance in the distributor. be sure to pull the dist cap and remove the rotor, move the advance plate under the rotor by hand and see if it springs back easily, if not you can rebuild it easily and inexpensively.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is offline   Reply With Quote
Old 01-26-2011, 12:40 PM   #12 (permalink)
Member # 177207
Angry
I have checked timing. But never did check to see if was at "0". I did get total advance at about 32 if I remember right tho. And see once the motor is over a certain rpm then it takes it just fine. And sometimes when choke is on.
It's irritating haha
Old 01-26-2011, 12:42 PM   #13 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
try advancing it about 3-4 degrees and see if that helps. then you'll know your on the right track. also, was that 32* with or without vacuume advance?
http://www.pirate4x4.com/forum/showthread.php?t=933618
Old 01-26-2011, 01:15 PM   #14 (permalink)
Member # 177207
I'm not sure actually
It was a while ago when I did it.
Old 01-26-2011, 01:27 PM   #15 (permalink)
Member # 177207
So I sprayed around the intake and no difference in idle.
Old 01-26-2011, 01:47 PM   #16 (permalink)
Member # 181394
I would say its your timing also. You should check everything like these guys said about the distributor advance, etc.
also if your carb needs set, the timing would have to be set correctly, to get everything just right.
cobra333 is offline   Reply With Quote
Old 01-26-2011, 01:53 PM   #17 (permalink)
TOGTFO
ChevyBoy2010's Avatar
Member # 174351
Sure your wires are on the right plug? Crossing your wires will cause this problem. Sounds stupid, but yooud be surprised how many times Ive seen this happen. Make sure its firing in the right order.
1977 Chevy K10... Soon- np205, 14 bolt, 4.56s, Detroit rear, crossover, 37 MTRs, Diet
http://www.pirate4x4.com/forum/showt...802&highlight=
1985 Chevy Suburban- 6 inch lift, 37's, 14 bolt/dana 44, 4.10s, hydroboost, 6.2 swap. Soon- bumpers, locker, rear disks, crossover steering
ChevyBoy2010 is offline   Reply With Quote
Old 01-26-2011, 03:14 PM   #18 (permalink)
Member # 138801
I'm saying its timing too .... set your base timing to 8 btdc with the vacuum advance removed from carbuerator and plugged then rev motor to 3500 rpm and set timing to 35-38 degrees
geo in a K5 is offline   Reply With Quote
Old 01-26-2011, 04:34 PM   #19 (permalink)
Member # 177207
Okay, when I put the intake back together I did get cylinder 1 top dead. But I didint check if the mark was lined up. Then " according " to my timing tab and balancer mark it's at 9 I believe.
Old 01-26-2011, 04:35 PM   #20 (permalink)
Member # 177207
So you think timing off like that will make it so with choke on it's fine, and after certain rPms it's fine also? Like a bottom end lean. Even just at idle not moving, a quick blip of the throttle it will pop out the carb also
Old 01-26-2011, 04:40 PM   #21 (permalink)
Member # 177207
The advance worked when I last checked total. But it won't hurt to try it and check it
Old 01-26-2011, 04:45 PM   #22 (permalink)
Member # 181394
that could be your motor is cold and runs good with a choke, but when its warm the timing is off enough to cause it to backfire. I have adjusted my timing by ear in my 305 atm, Before i replaced the timing chain it would backfire, and i was always adjusting the timing to get it to run good enough to get me down the road. I knew the timing was bad, and got it down the road for awhile, but towards the end it got so bad it backfired trough the carb and caught fire. after i adjusted the timing once more, it quit backfiring after that but i knew the chain was getting worse.
85 Chevy Scottsdale - 1ton.
Old 01-26-2011, 04:49 PM   #23 (permalink)
Member # 177207
So you replaced chain?
Old 01-26-2011, 04:52 PM   #24 (permalink)
Newbie
RebelK25's Avatar
Member # 90170
I've seen situations where on older motors, you can have a good reading off your timing mark, but your timing is still off for various reasons, whether your timing tab is jacked up or the harmonic balancer has issues.
At any rate, on older motors, I always time by:
A) vacuum gauge first if available
B) if no vacuum gauge available, ear
I have had this very problem you're describing on my '81 chevy with 350 crate motor and 600cfm edelbrock carb. Timed it with vacuum gauge and problem fixed. Not saying this is for sure your problem, but worth a try before you go digging into deeper possibilities...
1981 GMC K25 Tow/Plow Rig
1978 Chevy K20 Truggy "Camper Special" Trail Rig
2003 Ford F350 7.3
My Build Thread
RebelK25 is offline   Reply With Quote
Old 01-26-2011, 05:07 PM   #25 (permalink)
Member # 181394
yea i replaced the chain and i have not had that issue since. If you have over 100,000 its prolly time to get it done :P
