Member # 34987
NP205 Tech - Divorced Ford Passenger Drop....
I SAS'ed my 1995 ECSB Chevy C1500. Since I didin't want to mess with my 2wd NV4500 or deal with a $$ front shaft, I decided to use a divorced transfer case.
The project started with a F250 HP D44, however I managed to acquire a GM D60 for free so plans changed accordingly. So, I needed to make my D-drop case work with a P-drop axle. In short, this is very easy to do. The case is symmetric in regards to the input/output mountings. I had to modify the rear output housing: ![]() I drilled some extra holes for the oil passage since this case was going to be clocked flat and ground a little on the oil scoop. I went ahead and ground the rails for twinstick as well. To be safe, I also swapped the rails around also. Here is the case mounted in the crossmember. I decided that I wanted the crossmember to run under the case. ![]() I also had to make subframes to make this work: ![]() Here it is installed: ![]() ![]() As you can see, the input/outputs easily swap around which enabled me to use this case with a GM axle. Also, the high portion of this case fits nicely up in the trans tunnel. Here it is with driveshafts: ![]() ![]()
1 TON SAS'ed C1500 ECSB on 37s Last edited by axisT6; 07-24-2011 at 05:08 PM. |
Karnage
Member # 55444
That looks pretty clean. Pics of the rest of the truck?
Thanks to BAILEIGH INDUSTRIAL
![]() Krush RT IFS/IRS Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color] https://www.facebook.com/KrushRacing |
Member # 34987
I know a lot of you will disapprove of the subframe, but aside from cutting into the floor, or putting on a body lift, this was my next best option.
1 TON SAS'ed C1500 ECSB on 37s |
Member # 34987
Here it is now with 37s (same tires as above):
![]() ![]() Here is with the same amount of lift with some 40s I had: ![]() The only other thing a little unique about this build is that I used a 93' dually 14FF and adapted 02' 14FF SRW disks to it.
1 TON SAS'ed C1500 ECSB on 37s Last edited by axisT6; 07-24-2011 at 05:18 PM. |
Member # 16536
that's pretty cool. I have a divorced Ford 205, but have a HP60. If I ever need to switch, now I know how to do it rather than getting a pass drop 205. Like the truck too. The subframe doesn't hang that far down. But it's better than a body lift or cutting the floor...
#8 (permalink) | |
Member # 34987
I got smart and made a catch can with a drain and installed it towards the end of the vent hose, however I think the case is done spitting oil.
Member # 142394
Thats good info to know..I actually passed up a ford 205 with 1350 yokes
guy sold it for 50 bucks.. To me the ford case has a better mount location than the dodge case.On the dodge there doesn't seem to be enough support down low.
Unfortunately there is no end to human stupidity -- making things foolproof only creates more ingenious fools |
#12 (permalink) |
skullfuckery
Member # 29016
i dont understand how you swapped the shift rails AND ground them for twin stick.....
if you swapped the rails the detents for the interlock pills would now be on the outside facing away from the center of the case and the interlock pills. if you flipped the rails over to make the interlocks work then the detent ntches for the balls/springs are now on the bottom of the rail not the top.....
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#13 (permalink) |
Member # 2092
Clean. if you want to clean up the frame rails, you could always angle the ends of the crossmember up inside the frame but its not bad for most uses now.
A gm tail housing could help with the vent issue but I think the fill spec is about 1.5 qts so you might be ok with leaving it where it quit puking. you could also run the vent to a "t" let's oil drop back into the fill hole with the other leg of the "t" going to atmosphere.
Stephen Watson www.offroaddesign.com #4488 KOH '12 12th overall KOH11 28th. It's a finish! KOH11 Sportsmanship Award. Friends & partners who helped: Offroad Design, Pacific Fab, King, Baja Designs, TrailReady, Amsoil, PSC, Tom Woods, Bighorn Graphics, Superior, Optima |
#14 (permalink) |
skullfuckery
Member # 29016
i have well over 3qrts in my ord double "flat" clocking.
i welded a bung hole into the top of the pto plate and filled er up. i would even bet there is 4+ qrt in it, no mass blow out. id say it has more to do with your grind mod and the vent tube clocking than over fill.
#15 (permalink) |
Member # 34987
Good to know, however after all was said and done, the factory vent was a little too close to the oil level for my comfort. That is why I installed the vent hose fitting up top.
#16 (permalink) | |
Member # 34987
#17 (permalink) | |
Member # 34987
#18 (permalink) | |
Member # 34987
#19 (permalink) |
Member # 228167
Questions on ford case in ur chevy
i recently bought a ford case for my chevy and swapped the inputs and out puts but stuck on the shifter issue is there any chance you have pictures of how you made ur shifter work. would be a big help thankyou
#20 (permalink) |
Devout Newbie Hater
swap out the shift rails.
look, this isnt rocket science. I put a ford case married to a th400 chevy, drivers drop front output... all together with a few hours of thinking. no shift linkage adjustments required. I built my own linkage, used a couple of pieces of flat bar, and two 3/8" heim ends. again, it isnt rocket science
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! |
#23 (permalink) |
Member # 112607
X2 !!!!!!!
I've got mine down to 11-1/2"
77 K10 body, K20 frame, K30 axles cummins 12v getrag 5spd div.NP205 4.10 42" michelin X's 84 K30 quad cab,350,350,203,dueces,hemmt beadlocks,14.00 R20 XLs |
