16.5'' 6-lug wheel question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-10-2011, 09:56 PM   #1 (permalink)
Member # 87542
I want to put cheap military tires on my K5 and these: http://www.summitracing.com/parts/USW-706960/ are the only reasonable 16.5 6lug wheels I can find. The problem is that in the description it says not to go larger than a 33 inch tire. Is that just because of the safety bead on the 16.5 or is there another reason.
http://www.pirate4x4.com/forum/showthread.php?t=586729
http://www.cardomain.com/id/D44Runner
D44Runner is offline   Reply With Quote
Old 03-10-2011, 10:00 PM   #2 (permalink)
muddindog's Avatar
Member # 150680
They are pretty thin wheels. I have had a set of U.S. Wheels and I was less than happy with the quality of the wheels. They may be concerned that you may bust the centers out of the wheels, or maybe they know that your half ton axles wont be able to handle any tires bigger than a 33". You get what you pay for.
75 k20 350/350/203, 14bff, dana 44, 63"/52" 39.5 tsl
My Build
Chevy Build Thread List
muddindog is offline   Reply With Quote
Old 03-10-2011, 10:09 PM   #3 (permalink)
Lurkin' and learnin'
NJMetalhead's Avatar
Member # 150920
Get a set of H1 wheels and recenter them with a 6 lug center. There is a vender on here that you can get them from already recentered with the correct center.
'91 Chevy K5 Blazer: 350, 700R4, NP241, 14BFF, D60(almost), 35x12.5x15 BFG A/T(going bigger soon).
"Who's the more foolish? The fool, or the fool who follows him?"
NJMetalhead is offline   Reply With Quote
Old 03-10-2011, 10:14 PM   #4 (permalink)
Member # 87542
That's what I was afraid of, there isn't many options out there.
I'll have to look for that thanks.
Old 03-10-2011, 10:15 PM   #5 (permalink)
Banned
trkklr77's Avatar
Member # 29016
those wheels are fucking junk.
you will be FAR better off with the recenter.
pm 409yj
Old 03-10-2011, 10:59 PM   #6 (permalink)
Member # 87542
pm 409yj
That's what I'll do.
Old 03-11-2011, 12:08 AM   #7 (permalink)
Mr Mom
glenns89's Avatar
Member # 94897
406 YJ has a thread about the H1's /forum/axles-tires-wheels/746158-recentered-h1-special.html
89 jimmy D60/ff14bolt/400/203/205. Detroit rear, open front for now.
glenns89 is offline   Reply With Quote
Old 03-11-2011, 06:19 AM   #8 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
did you try the pro-comp rockcrawler wheels? i have a set, they are made of good thick steel, for a non-beadlock wheel i've been very happy with them. found two different ones on Summitracing here's the part #'s 52-65883 and 52-65983. both for less than $100 each.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is online now   Reply With Quote
Old 03-11-2011, 06:27 AM   #9 (permalink)
GM at TWF
Dookey's Avatar
Member # 23680
For another 75 bones why not upgrade to a true double bead lock?
ANDY<--- ME!
TrailWorthyFab.com<--- THE BEST DOUBLE BEAD LOCKS!
Project: Dookey's revenge<--- My Junk!
OFF ROAD GEAR<--COOL SWAG!
Old 03-11-2011, 07:46 AM   #10 (permalink)
Member # 185467
4wheelparts has the procomp wheels for $71 plus shipping also
tex_50613 is offline   Reply With Quote
Old 03-11-2011, 07:37 PM   #11 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
no offence, but for those of us on a budget that usually got to get it on the road $280 to $300 for four of them shipped to my door was a whole lot better than $600+. yes double bead locks are better if not the best, and when i can afford it then so be it. untill then.................
http://www.pirate4x4.com/forum/showthread.php?t=933618
Old 03-12-2011, 02:54 PM   #12 (permalink)
Member # 178825
he is putting these on 1/2 ton axles. Do you guys really think he is going to do anything to hurt the wheels or actually need a bead-lock his axle parts will break before he ever fucks up a wheel.
We have no words for speaking of wisdom to the stupid. He who understands the wise is wise already.
AngleIron is offline   Reply With Quote
Old 03-14-2011, 12:04 AM   #13 (permalink)
GM at TWF
Dookey's Avatar
Member # 23680
No offense taken. If I can help you with anything please just let me know. We will be around for a long time so if you ever need help on some bead locks I am here to help.
