Swick's Half Runner - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 08-18-2012, 08:51 PM   #51 (permalink)
Member # 124782
worked and sweated my ass off yesterday to install the mini fenders, final mount the hood pins, and open up the head light openings. i started around 9 am and ended and did not finish until 430 am. took a power nap for a couple hours and i was ready to go and attend a local car show with my whore with her new face lift.
checking the fitment of the mini fenders. had to do a lot of work to get them to line up close. i still need to do some final tweaks but that will have to wait
mounting the latches and the autofab fender bushings.
i got second in my division out of 5 cars. in total there were 150 cars and only 50 awards were given out. not to bad for the whore's first time.
im having some issues with my sd card reader so i can not upload the rest of the pics i have from the last two days. tomorrow i will work on glassing in the head light buckets.
swickwake is offline   Reply With Quote
Old 08-31-2012, 11:40 PM   #52 (permalink)
Member # 124782
issues have been fixed.
Old 09-16-2012, 08:38 PM   #53 (permalink)
Member # 124782
updates are a happening. here are some teaser pictures.
ruffstuff frame notch kit. picked it up from a dr member and friend. tomorrow i will find out if i need to notch the frame. that is why the area that is to be notched is not welded. im mainly doing this to fix a crack on my driver side.
my grandpa has a 86 bronco 2 that has been sitting for a while. since that truck is never going to be driven again i went ahead and pulled the tank to i swap in to my truck.
due to all the work that is going on with the truck this week i will be rocking this look
Old 09-18-2012, 12:11 AM   #54 (permalink)
Member # 124782
today was successful (kinda). i got the tank mounted and re-positioned my charcoal canister. once i did that i moved on to plumbing the tank. this is where i hit a brick wall. the diameter of the sender/pump on the B2 tank is smaller then the my sender/pump on my oem tank. im not to happy but im going to enjoy figuring out this problem.
does not hang to low
i plated the driver side frame but i still need to add a little piece to finish it off. i was not able to get to cycle my g 50 to find bump and full drop.
Old 09-23-2012, 01:28 PM   #55 (permalink)
Member # 124782
what it looks like with the bed on.
yesterdays progress. cycled my leafs to find my travel number and to add shock to the rear. i also had an idea that drive line would make contact with my gas tank cross member. i also figured out what im am going to do to make my 86 b2 tank and fuel/sender work with my 98 ranger. i will post pictures when i get to that this next week.
bump i think i can go a little more in to negative arch.
drop. im being limited by my hanger shackle set up.
Old 10-23-2012, 10:43 PM   #56 (permalink)
Member # 124782
the swap was not as plug and play like as i had hopped. the main reason it did not go as smooth is because i was dropping a (OBDI) 89 bronco 2 tank in to a (OBDII) 98 ranger frame.
this is what your sender should look like
this is what my sender looked like.
this is what i had to do to make it work for me. (I do not recommend anybody doing this)
98 ranger sender cut up
hole cut in to tank to match the plate cut from the sender
plate from send tiged into the b2 tank. the blank sensor measures the in tank pressure and the little white thing use to have the wires that powered the pump go through it. is just a plug now. im using the connector on the 89 b2 sender power the pump.
89 b2 sender with 98 ranger pump
Old 10-26-2012, 11:58 PM   #57 (permalink)
Member # 124782
today's progress
pics of the plumbing and wiring (tomorrow i will be make everything look clean and ditching all the quick crimps for shrink tube and soder) one thing if i did not have access to all the aluminum line this project wold have been scraped. the hard lines are carb approved so i should not have any problems with smog.
Old 10-29-2012, 12:55 AM   #58 (permalink)
Member # 124782
^^^^ before
the start of make shit clean
after VVVV
Old 12-15-2012, 12:56 AM   #59 (permalink)
Member # 124782
been doing work.
last weekend VVV
Old 12-15-2012, 12:56 AM   #60 (permalink)
Member # 124782
today VVV
Old 12-16-2012, 10:51 AM   #61 (permalink)
Member # 124782
did work yesterday. im 98% finished with the fab work. i just need to clean up some thing today and it all will be done. im going to get it all powder coated. im thinking the framing black and keep the box white.
for most of yesterday i was mainly working on the box. it started out as a lay flat and open with the dimensions of 18"L x 18"W x 32" T. i converted it to a stand up and open with the new dimensions 18"L x 18"W x 32". i traded my small old box for two of these boxes.
