Member # 24350
Need Trailer tires/wheels in San Jon NM
Lost two tires/wheels in San Jon NM( I-40 )at exit 356(?) on way to KOH
Lug pattern is 5X5, if anyone can help, give me a ring: Pete: 240.252.9842
#14- KOH RC [url]www.fourwardmomentum.com[/url] |
Try the Pilot truck stops. They usually have trailer tires.
"I think I can break that" Wouldn't be able to do it without the support from: AXIS FABRICATION INDEPENDENT4x EMS Offroad BFGoodrich, Freaky Tree, CTM |
Semper Fi
NM got another... Good Luck, BTT for ya.
Frank 49, 55, 57, 58, 75, 80, 93, 02, 07, and still growing check out our 68 charger build http://www.pirate4x4.com/forum/showt...7&highlight=68 |
Member # 24350
Made it to a tire shop, stupid tire lacky jacked up the fully loaded trailer by the axle....bent it bad. Ordered an axle from Amarillo, wrong axle showed up. Waiting on another axle from some other damn far away place. Might make it to the lakebed in the morning
![]() Jes, ready to drink some yuengling?
Member # 26472
I feel your pain. Nearly the same thing happened to me last year on the way to KOH. If it hadn't been for the help of some good friends, I would have been limping back home from OK City.
'84 Bobbed -8, LT-1, TH400, STaK 3 speed, front 60 with Detroit/35 spline shafts, rear 14 bolt with detroit, garage built rear four link, front radius arm, 42" TSLs on locked Racelines, PSC assist, WARN 8274, lots of plating. '82 -'8 As stock as it gets... |
Member # 24350
second axle was wrong too
![]() Sean just finised cutting the spindles off and welding back to the correct length, should be out of here in less than an hour.
Member # 6420
Good luck man...........
Thanx JP 911 NEVER FORGET semper fi [URL="http://wheelersforthewounded.org"]http://wheelersforthewounded.org[/URL] [URL="http://www.sharetrails.org"]http://www.sharetrails.org[/URL] The only thing necessary for evil to triumph is for good men to do nothing |
