86 K10 700r4 to th400 swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-25-2011, 06:30 AM   #1 (permalink)
Member # 186703
I have a 86 chevy K10 shortbox,i only use it for muddin,i recently smoked my 700r4 and i am going to throw in a th400 that i have layin around. What all has to be done to make this happen? i.e. mounting, drive shaft length etc... Thanks in advance
86MudSlut is offline   Reply With Quote
Old 03-25-2011, 07:04 AM   #2 (permalink)
Member # 181629
i recently did the same thing, i believe it pretty much a bolt on, im running a 205 behind my 400, what you have to do is plumb in the vacume for the shift module in the intake or the port behind the carb, i had to mock up a shifter for my 205, but u should learn how to search, all this info is on google
chevy305dbt is offline   Reply With Quote
Old 03-25-2011, 07:18 AM   #3 (permalink)
Mr Clickerson's Avatar
Member # 141777
http://pirate4x4.com/forum/search.php
Mr Clickerson is offline   Reply With Quote
Old 03-25-2011, 07:27 AM   #4 (permalink)
Member # 138801
It bolts in very easily, delete this thread and post it in the newbie section if you really can't figure it out
geo in a K5 is offline   Reply With Quote
Old 03-25-2011, 09:45 AM   #5 (permalink)
Member # 186703
Alright Guys,thanks for the info,and the search link. I'll know next time,just needed some info so i can get parts before I get my junk up on the lift.
Old 03-25-2011, 11:37 AM   #6 (permalink)
Member # 138801
You will need driveshafts everything else is common sense and bolt on.
