Family crew cab crawler - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-10-2011, 08:27 AM   #1 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
Send a message via Yahoo to mitchm
IT started life as a 1973 reg cab 1/2 ton 4x4 short bed gmc. I installed Dana 60 with wfo springless high steer arms with crossover steering the tie rod is behind the axle installed 56' s in front with shackle hangers under frame and 6 inch shackles the front axle is moved forward like 3 inches and for the rear got a 14 bolt installed 63's moved rear axle back and inborded them under frame and 5 inch shackles.then installed cab got lucky my dad's friend gave me the cab had to notch the frame so the cab could sit lower only a little body lift It's a 76 but the chp gave it the same vin as the 73 so no SMOG. The truck weighs 5470 and center to center axle is 131 inches
[IMG][/IMG][IMG][/IMG][/IMG]
mitchm is offline   Reply With Quote
Old 02-10-2011, 08:34 AM   #2 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
IT'S A 4 FOOT BED
[IMG][IMG][/IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old 02-10-2011, 08:38 AM   #3 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
Old 02-10-2011, 12:54 PM   #4 (permalink)
Member # 175121
Out of all the builds I have looked at thus far (which isn't that many really) your truck is the first I have seen with inboard springs. I searched some other threads about inboarding and it mainly helps with articulation I take it.
My question is, why don't more of the full size truck builds inboard? what are the pros AND cons of inboarding?
Love the snow wheeling pic btw.
My junk:
[URL="http://pirate4x4.com/forum/showthread.php?t=935013"]http://pirate4x4.com/forum/showthread.php?t=935013[/URL]
Build is on the back burner until summer, turning my DD into a rig welder.
wingnuts514 is offline   Reply With Quote
Old 02-10-2011, 02:10 PM   #5 (permalink)
Bad Doctor
Odin K30's Avatar
Member # 86878
Did ya put the apron back on the bed?
Or is the front open?
-Vinny
-from Elizabeth
Nobody cares about your rigs specs...
"Me too" short Crew build
/forum/chevy/994394-odins-me-too-short-crew-build.html
Odin K30 is offline   Reply With Quote
Old 02-10-2011, 03:34 PM   #6 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
The only thing that I found with inborded rear springs is in reverse going 10-15 mph or so it gets scary.but my rear shocks r junk. I need to relocate the shocks to. Weld apron back in. I should of left in the front pockets but live and learn. headache rack rock sliders hydro assist and locker in front some year. It will be white soon my old man is a painter.
[IMG][/IMG]
Old 02-10-2011, 04:20 PM   #7 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
^^ Nice weiner. Truck looks ok too.
76 CJ-7... mostly chevy parts
www.centexoffroad.com
mudskipper4x4 is offline   Reply With Quote
Old 02-10-2011, 04:39 PM   #8 (permalink)
AllGoNoShow's Avatar
Member # 46318
Cool truck.
Project Ol' Skool '37 Chevy: /forum/ford/1049898-project-old-skool.html
1979 F-350 build: /forum/ford/855113-79-f-150-build.html
AllGoNoShow is offline   Reply With Quote
Old 02-15-2011, 07:06 AM   #9 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
That is spark plug.
Rock slider hydro assiest locker in front some year. need to re locate rear shocks not sure if I should go straight up and down or heading forward or back or like stock 1 forward 1back. I was trying not put the shock up threw the bed need to haul dirt bikes there is not much room with just stock 63's springs and no blocks 5 inch shackles and inboard springs with 14 inch shocks.
[IMG][/IMG]
Old 02-15-2011, 07:28 AM   #10 (permalink)
Member # 80727
I really like the inboarded springs idea. Id do it if I wasnt set on doing a 4link rear now lol.
Truck is cool. Any good action shots?
1994 Isuzu Trooper: OM617/W56/toybox
4.56 Dana 44 w/ lockright/6 lug Ford 8.8 4.56 Ox locker
r0nin89 is offline   Reply With Quote
Old 02-15-2011, 08:56 AM   #11 (permalink)
Member # 72752
great looking truck!
I've wanted to build soemthing similar for quite a wile (ever sense I had to sell my '82 about 10 years ago).
I think if I ever get the chance to build one though, I'll probably shorten the cab/rear doors enough to take out that little fixed piece of glass. Doing that, although it would mean more body work, would move the cab corners a little farther away from the rear tires, and add just a bit more bed space.
93YJ, mostly stock,4.0, AX15, 231, D30 &35, 3" lift, TJ flairs, and 33's.
muddyj is offline   Reply With Quote
Old 03-03-2011, 08:40 PM   #12 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
Will get some action shot this weekend hopefully
[IMG][/IMG]
Old 03-04-2011, 01:39 AM   #13 (permalink)
Member # 170304
I like those snow pictures haha looks like fun man! This thing makes me want to turn my limo crew cab into a trail rig like yours, the only problem is bikes dont hardly fit in a 4 foot bed haha
StoutSam is offline   Reply With Quote
Old 03-04-2011, 07:46 AM   #14 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
My xr 400 fits just fine with the tale gate down
Old 03-04-2011, 09:07 AM   #15 (permalink)
Member # 46318
What did the wheelbase end up being?
Old 03-04-2011, 10:15 AM   #16 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
It's 131 inches center axle to center axle and it weights 5470
Old 03-04-2011, 06:18 PM   #17 (permalink)
91extsas's Avatar
Member # 184697
truck looks good did a similar swap to my 91 and inboarding the springs doesn't help as much as you think i moved mine in 3.5" either side and it didn't seem to make that much difference than just a shackle flip
whats ur spring width?
91extsas is offline   Reply With Quote
Old 03-04-2011, 07:05 PM   #18 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
Center spring to center spring is 33 1/2 what is yours
73 gmc crew cab on 41 inch iroks 56's in front with d 60 with wfo hd springless arms x-over hydro assist high steer with tie rod behind axle 14 bolt with disk brakes inborded 63's in rear 4 foot bed
Old 04-21-2011, 09:43 PM   #19 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
Have not had time to do any crawling but I got 2nd in a mud bog out of 25 trucks I Will see how it will do in oroville next weekend.[IMG][/IMG]
Old 04-22-2011, 05:08 PM   #20 (permalink)
91extsas's Avatar
Member # 184697
mine is stock for yours 40 from 47. thinkin bout inbording them even more and running a missing link shackle just gotta get my syi first
91 chevy extcab short shortbed, d60welded, 14ffwelded, 350, nv3500, np208, 37 boggers for now
Old 11-20-2011, 11:39 AM   #21 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
The familycrawler turn into the family snow rig there in not much rock crawling out here in dutch harbor. Look to get hydraulic assist going with psc. Any one know a good place to get the kit ?
Old 01-12-2012, 05:01 PM   #22 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
The hydro assist kit is on order thanks to Bo at wfo concepts great scrvice.
Old 01-12-2012, 05:48 PM   #23 (permalink)
Banned
Member # 208508
that's nice great service.
benchgave is offline   Reply With Quote
Old 01-12-2012, 11:55 PM   #24 (permalink)
Member # 162491
are all those pics from dutch?
I thought it was cool to see you're from dutch, I live in Kodiak stationed on H-60's in the coast guard, I have stopped through there for food and fuel in a 60.
The_Punisher is offline   Reply With Quote
Old 01-13-2012, 06:23 PM   #25 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
The pic are from cali just moved out here in july.
