They're up - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Competition and Event Info > Competitions and Events
Old 11-15-2003, 06:40 PM   #1 (permalink)
Pirate is KING!
RedBullJeep's Avatar
Member # 12217
They're up
The rules are up on UROC's site...I saw a couple of wording mistakes and a legends frame rule was insterted into the stock mod frame rules (for cutting the frame). There are still a few event formatting changes to be hashed out but those won't change anything for the way you build your rigs. Spotter ride is the same for single or two seater.
To the Skeptics...
Dustin Webster
Red Bull RockCrawling Team
RockHer 1 - SOLD
RedBullJeep is offline   Reply With Quote
Old 11-15-2003, 06:44 PM   #2 (permalink)
Member # 7482
Look at them closely...... Have a problem don't just bitch. State the problem and give some input so we might fix something. Now not Later!
"It's all about the skinny pedal"
pure-adrenaline is offline   Reply With Quote
Old 11-15-2003, 06:50 PM   #3 (permalink)
Member # 13742
The Modified frame line was fixed about two minutes after it went up.
Mark
polop is offline   Reply With Quote
Old 11-15-2003, 06:53 PM   #4 (permalink)
Pirate is KING!
Member # 12217
The UROC opinion is that these are the rules except for a few formatting changes that will come later (plus the issues I've already noted). If you have a suggestion, please make it in a positive way with a solution included. I cannot say that it will change these rules as they need to be somewhat firm, but they are willing to listen if a suggestion could make a big difference in improving things.
Dustin Webster
RockHer 1 - SOLD
Old 11-15-2003, 06:53 PM   #5 (permalink)
Smores!
Scott@Rockstomper's Avatar
Member # 1889
Re: They're up
To the Skeptics...
My apologies for jumping the gun, and I'd like to thank Lance, Dustin, and the other round table members for working hard at this on behalf of the drivers.
And I clearly earned the Pirate salute on this one.
Scott@Rockstomper is offline   Reply With Quote
Old 11-15-2003, 09:49 PM   #6 (permalink)
Member # 15582
Send a message via MSN to Droopy Send a message via Yahoo to Droopy
well
Nice job on the rules. Thanks guys.
Droopy is offline   Reply With Quote
Old 11-15-2003, 10:49 PM   #7 (permalink)
goin4xn's Avatar
Member # 4858
Re: They're up
To the Skeptics...
Great job there guys. I can say from experience that many a late night was put in on these rules.
'84 CYJ-7 (Ongoing project)
goin4xn is offline   Reply With Quote
Old 11-16-2003, 03:00 AM   #8 (permalink)
Administrator
Lance's Avatar
Member # 1
Send a message via Yahoo to Lance
told you....
Lance is offline   Reply With Quote
Old 11-16-2003, 05:02 AM   #9 (permalink)
lt1wrangler's Avatar
Member # 9102
Thanks for the hard effort guys!
lt1wrangler is offline   Reply With Quote
Old 11-16-2003, 08:06 AM   #10 (permalink)
jeepguru7's Avatar
Member # 14451
Dustin, Lance, and other RT members,
First off thanks for all of your long and hard work to get the rules out as fast as possible and making sure the rules were fair and equal. I just have a few quick questions I need explaining on and I'll let ya'll rest for a while.
1. Starting order, On the second day will the order be determined by lowest score per group or how you stand in your class? What about a tie in points of teams in the same group?
2. Winch weights must be carried in each vehicle even though they have winch weights at each obstacle? Seems like it would cause more harm than good if the weight comes loose during a rollover making a heavy projectile that may possibly hit the driver.
3. Fire ext., says must be mounted on left and right side of vehicle, then later it says must be mounted behind driver and between seats. Which way is correct?
4. Tires, rules state tires must be available to the open market two weeks prior, is tire style or size? i.e. BFG 39" Krawlers or 40" x-terrains, each of these styles are available but the size is not.
5. Seat belts, 4 points must be worn at all obstacles, even those that are flat and technical. Loose shoulder belts can cause more harm than just lap belts in a rollover.
Other than that everything looks good for now. Again thanks for all of your precious time used representing us and I can't wait to get going again. Thanks, Justin Smith
Save Tellico Rally Post #75
Rock Solid Racing, LLC
coming soon...
Sponsors:
Offroad Outfitters, Transportation Network Systems, Yukon Axle & Gear, Mild 2 Wild 4x4 Customs... more to come
jeepguru7 is offline   Reply With Quote
Old 11-16-2003, 08:35 AM   #11 (permalink)
Member # 9102
I thik the main focus of the 15th was just to get competitors rules for defining rig building, not on obstacles or points infractions. Just my .02 worth.
Old 11-16-2003, 08:57 AM   #12 (permalink)
Member # 15646
Dunno, I think now is the time for making sure the rules are clear and consice. If there is no input they must assume that no one found any thing that needs changing. I think they're asking for constructive input on proofreading all the rules to eliminate problems. Correct me if I'm wrong.
Peter
ROCKSFORBRAINS is offline   Reply With Quote
Old 11-16-2003, 08:57 AM   #13 (permalink)
jeepguru7's Avatar
Member # 14451
I know Rusty, but I don't get much time on here so I need to ask questions when I can. See you in April.
coming soon...
Sponsors:
Old 11-16-2003, 09:52 AM   #14 (permalink)
goin4xn's Avatar
Member # 4858
I think the main focus of the 15th was just to get competitors rules for defining rig building, not on obstacles or points infractions. Just my .02 worth.
