4l60-E to Th 400 ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-15-2011, 01:27 PM   #1 (permalink)
Member # 84230
4l60-E to Th 400 ?
So I'm running an LS1 motor with a 4L60-e behind it.
I Swapping out for a th400.
What if anything do I need to do with the computer now that I wont be utilizing the lock up torque converter switch nor the electrical shift wiring?
Thanks
Please no opinions, only experienced instructions please.
VetteJ is offline   Reply With Quote
Old 04-15-2011, 02:50 PM   #2 (permalink)
Member # 184984
Thanks
If you have HP tuners or equivalent you can turn off all of the fault codes related to the transmission. Several faults will come up for missing shift indicator, incorrect line pressure, no speed sensor, ect.
This is detailed on a different forum specific to the engine your using, it has step be step with photos. It is not a 4x4 forum, but I don't think I am allowed to post a link to it.
Twinturbo496 is offline   Reply With Quote
Old 04-15-2011, 03:37 PM   #3 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
Just have the PCM tuned to remove the 4l60e auto tune. PM waynehartwig he is a sponsor here and can do the tuning.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
GM Gen III/IV V8 swap info
TECH: Gen III/IV "LS motor" to Early GM Auto Trans
Bo185 is offline   Reply With Quote
Old 04-16-2011, 09:00 AM   #4 (permalink)
Member # 84230
got a hold of wayne. thanks.
What would you suggest for a VSS ?
I'll be mating and atlas 2 to the th400.
Old 04-16-2011, 02:41 PM   #5 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
Can't you get an atlas with a VSS? Or just have him tune it with out one.
I would run a 4l80 and use its rear VSS. That way you would have OD. All you do is buy the stub harness or repin and add the VSS as well has have to tune the PCM.
Old 04-17-2011, 06:28 AM   #6 (permalink)
Member # 88919
This is what I would do also.
[COLOR="Lime"][I]At 1300rpm's would you rather have 10 extra hp or 10 extra lb-ft of torque?[/I][/COLOR]
Rinkrat456 is offline   Reply With Quote
Old 04-17-2011, 09:59 AM   #7 (permalink)
Member # 91791
Send a message via AIM to g-wizz
really dude... does it really seem like posting a link would be that big of a deal. i mean if you did, you would be doing so to help somone. about the only thing that will get you banned on pirate is dropping the N bomb or the like. i wouldnt really worry about consequences on here unless your being a racist asshole or trying to rip somone off. pretty much eveything else seems to be kosher.
74k20 with 6bt nv4500, 203/205, d60, 14bolt, lots of metal and booger welds... one of these days.
g-wizz is offline   Reply With Quote
