NP205 to TH400 adapter problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-17-2011, 03:54 PM   #1 (permalink)
1976 F100 project's Avatar
Member # 88251
Send a message via AIM to 1976 F100 project
I have a 86 2500 suburban with the 6.2 Detroit diesel. Originally had a NP208 behind a TH400. I'm swapping the 208 for a 205. Just picked up a 205 out of a 87 K30. Went to bolt it on and it wouldn't mate up. There is about 1" between the tailhousing and the 205 case. I need a tailhousing that would be able to mate the long shaft instead of the short shaft 205 input. Because this truck is a diesel it is a J code. I need to know where I can find a TH400 long shaft tailhousing to mate to the round 6 bolt pattern on the 205. Please let me know where I can find this it has been very difficult finding one
1976 F100 project is offline   Reply With Quote
Old 04-17-2011, 05:37 PM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
which 32spl input gear do you have? long or short?
exactly how long is the 208 adapter and the tail shaft from the th400?
Old 04-17-2011, 09:48 PM   #3 (permalink)
Cotton Farmer
Member # 167491
Send a message via ICQ to jd8420
208 and round 205 use the same transmission tailshaft with 2.375" stick-out. If you are trying to use the 2.5" 208 adapter, it will not work. You need the 4" 205/TH400 round adapter.
jd8420 is offline   Reply With Quote
Old 04-17-2011, 10:04 PM   #4 (permalink)
Member # 138801
I'm gonna guess he has a long shaft 32 spline 205 from behind a sm465
geo in a K5 is offline   Reply With Quote
Old 04-17-2011, 10:25 PM   #5 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
the long input was also used in late 86ish+ th400.
Old 04-17-2011, 10:38 PM   #6 (permalink)
Member # 138801
This I didn't know, was there a reason for the different length shafts for the th400 to 205 combo?
Old 04-17-2011, 10:49 PM   #7 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
i "thought" it was so that they could use the same output shaft and addapter as the 208/241.
but jd8420 say that you need a 4" round adapter......
Old 04-18-2011, 04:16 PM   #8 (permalink)
sweetk30's Avatar
Member # 80500
cant use the 208/241 adaptor on 205.
were will the shifter pivot bolt go ? as the 208/241 use floor pan mounted shifter.
if you can't play nice then STFU. Don't get pissed & go flaming someone cause you SUCK !
sweetk30 is offline   Reply With Quote
Old 04-18-2011, 05:50 PM   #9 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
duh, youre right.
Old 04-18-2011, 07:01 PM   #10 (permalink)
Member # 138801
This makes me question whether there actually was a long shaft used in the 205 to mate to the 400.
Old 04-18-2011, 08:54 PM   #11 (permalink)
Cotton Farmer
Member # 167491
6 bolt round 205's use a long input on the 205 and a 2.375" transmission shaft (same as 208/241). Figure 8 or racetrack 205's use a short input and a 4.5" transmission shaft. All TH400 to NP205 adapters are 4 inches thick.
Old 04-18-2011, 08:57 PM   #12 (permalink)
Member # 88251
Does advance adapters have this?
Old 04-18-2011, 09:18 PM   #13 (permalink)
Member # 188659
I had that same problem
I went through that same issue.I cut the tail shaft of my thm 400 and used the round to 8 bolt adapter.2 years an works like it should.Also O.R.D sells all those hard to find adapters,or I have a 6 hole to 6 hole 4"deep adapter that was made for the problem you have for sale 100$ I also have a round bolt to round bolt (208 to thm 400) stock adapter 150$.
bigk588 is offline   Reply With Quote
Old 04-19-2011, 08:04 AM   #14 (permalink)
Member # 13786
You could also install the short 32 spline input into the 205
KWTMECH is offline   Reply With Quote
Old 04-19-2011, 08:34 AM   #15 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
thats what I did... worked great.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
