KOH Stock Class - Really Stock LJ Build - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Competition and Event Info > Competitions and Events
Old 01-26-2012, 06:50 AM   #151 (permalink)
Stock Rock Racer
FC4X4's Avatar
Member # 195725
Originally Posted by Provelogear View Post
For the fuel regulator, you don't need to hook the vacuum up. You will need to plumb a feed and return line to the regulator. Our works fine with AN-6 stuff. The bottom is the return. Then the feed to one side and the other side to the fuel rail. You'll need that AN-6 to fuel rail adapter.
Good luck on getting that Tera bump in the rear. Since we can't cut the frame rails it real tight back there.
Only a few more days left!
Look forward to seeing you out there!
If you don't mind, Gerald, I might give you a call this morning. What you describe as the correct way to plumb this is what I had in mind. The problem that I see is that there are only two -6an fittings on the regulator. One inlet and one return. The "outlet" side is 1/8" NPT and the instructions say it's for a pressure gauge. I don't think this side of the regulator would flow enough fuel. I am not sure I have the right part. Would a tee on the inlet side work to drop pressure out of the entire line as fuel flowed past the regulator, or do I need a different regulator?
Jason Kaminsky
- Ultra4 Stock Class #4678 - Four Corners 4x4, Superchips, M.O.R.E., Durango Custom Works, Associations Direct, Clayton Offroad Manufacturing, Bigelow Motorsports, Savvy Offroad, Yukon Gear & Axle, Tom Wood's Custom Driveshafts, Metal Cloak, Bilstein, Grandview Land Holdings
FC4X4 is offline   Reply With Quote
Old 01-26-2012, 07:21 AM   #152 (permalink)
Savvy Off Road
Provelogear's Avatar
Member # 110540
Call me 949-870-8106
THE ULTIMATE LIGHTWEIGHT JEEP PROTECTION AS PROVEN AT THE KING OF THE HAMMERS. TWICE! BACK TO BACK OVERALL EMC WINNER.
Click here for: SAVVY OFF ROAD
Provelogear is online now   Reply With Quote
Old 01-26-2012, 09:23 AM   #153 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
You have the right regulator. It gets T'd into the pressure line. Take your pressure line going to the rail and add a T somewhere. Hook the extra leg of the T to the inlet of the pressure regulator, hook the outlet to the return on your tank. That's all you need to do. It would be wise to at least hook a gauge to that 1/8" port for setting your pressure though.
Dallas Ashley
StinkyFab Racing (SFR) - Custom Fabrication
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Overall Winner, 2012 KOH EMC. Gettin it done in a stocker!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote
Old 01-26-2012, 10:04 AM   #154 (permalink)
Beat95YJ's Avatar
Member # 22176
This
Beat95YJ is offline   Reply With Quote
Old 01-28-2012, 07:44 AM   #155 (permalink)
Stock Rock Racer
FC4X4's Avatar
Member # 195725
Thanks for confirming what I had thought. I cobbled together a tee with parts from NAPA and it runs! I still need to get a pressure gauge.
Jason Kaminsky
Old 01-28-2012, 10:50 PM   #156 (permalink)
Stock Rock Racer
FC4X4's Avatar
Member # 195725
Pictures from the first flex yesterday. I was planning to make it out tomorrow; a bunch of folks will be wheeling in Farmington tomorrow. I just have so much to do! The test drive might be in California.
Name:  LJ - First Flex 002.jpg
Name:  LJ - First Flex 003.jpg
Name:  LJ - First Flex 004.jpg
Jason Kaminsky
Old 01-28-2012, 11:23 PM   #157 (permalink)
Member # 116105
Awesome. Glad to see this thing on 4 wheels and running. Hope you make a good showing out there. Good luck.
[COLOR="Red"][SIZE="4"]THEROCKGODS4X4.COM[/SIZE][/COLOR]
[COLOR="DimGray"][SIZE="3"]ULTRA 4 LUNATIC[/SIZE][/COLOR]
slvrbck is offline   Reply With Quote
Old 01-29-2012, 09:59 PM   #158 (permalink)
Member # 189941
Nice! rig is looking great man!
