Hey Rich please clarify calrocs rules - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Competition and Event Info > Competitions and Events
Old 04-28-2003, 08:14 PM   #1 (permalink)
Member # 14041
Send a message via MSN to Team Purple
Addendum: (04-10-03) All vehicles must retain their original back body corner designs (no dovetailing permitted). All vehicles must have rear lights for stop/turn and driving. After market lights may be used.
is this only for stock class? does not make since in pro or super
Ron Schneider (driver)
[COLOR=Purple](Team Purple)[/COLOR]
[FONT=Arial Black]Home of the GCD Portal's[/FONT]
If nothing else (GET IT)
Team Purple is offline   Reply With Quote Quick reply to this message
Old 04-28-2003, 08:23 PM   #2 (permalink)
pro web-wheeler
RedBullJeep's Avatar
Member # 12217
This rule only applies to purple vehicles in Pro Class.
RedBullJeep is offline   Reply With Quote Quick reply to this message
Old 04-28-2003, 08:51 PM   #3 (permalink)
Member # 2769
And while you are at it, Rich, tell what's happened with that "cutting and reboxing is allowed for non-suspension components (except non coil-over shocks)" sentance that you inserted into the Mod-Stock rules last month and now conspicuously absent in your latest and the RCAA version ... .
Jaffer is offline   Reply With Quote Quick reply to this message
Old 04-28-2003, 09:37 PM   #4 (permalink)
Member # 14041
hey dusty, don't worry there is not much left of the Purple rig, but it will still give you a run for your money this weekend, (I hope)
, this will be its retirement compitition>>>>>>>>>>>>>.
Old 04-28-2003, 10:06 PM   #5 (permalink)
Big Rich's Avatar
Member # 3123
Send a message via Yahoo to Big Rich
The cutting for clearence of non suspension items (and reboxing) should not have been dropped from the rules. I did not notice that it was missing
Dovetailing is not allowed in the modified stock class only.
Rules are a pain in the a$$.......and even if you don't believe it, we are trying hard to come to a standard. If you don't like our standard, or what we are trying to do......there are ale\ways others with different rules. Someday, someone might hire a lawyer or professional rules writer and come up with the perfect set of rules (yeah right) and I will applaud the task, until then help us work through the problems ask questions. Maybe we'll get them right like SCORE or NASCAR, where they use the same rules for 10-20 years.......
Rich
Thanks to our marketing partners: MAXXIS Tires, Trail Gear, NITTRO Gear and Axle, ARTEC Industries, Branik Motorsports, ASR Recovery Gear, SpiderTrax, Dirt Skins, Metal Cloak, Crown Automotive, SuperChips, PSC Steering, Fox Shocks, Axel Off Road, Currie Enterprises, PCI Race Radios
Originally Posted by ZUKROVER
4 wheeling sure changes when there is a crowd and cones.
530-417-5333
( @ Y @ ) ( * Y * ) ( . Y . )
Big Rich is offline   Reply With Quote Quick reply to this message
Old 04-28-2003, 10:14 PM   #6 (permalink)
Member # 14041
does this apply to Pro class?
please go into depth if it does
Old 04-28-2003, 10:18 PM   #7 (permalink)
Big Rich's Avatar
Member # 3123
No only to the Modified stock
530-417-5333
Old 04-28-2003, 10:26 PM   #8 (permalink)
Big Rich's Avatar
Member # 3123
IT"S IN THE CALROCS RULES THAT ARE LISTED ON www.calrocs.com
under vehicle requirements, modified stock, body (near the middle of the section)
Tub/Cab
=Must house two front passenger seats mounted side by side at both the left and right side of the vehicles passenger compartment.
=General condition must be in good shape without excessive rust or damage that would warrant concern for safety.
=Excessive body damage, as determined by an RCAA official, is not approved.
=All OEM tub/cab configurations are approved for competition. Aftermarket tubs must be OEM width and RCAA approved.
=No bolt in body panels are allowed (zeus clipped, quick replacement panels). Repaired panels are acceptable.
=Complete floors must be maintained.
No cutting of floor is allowed with the following exemptions.
=The center section of the body is approved for cutting & raising to allow drivetrain clearance directly over drivetrain components. This does not include axles or axle shafts. Cutting and reboxing for the clearance of non suspension items , including tires, shocks and fuel tank is permitted.
=Tubs/cabs may be cut along the bottom (rocker) area of the vehicle.
=The back of the tub/cab may be trimmed horizontally to match the rocker height. A minimum distance of 24 from the center of the axle to the back of the body must be maintained on bobbed vehicles. Trucks with non-convertible tops must maintain top.
1- Glass may be removed (recommended). All non-safety glass must be taped completely.
2- Doors may be removed.
Rich
530-417-5333
Old 04-28-2003, 10:34 PM   #9 (permalink)
Member # 14041
Thanks Rich
See you on Friday
Old 04-28-2003, 11:04 PM   #10 (permalink)
BBP
Member # 8225
Rich
Having a set of rules that's good and stands the test of time is great and all, but I hope to god competitive rockcrawling never gets to the point NASCAR is at where everyone drives identical cars around in left hand circles a bunch.
Half Toyota half... well ok it's just half a Toyota right now.
BBP is offline   Reply With Quote Quick reply to this message
Old 04-29-2003, 06:51 AM   #11 (permalink)
TEX
Member # 603
Rich
NASCAR uses the same rules for 20 years?
TEX
Thanks to:
Extreme Performance
Bear Creek Auto Recyclers
TEX is offline   Reply With Quote Quick reply to this message