You are both correct. The big push was to get spec type rules out so that you guys (and gals) can get started building your rigs.
We are aware that there needs to be some fine tuning of the rules and your input/insight is very valuable.
Make comments to UROC and to the Round table members on items that you feel need to be addressed or clarified.
Old 11-16-2003, 11:08 AM   #15 (permalink)
Member # 7482
Make comments on everything. The rules had to be done by the 15th so the rig specs where the most important. We still can address some of your guys comments on that part but the rest of the rules have some grey areas or might need to be worded different. I think now is the time to do that so lets here everything. You guys need to talk to your buddies that don't frequent a computer too. Get there imput.
Old 11-16-2003, 12:59 PM   #16 (permalink)
Wanna mustache ride?
ROKN ZJ's Avatar
Member # 6536
Is the first event March 14-16 (Sun-Tues) or March 11-13 (Thu-Sat)??
ROKN ZJ is offline   Reply With Quote
Old 11-16-2003, 03:10 PM   #17 (permalink)
BIGELOW MOTORSPORTS
DOUG38S's Avatar
Member # 17107
Send a message via AIM to DOUG38S
Just read the rules. Great work fellas and I do appreciate it.
Couple questions:
How many spreaders are needed in a single seat application?
I saw four for what I suppose a is 2 seater but what for a single seat?Is there any restriction on what way the spreader goes? Ie, front to back or from back corner to front corner?
Also is the use of expanded metal allowed above the drivers head?
TEAM YUKON GEAR and AXLE #4413
Bulldog Winch, Raceline, Maxxis, FOA, Tom Woods, Everlast Welders, Ruffstuff Specialities, Cool Shirt, Stage 8, Baja Designs, PSC Steering, AJIK Overland Exchange, Reid Racing, Artec, Powertank, DynoMax, Hinchman Racewear, DJ Safety
DOUG38S is offline   Reply With Quote
Old 11-16-2003, 03:35 PM   #18 (permalink)
Member # 11746
Send a message via ICQ to thejunker Send a message via AIM to thejunker
Doug, not sure about the first question, but this one is covered:
Magnetic, flattened expanded sheet metal, 1/8” sheet metal or 1/8” aluminum must cover 50% of the cage perimeter on the driver side for two seat vehicles and 100% of the outer cage perimeter on single seat vehicles immediately over the driver seat and be welded or bolted to the four tubes surrounding the driver. Additional tubing may be used in place of plate steel or aluminum.
I was born not knowing and have had only a little time to change that here and there.
thejunker is offline   Reply With Quote
Old 11-16-2003, 03:49 PM   #19 (permalink)
Smores!
Member # 1889
I'm curious as to whether the 1/8" sheet metal is a typo... stock class calls out 0.040, while mod and super mod call out 1/8". 1/8" steel roof seems grossly overkill, especially on the more-modified classes where the vehicles are likely to have more tube, and less weight.
Old 11-16-2003, 03:54 PM   #20 (permalink)
TONY K's Avatar
Member # 12008
I saw that also. I would assume t-f-s or if it is a Cougar buttes then maybe f-s-s.
Tony K - Shocks - Sway Bars - Steering
tk1racing.com or Facebook.com/tk1racing
TONY K is offline   Reply With Quote
Old 11-16-2003, 04:38 PM   #21 (permalink)
Member # 23579
Excellent work from the Roundtable guys. Really appreciate these out and for all your hard work. I don't have much to change for this year, mostly just tweaking I was going to do anyway. Great work and thanks again.
Bart
Wheeling the original Super Ranger
fnbuggy is offline   Reply With Quote
Old 11-16-2003, 04:46 PM   #22 (permalink)
Member # 13536
Send a message via Yahoo to TerryHowe
That is an RCAA rule, it always read that way, although I've seen people run thinner material. 1/8" steel is absurd. 1/8" aluminum is not so bad though.
Terry Howe
TerryHowe is offline   Reply With Quote
Old 11-16-2003, 05:09 PM   #23 (permalink)
Member # 7482
On the single seat roof bars.....What do you single seater guys want? "Terry" In my opinion maybe a 24" outside to outside w/ a center bar going from one corner to the oppisite corner. More than 24" they should have 4 like the rest. Help me out and I'll have it brought up.
Old 11-17-2003, 06:26 AM   #24 (permalink)
Go2Guy's Avatar
Member # 12158
That sounds good to me- what about all these gussets in a single seater??? Going to get "busy" fast. one diagonal in either the b pillars or c pillars as well as the roof panel would go a long way and be stouter than all these baby gussets that still let your 4 sided cage fold up.
Are there any preferred ball valves out there? Return line need them too?
Many vehicles have the throttle body towards the rear of the engine and the air cleaner poking through the firewall into the passenger compartment- is this still within the intent of the rules regarding the firewall which totally separtes the engine and driver. Usually you are permitted to have some type of openings for plumbing, wires, aircleaners etc to pass thru.
Ken Blume
Rock Rod Racing
Team #192/4192
Thanks to our partners
Maxxis, Trail-Gear, Yukon Gear, Goatbuilt, Tom Woods Custom Driveshafts, Ruffstuff specialties, Warn Winch, Rokit Enterprises, Viair, Edge Perf., Branik Motorsports, PRP seats, 12V unlimited, Bailie built, Baertrax, Raceline
Go2Guy is offline   Reply With Quote
Old 11-17-2003, 09:12 AM   #25 (permalink)
Pirate is KING!
Member # 12217
This is an important question Ken...I'll pass this one on.
Dustin Webster
RockHer 1 - SOLD
