Master Cylinder? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-30-2011, 03:56 PM   #1 (permalink)
Member # 62990
Master Cylinder?
I am in the process of converting a 69 c-10 to 4x4. A soft core resto mod driver. Anyway, I used an 85 blazer as the donor. The cheap alumaplastic power master cyl looks like a$$, and leaks. Does anyone know of an old school iron master that will "bolt up" without too many mods. I know that there are many possibilities, but looking for something that will still have decent street manners. all stock blazer disc front, drum rear.
Thanks in advance.
dunenutt is offline   Reply With Quote
Old 04-30-2011, 06:11 PM   #2 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
are you asking what power booster/master combo will fit your c-10 or what master will fit the donor blazer booster that originally had the plastic resivoir attached? personally i would run the setup you got and make sure it works good, then start swapping out stuff.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is offline   Reply With Quote
Old 04-30-2011, 10:49 PM   #3 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
anything pre 1980 then.
just tell them its for your 69 with power brakes and you will get a bolt on iron master.
Old 05-01-2011, 06:33 AM   #4 (permalink)
Member # 62990
sjracer, I have everything and it works. The AL master weeps around the bowls, and generally just does not look old school.
trkklr77, Thanks, I'll try one from a 71-72 because they didn't have power brakes in 69.
Old 05-01-2011, 08:07 AM   #5 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
my 70 did......
Old 05-02-2011, 08:47 AM   #6 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
1979 firebird master cyl with 4wheel disc brakes. cast iron. designed to run 4 wheel discs, costs about 15 bucks, i think (last one i bought was 14 and change.) works with or without power booster. use a pedal ratio of 7:1 without power booster.
here
works for me.
looks like the price went up, and could be that i get my parts at a reasonable discount...
oh, hey.. not too much, look at this one:
Here
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is online now   Reply With Quote
Old 05-03-2011, 08:23 AM   #7 (permalink)
Member # 62990
Grumpy,
How well does the rears work if this is for 4 wheel discs, and I have drums?
Old 05-03-2011, 10:33 PM   #8 (permalink)
Devout Newbie Hater
Member # 20147
probably will definitely stop a set of drums dead in their tracks... it sure works for discs, they take a LOT more pressure.