Old 12-16-2012, 10:51 AM   #62 (permalink)
Member # 124782
Old 12-17-2012, 11:02 PM   #63 (permalink)
Member # 124782
i gave my mobile house a front porch
Old 12-23-2012, 02:05 PM   #64 (permalink)
JEEPTJ97's Avatar
Member # 138863
Pretty sweet set-up. I like the swing out design.
97 Jeep TJ
JEEPTJ97 is offline   Reply With Quote
Old 01-09-2013, 05:43 PM   #65 (permalink)
Member # 124782
Thank you.
Old 04-07-2013, 11:45 PM   #66 (permalink)
Member # 124782
my weekend started like this. I globe trotted California last night. I left Chico at 6:30 made it to sac at 8:00 and left at 8:30. Then I made it to redwood city (bay area) at 10:30 and left at 11:00. Then i made to my parents house in terra Bella at 3:00 am. With a grand total of 8.5 hours of driving. This is also on top of all the driving I did today during my ten hour work day
i have a lot of work ahead of me.
i have found mixed info when it comes to the fuel delivery systems on explorers. the year of my expo is 99 i found that some people have return less and return systems. this turned in to an issue for me because my motor has a return less system. in order for me to run my b 2 tank i need a return style system. i could mount the expo tank like a aux tank and get by or just wait and find a return style fuel rail. but i think this will exempt me from having a ca legal swap. im leaning towards swapping the tank.
time for a cage, i had the interior striped in less then 3 hours. thank god for 1/4 impacts
dash on top, interior harness on the right, engine bay harness on left.
i need two tubes on the sender.
Old 04-07-2013, 11:46 PM   #67 (permalink)
Member # 124782
had a long and productive day. im am going to make this swap happen. motor, trans, expo fuel and brake line are in. tomorrow the plan is to get all the plumbing, wiring done. i hope to hav the truck running tomorrow afternoon.
ohv is out
sohc is in
separated the the cab from the fram to gain better access to everything.
then we removed the cab from the frame
what i get to deal with tomorrow. there is a method to the madness.
the motor is plumb, wired, and running like a raped ape. another thing i have not had ac since i did my last motor swap. well i swapped over the cold blowing ac from the expo. i will also have cold blowing ac for the rear seats to.
my temporary fuel tank set up.
running vid VVVV
Old 04-08-2013, 11:04 PM   #68 (permalink)
Member # 124782
i was able to get the truck running and driving like a champ. tomorrow will be the real test when i have to drive 6 hours and 300 + miles.
Old 04-18-2013, 08:37 AM   #69 (permalink)
Member # 95468
Sweet low budget build, one question tho... did you make it back??
If you can't fix it with a hammer... it must be an electrical problem.
Beat it till it works or beat it till it squirts!
oldblue05 is offline   Reply With Quote
Old 04-18-2013, 11:31 PM   #70 (permalink)
Member # 124782
^^^^ hahah thanks, its funny that you say that.
my week of having a shoc 4.0.
last tuesday i drove my truck back to chico and delivered my old ohv 4.0 to sac. then on firday night i headed back to porterville to clean up my mess. then on saturday i delivered the expo axle and picked up parts from down in ranch cucamonga, then on sunday i headed back to chico. so after 1200 miles i have no issues to report on.
soon i will have pics of the latest parts.
Old 04-19-2013, 10:43 PM   #71 (permalink)
Member # 124782
race car parts. that i been hording. i have a set of 2.5 x 12" saws that im waiting for as well.
new bed sides that i worked an interesting deal to get.
wheels covered
sucession of bed sides
Old 04-22-2013, 07:37 AM   #72 (permalink)
Member # 95468
Damn, not sure if the pic is showing it right but you might want to get some more lug nuts b4 you get anymore body panels, just my .02
Old 05-28-2013, 03:07 AM   #73 (permalink)
Member # 128169
Dude its low budget... Plus I see 4?
2007 Dodge Ram 2500 CTD (Tow Rig/Prerunner) Carli Suspension
2004 Jeep Wrangler TJ
BACRAKR is offline   Reply With Quote
Old 06-02-2013, 10:25 PM   #74 (permalink)
Member # 124782
^^ there are 4 missing. im gettin they all replaced the next time i get the tires rotated.
did some work over the last week.
made support perches for my swing outs.
c notch frame plate welded in.
painted up the swing outs and installed my 6" bed sides. stickers will come off in a day or two. i wanted to wait on installing the bed sides untill i got a new bed with a tail gate. wife was getting tired of looking at them, plus i had to make room in my one bed apartment.
Old 06-02-2013, 10:37 PM   #75 (permalink)
Member # 124782
soon
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
