Member # 6208
minimum weight
It can't be this simple or is it? At the RCAA Reno event. They weighed every vehicle for the unlimited class. Their scale/wood blocks was not the best method. My question is hypothetical. If I knew I was under weight. Could I fill my tires with water to make weight, then drain. I think the top money winners should be weighed after their last obstacle. Judges should follow the vehicle to the scale. maybe this is done?
Pirate is KING!
Member # 12217
And the drivers and spotters should also have to submit urine specimins as well...
I agree that it is possible, even likely that someone in the future would do exactly what you've noted, so really, you're not out of line in pointing this out...still, the rules thing is going really far and really fast without many of the rules makers considering all of the consequences when they hit upon an idea.
. Dustin Webster Red Bull RockCrawling Team RockHer 1 - SOLD |
Member # 6208
so you think everybody made weight (legally) at rcaa reno? my booth (Advance Adapters) next to scales, atleast of of them looked like they were having hard time making weight
I make websites!
Don't some competitors put water in their tires anway.. so how would you know that they didn't legititmly want to use water, and then maybe after a couple courses they wanted to try without water, and took the water out...
I could see that happening, and nothing 'illegal' or rule breaking is there.. |
Member # 603
If you're going to have a weight minimum (and we can argue the merits another day), you have to enforce it. That means checking every vehicle prior to the run & the winners afterwards. Anything less & it's not a rule, it's a suggestion.
TEX
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
Member # 14451
"Why is there a weight limit again????
unlimited should mean unlimited" Exactly!
Save Tellico Rally Post #75 Rock Solid Racing, LLC coming soon... Sponsors: Offroad Outfitters, Transportation Network Systems, Yukon Axle & Gear, Mild 2 Wild 4x4 Customs... more to come Last edited by jeepguru7; 05-07-2003 at 06:28 AM. |
Member # 10644
Any competitor can challenge the weight of anothers vehicle at any time during the event. If that vehicle is found to be underweight, they are DQ'd for the event.
As for weighing each rig before each obstacle, that will either stretch the comp into 4 days, or lower the field to 20-30 vehicles. Tech took FOREVER because of the scales in Reno. Granted, the wood blocks for the scales were a problem and it can all be improved. But each rig's width and length is different and if you spend 1 minute placing the scales for each rig - that adds another hour to tech. The future may be to weigh each rig before a run, but things are going to have to be improved first. |
Newbie
Member # 19108
[QUOTE]Originally posted by bigdude
[B]Why is there a weight limit again???? Exactly what I was wondering. If someone can build an 1800lbs rig that could survive a competition and be competitive, more power to them. |
#10 (permalink) | |
Member # 603
Again, not arguing in favor of minimum weight restrictions, nor against them. But, cost is only one potential factor why they would be used. TEX
#11 (permalink) | |
Super Moderator
Cage strength is the first to come to mind... kept in check by min. tube thicknesses (drill and measure method) and min. O.D. rules.
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." |
#12 (permalink) | ||
Duke of Drink
Member # 1352
Re: minimum weight
http://www.pirate4x4.com/forum/showt...5&pagenumber=3 Quote:
