Buick 455 into a Chevy????Anyone??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-25-2011, 05:35 AM   #1 (permalink)
Member # 41429
Send a message via MSN to scrapper69
I haven't been on here in some time, but I am trying to find out if anyone out there knows of any kind of manufacture that makes bellhousings to put a Buick 455 in to a Chevy Blazer with a manual trans. I just had this smokin 455 dropped in my lap, and would like to put in my Blazer just for fun, and I'm having a hard time finding any conversion info, and whether or not there is a conversion bellhousing for it. Or, if anyone has ever done it, and can point me to the right people. Thanks a million to anyone who has any info.
'84 Blazer, D60, 14FF,Detroits both ends, with 456's, on board air, SM-465, NP205TF, Corvette factory roller lifter block Edelbrock intake, with Quad built, MSD ignition, crossover steering over springs, rear shackle flip, custom bumpers with rear swing out, 6-point cage,,
scrapper69 is offline   Reply With Quote
Old 05-25-2011, 09:33 AM   #2 (permalink)
Member # 127650
Originally Posted by www.jeeptech.com/convtrans/gm/gmsm465id.html
Rumor is, the late 70s to 81 GMC trucks were available with a Oldsmobile 5.7L diesel and SM465. The bell housing used in this truck would be useful to mate an SM465 with a Buick engine since this engine should have the BOP/BOC pattern.
What manual trans were you hoping to run? What year blazer?
RanchTruck is offline   Reply With Quote
Old 05-25-2011, 12:10 PM   #3 (permalink)
45
rugburn's Avatar
Member # 45
http://www.chevy-wiki.com/wiki/List_...using_patterns
http://www.jegs.com/i/JEGS+Performan...60172/10002/-1
You suck at the intarweb
John Runberg
rugburn is offline   Reply With Quote
Old 05-25-2011, 12:44 PM   #4 (permalink)
GMCTruxrule's Avatar
Member # 51243
that Jegs part only works with auto trans apparently...
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 05-25-2011, 01:18 PM   #5 (permalink)
90ctd's Avatar
Member # 110717
Location: Glen Burnie, MD wishin I was still wheelin in N Idaho
From his sig...
"'84 Blazer, D60, 14FF,Detroits both ends, with 456's, on board air, SM-465, NP205TF, Corvette factory roller lifter block Edelbrock intake, with Quad built, MSD ignition, crossover steering over springs, rear shackle flip, custom bumpers with rear swing out, 6-point cage,, "
94 ZJ- 4.0- 5.13s-D60 lockright- D60 welded- 39.5 TSLs and H1s- 4:1 DEO Flipped dana 300 on the way
90ctd is offline   Reply With Quote
Old 05-25-2011, 06:54 PM   #6 (permalink)
Member # 127650
Which means the quote I gave him exactly fits what he wants. I don't bother reading sigs, half the time people aren't talking about the the truck in it, and if they can't be bothered to list what they want to couple together in their question, I sure as hell ain't going out of my way to help 'em.
Old 05-25-2011, 08:11 PM   #7 (permalink)
Member # 121293
Couldn't you use the bellhousing from an old manual Pontiac? I know they'll bolt right to the Buick, but I don't know about the clutch situation.
'85 4wd S10, ECLB with an '05 LLY Duramax/Allison, Locked 1 ton's, air-ride, 38's, & twin 241'.s
DieselS10 is offline   Reply With Quote
Old 05-26-2011, 08:49 PM   #8 (permalink)
Dear Penis
brooks294x4's Avatar
Member # 123551
you better hope that 455 stays healthy, those things are $$$$$ to fix or build. as said before, id look into an older manual that came behind one factory. good luck finding one, and when you do, more $$$$$. also wanna see what kinda tcase youll be able to adapt if you gotta switch trannies.
90 Jimmy 350/465/205/60/14/44's
04 Sierra Duramax ZF6 on 37's
I work hard for a living, millions on welfare depend on me...
Looking for 1 44" TSL for 15" rim, pm me if ya have one
brooks294x4 is offline   Reply With Quote
Old 05-27-2011, 06:03 AM   #9 (permalink)
DIY4X's Avatar
Member # 63837
Cadillac 513 with a mid plate/adapter for running the SM465. Midplate is 1/4" thick steel.
Cadillac 508 with a 1/4" thick adapter for running the NV4500.
Both of course BOP pattern engine blocks and a good excuse to pic whore.
SUPPORT THE BLUE RIBBON COALITION!!!!
Specialty off road shop. In house fabrication for just about anything you might need.
SAS Kit coming soon!
712-472-0200 Order line
712-479-2252 Tech support
www.diy4x.com
DIY4X is offline   Reply With Quote
Old 05-27-2011, 08:37 AM   #10 (permalink)
angryblack's Avatar
Member # 142394
Havent heard about it in a while but mccleoud(sp) makes a universal bell that will work for you..Last one i saw used was a buick 455 in front of a T56..
Maybe worth looking into
Unfortunately there is no end to human stupidity -- making things foolproof only creates more ingenious fools
angryblack is offline   Reply With Quote
