Chevy leaf springs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-04-2011, 03:03 PM   #1 (permalink)
Member # 186622
Chevy leaf springs
How long is a front leaf spring (eye to eye) on a 73/87 chevy truck? And how wide at the eyes are they?
spot92chevt is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:12 PM   #2 (permalink)
Loftis61's Avatar
Member # 148442
Come back tomorrow.
47" at 2.5" wide I believe...
Semper Fidelis
Loftis61 is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:12 PM   #3 (permalink)
Member # 130928
47" eye to eye and 2 1/2" wide.
86 Silvy - 355/TH350/208/60F/14FF/4.56s/Detroit/38.5x15 Boggers
ryan_thompson87 is online now   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:31 PM   #4 (permalink)
Member # 186622
Thanks for the help.. im starting a sas on a 92 chevy. ive got another question does the eye to eye length change when you go to a 4 or 6 inch lift spring?
Old 04-04-2011, 03:31 PM   #5 (permalink)
Member # 174351
no....
1977 Chevy K10... Soon- np205, 14 bolt, 4.56s, Detroit rear, crossover, 37 MTRs, Diet
1985 Chevy Suburban- 6 inch lift, 37's, 14 bolt/dana 44, 4.10s, hydroboost, 6.2 swap. Soon- bumpers, locker, rear disks, crossover steering
ChevyBoy2010 is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:41 PM   #6 (permalink)
Member # 186622
I was goin to start building the brackets with stock springs and i didnt want to buy lift springs an they be different. thanks for the help. this is my frist sas.
Old 04-04-2011, 03:49 PM   #7 (permalink)
Member # 175879
You're using springs from the wrong end of that truck.
Uh Oh is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:56 PM   #8 (permalink)
Member # 186622
Are you saying use the 52" rear springs?
Old 04-04-2011, 03:58 PM   #9 (permalink)
91extsas's Avatar
Member # 184697
yea trust me did my sas with the 47s. 52s would have been way easier trust me use the 52s
91 chevy extcab short shortbed, d60welded, 14ffwelded, 350, sm465, np208, 37 boggers for now
91extsas is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:58 PM   #10 (permalink)
Loftis61's Avatar
Member # 148442
Yes. It will be easier to use 52" rear leafs in the front.
Dont forget to take into account for your bushings to stick out about 1/4" each side of the leaf spring eyes when you make your hangers...
Semper Fidelis
Old 04-04-2011, 04:08 PM   #11 (permalink)
Member # 186622
question? What makes the 52's eaiser than the 47's?
Old 04-04-2011, 04:13 PM   #12 (permalink)
Loftis61's Avatar
Member # 148442
Because the 47's are gonna be stiff as fawk, and its easier to make/order new mounts and use the 52's for about 4" of lift (pending how much weight you have in the front), and ALOT softer ride.
Now, take this to the newbie forum.
Semper Fidelis
Old 04-04-2011, 04:26 PM   #13 (permalink)
91extsas's Avatar
Member # 184697
the rear of the 47s end up right where the frame curves in its a bitch to make mounts to actually hold up.http://pirate4x4.com/forum/showthread.php?t=961402 check out my brackets
Old 04-04-2011, 04:41 PM   #14 (permalink)
Member # 186622
ok thank for the help. im not new to 4x4 im just new to the axle swaps an i told to move this to a newbie fourm. so here it is (1992 k1500 SAS) if you guys still want to help me.
Old 04-04-2011, 04:48 PM   #15 (permalink)
Member # 107830
Read and learn
http://pirate4x4.com/forum/showthread.php?t=820217
84 K5 / 06 LBZ Dmax / 2012 TFab 151 buggy
BigRed05 is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 04:56 PM   #16 (permalink)
Member # 186622
i ment to say is that im new to the whole fourm thing.
Old 04-04-2011, 05:24 PM   #17 (permalink)
Member # 107830
I think you need to search and learn some more.
Ill start you off so you dont get to butthurt
http://gmfullsize.com/forum/showthread.php?t=72622
http://gmfullsize.com/forum/showthread.php?t=193225
http://pirate4x4.com/forum/showthrea...ight=livin+low
Old 04-04-2011, 05:26 PM   #18 (permalink)
Member # 186622
Thanks for the links. i have been planning this swap for about four months now. and the rear hanger boogle me. once i get my metal in the next day or two. ill post some pics of the hangers as im fabing them.
Old 04-04-2011, 05:39 PM   #19 (permalink)
91extsas's Avatar
Member # 184697
deff start a build thread.
Old 04-04-2011, 05:53 PM   #20 (permalink)
Member # 186622
Ok ill do that! now placing the rear hanger? ive heard of a hole in the frame just before the boxed part ends. is that a good starting point?
Old 04-04-2011, 06:15 PM   #21 (permalink)
91extsas's Avatar
Member # 184697
make your front hangers first. get a rough idea of where the rears should be then put weight on them measure ur shackle angle and play with where u have ur hangers just tack em in just to make sure u have them where u want them. want ur shackle angle at about 25-30 degrees back.
Old 04-04-2011, 06:58 PM   #22 (permalink)
Member # 186622
Ok i see. thanks for all the help on this.. ill start that thread when i start the build.
SAS'ed 1992 K1500 ext... Aka Spot..
L1992 ford regcab longbed..
Old 04-04-2011, 08:20 PM   #23 (permalink)
Member # 166945
whatever you do dont copy his brackets lol
snopro803 is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 09:48 AM   #24 (permalink)
91extsas's Avatar
Member # 184697
FAH Q sno pro my hangers came out just fine and will be pretty damn rugged
Old 04-05-2011, 09:56 AM   #25 (permalink)
Member # 107830
X2 sketchy....
