Member # 146710
IFS to SFA
I have a 96 Z71 that has a IFS lift from fabtech 6" suspension and im thinking about taking that out and doing a SFA converstion using the ORD bolt in kit. If i do end up doing this i am using D44 hp driverside drop and a D60 rear. My question is what would be the best spring to use in the front to give me my 6" back? Im having trouble finding lower control arms, torsion bars, and torsion xmember hints the reason why I am thinking of doing the SFA converstion. Any advice [or if you have those parts drop me a pm] would be very helpful..
**1 Goal 1 Vision** |
Juice
Member # 130270
I have everything you need. For 10k
You know just as well as I do, that it may be money, and it may even be your money.... but there are certain people in our lives that will chop your balls off in your sleep, and drug you and tie you to a bumper of your favorite truck and drag you if you bring home another project
Member # 20053
I have everything you need for 9K, with 90 day warranty
98 K2500 SAS dynatrac pro rock 60, ORD high steer, RCV CV's, arb's front and rear, 4.56 gears 06 D Max Express |
Member # 88919
The apple must not fall far from the tree...
So is your mom.
[COLOR="Lime"][I]At 1300rpm's would you rather have 10 extra hp or 10 extra lb-ft of torque?[/I][/COLOR] Last edited by Rinkrat456; 03-07-2011 at 12:19 PM. |
Member # 39108
you chevy guys got it all wrong. He needs to swap in that fabtech suspension on the rear and have rear stear. Then throw the dana 44 & the dana 60 up front with a reverse mounted wench...
nullum magnum ingenium sine mixtura dementia fuit |
Member # 39108
where can I get that warranty? The dealership usually only gives warranties if you've used synthetic blinker fluid
#11 (permalink) | |
Member # 146710
#12 (permalink) |
mega hack!!
Member # 139150
good luck on that Hoss.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's! ![]() /forum/chevy/933618-new-old-black-getting-1-ton-makeover.html |
#13 (permalink) | |
Gettin there!
Member # 45202
#14 (permalink) |
Member # 146710
Im just dumb huh? And why would that be? I must be real dumb considering I replaced the torsion bar and lower control arm for the 1st time working on ifs and it works great... Thanks for all the help you guys have givin me... Much appreciated
#15 (permalink) |
look your not makein eny sence are you or are you not doing a solid axel swapp if so i would not have wasted my money on new torsion bars and eny way its only one bolt to pull one out and putt back in .as for your axels iwould no us a 44 and 60 rear if you do you might as well leve the ifs in if not do a hp dana 60 and 14 bolt out back . do research you just sound confused
fuck off .com |
#16 (permalink) | |
Bootyfab Technician
Member # 35163
1979 FJ40 |
#17 (permalink) |
Member # 146710
I was saying if i couldnt find the parts for the ifs i was goin to straight axle the truck but i found the parts that i was looking for so im not straight axling now... I have the axles under my blazer if I wanted a sfa under the Z71 they are D44 hp with 4.10s and the rear is a D60 welded with 4.10s out of a 78 F250... I kno what im doing I was just wanting suggestions on either sfa it or keep the ifs but no need for that now bc i have ifs put back together... Just have to do some adjusting here and there still on the truck since it was hit but nothing that should take me to long of a time to do... Now is everyone on the same track? I sure do hope so.
