Member # 147000
Triple X'n the D-max
So I figured I would also post up my build using Toby's SAS kit from triple X Traction. I will be using a 78 Ford Dana 60 axle for my build instead of the 05 and newer Superduty axle. I am also planning on 4 Linking the back instead of leaf springs so hopefully I can shed some light on things tried that dont work by the end of this project and help save some people some money and time! LoL!
Here are some pics of the truck. Unfortunately I started off with a 8" Fabtech thinking that was a cool thing to do back in 05 when I bought my truck brand new. I am now doing like so many others and fixing the weak link in GM's grand idea of a "HD" truck.
It aint broke if its rollin black smoke |
Member # 147000
The clocking ring that came with the 273 transfercase leaves a little to be desired. I pulled my studs from my 263 thinking I would reuse those but they are metric and the adapter ring came with standard 3/8" 16 threads so I got some automotive studs from Ace Hardware. You also have to oblong a whole on the allison trans for the 6th stud to be used. I have the clocking ring pictured with the studs in the location used to run Toby's skid plate it allows for more adjustment if you were to use some other type of link bracket setup.
Member # 147000
Hmm... buttsex wheels... Lmao I take it you don't like the "ROCKSTARS". To each there own I guess. You are the first person to complain about those wheels. Thanks for your input. Maybe you will like the wheels on my buddies Avalanche. I see you have a "Megacab" the Avi has a Cummins and a 60.
Member # 142211
First person to complain? Must be new here...
Why is your Sig bass ackwards? Black smoke means you are over fueling, and that could be considered broken...
POLY PERFORMANCE - RUFF STUFF SPECIALTIES |
#8 (permalink) | |
Member # 142394
![]() Do yourself a favor find a guy in da hood to buy your wheels.Even by ghetto standards your rockstars are so 8 years ago.. .That avacramp is classic..Ghetto wheels and bolt on crap with a huge by wide stack..Hardcore puller is he..I guess it doubles to pull the trailers in the trailer park in the back ground..
Unfortunately there is no end to human stupidity -- making things foolproof only creates more ingenious fools |
Member # 147000
Thanks for the info. I had found choppermans thread on here thats what finally got me to spend the money to straight axle the front and thought I might have some good info when I build the back 4 link setup since most guys keep the leaf springs. I suppose if nothing else it will give people something to laugh at
![]() You are right I don't plan to rock crawl or extreme offroad it. I do plan to go to Silver Lake sand dunes up on Lake Michigan I enjoy that type of offroading because I don't like to clean off mud or get dents in my truck. LoL! Sand is fun in the Dmax and on the dirtbike.
#13 (permalink) |
Member # 83920
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. |
#14 (permalink) |
Member # 150291
I got all excited when i saw a thread involving a dmax, then i got all bummed when i realized it was just an abortion gone wrong, maybe soon this place will have you straightened out buddy, i really hope that avalanche is a joke.. you dont really know that guy do you?
Vehicles in sig change too often to keep updated, usually something fast and something slow. |
#16 (permalink) |
Member # 147000
Hey I posted up my build to try and help others and gain helpful insight on things that I need to change to do the build correctly. SInce it is an abortion gone wrong then fill me in on what you think is wrong with the build I propose to do? Thanks for the info.
The 273 Tcase was recommended to me by Toby at Triple X. He has a builder that supplys the Tcase to him built and ready to go to mate up to the allison. I was told the input shaft is changed to except the allison output shaft. They put in the VSS so it is plug and play with my facory harness. The 4wd shift motor also bolts onto it as well so I can still use my push button 4wd. The adapter/clocking ring allows you to be able to clock the T-case down and bolt it up to the transmission. The 273 to me seemed like a great choice. Larger case, more less bolts up, and its plug and play with my wiring. The other nice thing is it clocks down for front driveshaft angle and it eliminates both of my slip yokes so I can have the slip in the drive shaft where it needs to be.
#17 (permalink) |
Member # 113084
Chrome rockstars are ugly as fuck.
Chevy Truggy...5.3/350/203/205/d60/14b |
#18 (permalink) |
Drunk Off Pancakes
Member # 159011
One of the few I've heard of using a clocking ring to create MORE clearance issues... Specially in sand, or you like gittin' stuck? Cuz me an shovels ain't pals...
almost know what im doing, I think... |
#19 (permalink) |
Member # 138801
Jeez enough with the Flaming of the rims and stacks and shit ... sure they aren't my choice but fk this guy is actually going to build up his dmax not just put on some new shock boots lol... I want to see this sas build so carry on
#20 (permalink) | |
Banned
Member # 29016
this is where youve got me interested. fuck the gm cases, i repair them at least once a week. depending on what case the truck scomes with they can have 1-3 vss's so is it setup for all three or just one and spit wired to feed the additional needed inputs? they have to add a tone ring internaly and pick up boss so i would love to see how they did that. |
#21 (permalink) |
Member # 42023
the 271/273 is a beast and you should be fine, I say SHOULD...i did the same thing in my truck except i have a 6.0 gasser and a 6l90e, the case is big as hell and heavy to boot, i redid all my drivelines to fit and once it was all said and done, i fried two in a matter of months. soemthing wasnt right, not sure if i got a bad case or what. but i was getting my cases from the guy that toby and trevor were both getting theres from.....he was very helpful but in the end for my application...i bastardized a 241 with a dodge input and its been fine ever since.
maybe mine was a one off deal, but jsut because it has a 17,000 gvw, doesnt make it indestructible...also...its still a cast housing. (aluminum/mag...whatever it is) either way, should be solid when done
2007.5 2500HD 6.0/6l90e/241/d60/gm14 1988 V30 Crew Dually 454/400/205/D60/D70hd |
#22 (permalink) |
Member # 168414
X2 on this.. atleast he sounds like he knows what he's doin very interested in it keep it comin
84 K20 on tons & 01 Dodge w/ some go fast goodies "Beer in one hand, welder in the other" |
#23 (permalink) | |
Member # 135902
#24 (permalink) |
Member # 127442
X3 id like to see this thing built...whats dont to the truck performance wise?
[CENTER]95 Ranger 5.0L Built 4R70W 203-205 D-60 14B 3 link front 14'' kings 250lb-400lb 63"chevys detroit rear powertrac front 37' creepy crawlers. Build thread here[URL="http://pirate4x4.com/forum/showthread.php?t=878737"]http://pirate4x4.com/forum/showthread.php?t=878737[/URL] [B]Support the BRC![/B][/CENTER] |
#25 (permalink) |
Member # 12370
For all you that just wanna talk shit... Cory is a smart dood, and knows what he's talking about. He's looking for input about the build, not his choice of wheels or other stupid shit like that, and also wanting to share his experiences to possibly help other people in the future... so chill the fuck out!
Preview of things to come.... He's using a different axle, but you'll get the idea. Last edited by mrtwstr; 01-31-2011 at 04:48 PM. |
