Member # 95938
for some reason, the IAC on it keeps going in and out. sometimes it'll work, sometimes it won't. tried a new IAC, another computer, and the wiring checks out good. even with the new IAC and computer it does the same thing. works for a while, stops working, then it starts working again. anyone have any ideas why?
Member # 139990
possible vacuum leak or fuel pressure issue if your wiring checks out and you put on a new IAC valve and computer
trucks are built, maintained, repaired by humans, you are a human you can do anything |
Member # 95938
smoke tested the motor for vac leaks, none found. fuel pressure is consistant at 15 psi.
i have a feeling it may be something loose in the connector, in the wiring harness. it's a new harness though, from howell, so it "should" be good. but that's really the only thing that makes any sense since it does it with a new iac and new ecm. i'm thinking it's some type of intermittent connection maybe? |
Member # 9991
Grounds, or lack there of, can cause gremlins. Is there a complete ground path between the body, frame, and engine?
[url]www.scotthansen.net[/url] Last edited by MrWillys; 02-21-2011 at 07:57 AM. |
Member # 37184
Engine grounds to ECM? There are a couple of common ground points at front of the engine that have 2-3 ground wires each, that go back to the ECM. Also, just because the wires "look" good, doesn't mean they are electrically good. If I were chasing the problem you describe, I'd remove each ground, and properly clean and reinstall it. Your problem sounds like wiring.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's. |
#12 (permalink) |
needs a sponsor
Member # 156242
Although there are ground straps as mentioned, you should check your grounds at the t stat housing. Mine were corroded underneath but seemed to be fine visually and cost me a lot of time doing pin outs, and trying known good parts.