If you run 16.5s you NEED bead locks. The wheel size was designed specifically around an insert and running one without it causes you to pop a bead very easily. How many parts do you think you will break when you have a flat on the trail and roll your rig? Besides, there is nothing more expensive then spending money twice.
ANDY<--- ME!
Old 03-14-2011, 12:30 AM   #14 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
to bead lock a 16.5, you can always weld a .125 wire ring around the inside of the wheel where the bead rides for a safety ring. it makes the tires a bitch to get off the wheel, though.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 03-14-2011, 05:57 AM   #15 (permalink)
Member # 178825
How can a wheel size determine if you HAVE to use a beadlock? I'm not trying to be a smart ass i really want to know the reasoning behind that. and why didn't GM use one for all the years they sold trucks with a 16.5" wheel?
i was simply stating that if a guy runs 1/2 ton axles, chances are he is not going to put his truck in a situation where he is going to be off camber enough to pop a bead. save the money upgrade your axles then buy a set of bead lock wheels and go wheel the hell out it
Old 03-14-2011, 06:18 AM   #16 (permalink)
GM at TWF
Dookey's Avatar
Member # 23680
From the very inception of a 16.5" wheel it was designed around an insert. So there are no bead protectors built into the wheel. Thus, why Grumpy is suggesting to weld pieces into the wheel to help keep the bead seated. The majority of wheels out there in a 16.5" size don't have the required parts to handle the tire. They rely on air pressure to keep the bead seated. When you air down or get a leak in a tire.... bad things happen.
That is how a wheel size can determine whether you should run a bead lock. And not just any bead lock. You should run double bead locks because the problem can still happen running single bead lock wheels.
It is no secret that when people run the 16.5s other than the way they were designed there are problems. I met a guy at the Big Meats Run this past weekend and he stated he popped a bead 5 times in one day because he aired down. He bought PVC inserts off the trailer and now he won't have problems.
ANDY<--- ME!
Old 03-14-2011, 06:47 AM   #17 (permalink)
Member # 178825
thanks for the good information and for being polite about it
Old 03-14-2011, 08:00 AM   #18 (permalink)
GM at TWF
Dookey's Avatar
Member # 23680
That's what I'm here for. Please let me know if you have any other questions about 16.5s. Considering we have over 5000 of them in stock it is easy to get stuff figured out.
ANDY<--- ME!
Old 03-14-2011, 08:28 AM   #19 (permalink)
Member # 147891
not all 16.5 wheels were designed to work with an insert. their are lots of people that 16.5 wheels with out an insert or a bead lock just don't air down problem solved.
this thread was about 16.5 steel non bead lock wheels with a 6 lug on the cheap that this guy can run on his rig with some cheap 37in tires
not one time did he say that he planned on airing down and going crawling
mog-10 is offline   Reply With Quote
Old 03-14-2011, 08:33 AM   #20 (permalink)
GM at TWF
Dookey's Avatar
Member # 23680
You're absolutely correct. But it is better to have more information to make up an educated decision on which way you prefer to go. Nobody is forcing his hand to do anything. There is so much misinformation about 16.5" wheels that I try to help clear the air about it.
ANDY<--- ME!
Old 03-14-2011, 09:23 AM   #21 (permalink)
Gettin there!
rockbuggy84's Avatar
Member # 45202
Not sure on your location but all over craigslist here in Ca they are about giving 16.5"s away every day. All the street qweens have been told by the tire shops you can no longer get tires for them and need new wheels. I have bought 3 sets of welds in the past year and the most I have paid was $225 for full set of Weld Mountain Crushers. Also I think this is would be a question for newbie discussion, to help not clutter up certain sections.
rockbuggy84 is offline   Reply With Quote
Old 03-14-2011, 10:36 AM   #22 (permalink)
Member # 156216
no answer on pirate will ever involve anything less than the strongest, most expensive option, and you will be continually berated and told that you will kill a busload of nuns and that you are attempting a "band aid" fix or that you are "cheaping out" if you opt for anything other than the most involved, expensive, and unnecessary hardcore rockcrawling part. c'mon.
Poop.
hasteranger is offline   Reply With Quote
Old 03-14-2011, 10:56 AM   #23 (permalink)
Gettin there!
Member # 45202
Your a fucking idiot!
Old 03-14-2011, 11:30 AM   #24 (permalink)
Member # 28084
yup.
Orion
'72 K20 on 35s
K2Orion is offline   Reply With Quote
Old 03-14-2011, 01:14 PM   #25 (permalink)
Member # 156216
At least I know how to use "your" and "you're."
Poop.