95 YJ- with stuff, 04 KJ- stock
05 F350- the tow rig
Phat95YJ is offline   Reply With Quote
Old 01-29-2012, 10:03 PM   #159 (permalink)
DOUG38S's Avatar
Member # 17107
Send a message via AIM to DOUG38S
Keep going!
TEAM YUKON GEAR and AXLE #4413
Bulldog Winch, Raceline, Maxxis, FOA, Tom Woods, Everlast Welders, Ruffstuff Specialities, Cool Shirt, Stage 8, Baja Designs, PSC Steering, AJIK Overland Exchange, Reid Racing, Artec, Powertank, DynoMax, Hinchman Racewear, DJ Safety
DOUG38S is offline   Reply With Quote
Old 01-29-2012, 10:16 PM   #160 (permalink)
HOG JOCKEY
Member # 54114
good luck to you. lots of hard work and frustations! looks like you are a little short of clearance on that front passenger tire in your flex shot.
herbycj5 is offline   Reply With Quote
Old 01-30-2012, 04:03 PM   #161 (permalink)
Stock Rock Racer
FC4X4's Avatar
Member # 195725
Yep... I thought I would be able to run the flares on the front. They have been removed again. This is on 5 1/2" of suspension lift and 1" body lift. No trimming in the front. I trimmed the back fenders now as well; the wheelbase is strecthed to 106".
The front driveline wasn't working... and that had nothing to do with the driveline construction. My front 60 is very narrow at 63 1/2" WMS. That has caused a lot of frustration during this build. I had to cut up and relocate all my front suspension brackets to make them fit on the axle and still the pinion is so far to the passenger side that it's hard to avoid the side of the transmission and the exhaust. I ended up putting in my old driveline from the old YJ. It's a Tom Wood's two-piece. I am hopeful it will work. I am very concerned about potential vibration because of the angle at which I have the first joint set. Time will tell, but the first shaft definitely won't work. I talked with Tom about it today and he said he would take the other shaft back. That's great; especially since it really wasn't a driveshaft issue.
We're cutting off the rear lower shock mounts now. The shock tubes rubbed on the axle tube during articulation. Hoping to drive it soon!
Jason Kaminsky
Old 01-30-2012, 04:06 PM   #162 (permalink)
Savvy Off Road
Member # 110540
Come on Jason! Power thru it you are almost there!
Old 01-30-2012, 04:40 PM   #163 (permalink)
Jarhead
BTF1's Avatar
Member # 25253
Got to hand to all of you running in this class, not much money and working your ass off, we will all be watching you in a few days, hang in there and keep work it only gets worse from here, you could have four cars to prep looking forward to watching all of you race and good luck!!!
Thanks for your support:
Wide Open Design http://www.wideopendesign.com/
Radflo Shocks http://www.radflo.com/
Torq Axles http://www.torqaxle.com/
RCV http://www.rcvperformance.com/
Twisted Stitch Seats http://www.twistedstitchinc.com/
Rugged Radios http://www.ruggedradios.com/
Bower Motorsports Media http://www.facebook.com/charlene.bow...s#!/BowerMedia
Trail Ready Wheels
http://www.trailready.com/wheels.html
http://www.facebook.com/bentandtwistedracing
Bent and Twisted 4x4
Bent and Twisted Racing
620-805-1959
BTF1 is offline   Reply With Quote
Old 01-30-2012, 06:24 PM   #164 (permalink)
Member # 168725
Wow that's a pretty crazy build to tackle in that time period.
Keep it up you are close!
Just hack sawzall those flares.
SideshowBob is offline   Reply With Quote
Old 01-30-2012, 08:54 PM   #165 (permalink)
Member # 143821
Keep it going buddy, you will make it. By the time I make the lakebed, I want to hear all kinds of war-stories and bench racing from your race...
#129 is ready to roll. GPS mount from Stinkyfab is in and being mounted, that was the last thing to do..
