#127 (permalink) |
Member # 164266
another saturday down the drain. we started cleaning up the gas tank and cutting out the passangers side for the boatsides. got quite a bit cut out and the 2x3 welded in place. started cutting out the rear floor, unbolted the body mounts tore all that junk out. cut out some rivets and about 5 inches off the back of the frame along with the factory crossmember, tacked in the new bumper when a storm started coming. had to clean it all up and put her up for the day
#129 (permalink) |
Member # 164266
i forgot to mention yesterday i picked up a dual electric fan set up out of a 98 ford windstar with wiring harness which hopefully gives me some room to move the radiator back a couple inches.
today i completely welded up the rear bumper then started cutting away at the rockers. i managed to get all 3 braces tacked into place ![]()
#133 (permalink) |
Member # 142394
This rig has come a long way. BTW your gonna love the windstar fans..I have always been addicted to 3rd gen f body fans but i cant get my truck to run past 190* even in heavy traffic with windstar fans
Unfortunately there is no end to human stupidity -- making things foolproof only creates more ingenious fools Last edited by angryblack; 10-01-2011 at 04:30 PM. |
#134 (permalink) |
Member # 164266
thank you, hopefully they work out good. its a little toasty in AZ
the day started out slow. couple buddies came over to start throwing together the cage. first thing we did is miscalculate a bend. there went 4 ft of DOM. after that we got one done and then the other. started tacking things together and it all started moving much faster. we ended up using all but 2ft of the DOM we effed up so that was good. i got some of the tubes welded all up but mostly just tacked in place. everything is looking really good. i only expected to get the main structure done today but we managed to get the rear "X" in place before we called it a night. one of the few times that i will say we got more done than i expected. sorry for the crappy pics. my phone is afraid of the dark ![]() ![]()
#136 (permalink) |
Member # 175121
Great looking build, if you get a chance could you post up some good pics of the engine crossmember you built?
My junk: [URL="http://pirate4x4.com/forum/showthread.php?t=935013"]http://pirate4x4.com/forum/showthread.php?t=935013[/URL] Build is on the back burner until summer, turning my DD into a rig welder. |
#138 (permalink) |
Member # 175121
Oops I didn't notice that was Maxpf, post 108 in your thread.
#140 (permalink) |
Member # 164266
here are some better pics of the cage. today i just welded everything up good then started cleaning off the rear of the frame in prep for my gas tank and made the mounts. once i get the gas tank in place i will start bending the rear portion of the cage
#142 (permalink) | |
Member # 84454
Oh well, you know what they say about hind-sight....
[QUOTE=-Dex-;13278433]You're the kind of guy who isn't happy with just sticking a finger up his ass while jacking off, you have to pull it out and smell it afterwards too don't you?[/QUOTE] |
#144 (permalink) |
Member # 164266
nothing too exciting today. more welding, cleaning and painting. right now everything is welded in place and everything is cleaned up. i got the gas tank in place so i can start surrounding it with tube. i was going to start bending tonight but decided to watch my packers play instead
#145 (permalink) |
Member # 164266
today i finished bending the 2 main supports for the roll cage. its just tacked together for now but that is the last of the bending on the main structure of the cage. the only bends i have left to make are going to be on the tube front and some dash parts.
sorry if the small bi-daily updates arent very interesting. I'm learning everything as i go, which takes me a while. making small updates regularly keeps me more motivated. ![]() ![]()
#146 (permalink) |
Member # 164266
Tonight i cut more useless sheetmetal off then added a couple more tubes, I called it an early night since ill easily have 20 hours into this thing this weekend
![]() ![]() ![]() ![]() ![]() I also received my pair of 5 points today
#147 (permalink) |
Member # 164266
alright, saturday was a great day to lay out some tube on my rig. got lots of braces and gussets in place and tacked together. i really like how its looking. i started running out of tube so i decided to start working on the front before i run completely out. then today i never got to touch my rig cause i was too busy trying to get a dead XJ to run
#148 (permalink) |
Member # 164266
i got a little more done tonight, a few more braces and quite a bit of welding. i should have all the cage braces done by tomorrow if i dont run out of tube then just more welding. i may have over done it on the triangulation but im liking it more and more
#149 (permalink) |
Member # 164266
so i finally have the entire cage tacked together. there is a chance that i may add a few more peices but i doubt it. tomorrow i will weld everything up and the cage will be done. next is going to be the tube nose
i also picked up some 14.5" travel pro comps from Fly-N-Hi and got my master instal kit for my 60 in the mail from Letzroll Offroad. that should be at my doorstep tomorrow ![]() ![]()