Hang in there Jason, you got it handled I know...
Arctic Cat Desert Race XTZ: ITP, King Off-Road Racing Shocks, custom +5 Suspension & more..
Darryl89 is offline   Reply With Quote
Old 01-30-2012, 11:18 PM   #166 (permalink)
Stock Rock Racer
FC4X4's Avatar
Member # 195725
Thanks for all the encouragement. You're right; the timeline is nutty. I purchased this thing bone stock just about 72 days ago. It has been a ton of work and some fun as well. I am getting excited about the trip; I am bummed there has been virtually no testing completed. Our preliminary flexing did point to several problems we have hopefully overcome now. It looks like I will be ditching the front swaybar. Packaging is insanely tight and I would rather run without than one that's messed up and interfering with my steering linkage. We'll also most likely be without rear bumps; just out of time.
Noticed my seatbelt were the wrong mounting style this weekend and reordered new... to arrive tomorrow. We got the front driveline and rear shock mount issues addressed today. The graphics are done as well...
Name:  LJ Progress 01-30-12 001.jpg
Here's a picture of what I did for the fuel pressure regulator. I am still not sure if I should be running the vacuum port connected or not.
Name:  LJ Progress 01-30-12 002.jpg
Name:  LJ Progress 01-30-12 003.jpg
Name:  LJ Progress 01-30-12 004.jpg
Name:  LJ Progress 01-30-12 005.jpg
Jason Kaminsky
Old 01-31-2012, 05:35 AM   #167 (permalink)
Newbie
Hoose's Avatar
Member # 179197
Build turned out good. See you on the lake bed.
2003 ford F-350 srw ex cab long bed 4x4 7.3L
98 TJ with some stuff
2012 KOH Modified 4555
Get your Atlas support rings here
www.roarkfabrication.com or call 606-286-0681
Hoose is offline   Reply With Quote
Old 01-31-2012, 07:53 AM   #168 (permalink)
Member # 206767
looks good
sallys xj is offline   Reply With Quote
Old 01-31-2012, 10:51 AM   #169 (permalink)
konacaliboy's Avatar
Member # 40585
Totally pulling for you! Been watching your thrash build on here and it's exciting just to keep up behind the keyboard here....Good luck man, hope you guys do well
KI6TUI
konacaliboy is offline   Reply With Quote
Old 01-31-2012, 04:07 PM   #170 (permalink)
:flipoff:
rob low's Avatar
Member # 98084
Don't connect the vacuum port. It's only for Boosted Engines.
Your a real breath of fresh air.
www.wnyoffroad.org
My build: http://www.wnyoffroad.org/forum/viewtopic.php?t=4271
rob low is offline   Reply With Quote
Old 01-31-2012, 11:45 PM   #171 (permalink)
Member # 189941
cool man, the stickers make it! Good luck out there!
Old 02-01-2012, 04:26 PM   #172 (permalink)
Stock Rock Racer
FC4X4's Avatar
Member # 195725
Packed up, paying some bills, and heading out tonight. See you all there, ready or not!
Jason Kaminsky
Old 02-02-2012, 10:16 PM   #173 (permalink)
Newbie
Hoose's Avatar
Member # 179197
Turned out good. See you on the lake bed.
Old 02-03-2012, 07:37 PM   #174 (permalink)
DOUG38S's Avatar
Member # 17107
You better have this buttoned up! We got a race to win!!!! I'll be in tomorrow around lunch time. Maybe a quick ride before the drivers meeting?
Old 02-03-2012, 08:39 PM   #175 (permalink)
whypave's Avatar
Member # 28177
Doug in a rig racing on Krawlers. 2012 really is the end of days
Smiley Racing 609
1st Place KOH class Badlands UMC race Oct 2nd 10
11th and 8th place 1st and 2nd RCrocs 10
New buggy
http://www.facebook.com/TeamSmileyRacing
Thanks to:
Crane Clayton Offroad BFGoodrich Bilstein Tom Woods Driveshafts
Tom Guaraldo RIP!
whypave is offline   Reply With Quote
