Philofab's 1993 Bronco AKA "Lucky Bronco #3" - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 04-01-2012, 05:53 PM   #26 (permalink)
Member # 100288
Just measured travel on the drivers side.... 17". Looks like I will need to clearance the frame a little just behind the steering box at the top. The coil just barely kisses it at full shock extension. I have not drooped both sides yet to see if the u-joint gets angry. I have my up travel limited on both sides to save the A/C box, stop excessive negative camber on the passenger side, and give the ECM some clearance. I also found the nut for the upper left (driver) side radius arm bolt has come loose from the beams so next time I have it apart it will need to be welded back in.
Mohave Battery
UHaul Dealer, Optima, Odyssey, Amsoil, LucasOil, Swepco, Deka, Exide, Method Wheels.
philofab is offline   Reply With Quote
Old 04-02-2012, 03:03 PM   #27 (permalink)
Member # 100288
Built a cross bar... still need to cut it and install tube disconnects. Also picked up some brake stuff...
Mohave Battery
Old 04-02-2012, 05:30 PM   #28 (permalink)
Member # 100288
Started on the brake lines. 10" -3 hoses in four places. The rest will be hard line. I should be able to carry one 10" -3 hose and a -3 cap for spares. If I can't repair it with a new hose I can just cap the wheel and still have three brakes that work.
Mohave Battery
Old 04-03-2012, 12:46 PM   #29 (permalink)
Member # 100288
Got a little more done...
Mohave Battery
Old 04-06-2012, 11:51 AM   #30 (permalink)
Member # 100288
Installed the Motorola radio from Tony. We'll see how it works this weekend in Plaster City.
Also got the front end far enough to be useable. Still need to do straps and rebuild the shocks. I may have to change a coil out to get it a little lower too. May try a 14x300 on top instead of the 350 that on there.
Steering and widening the front are next on the list. I still need to gusset the engine cage and install tube disconnects on the cross bar.
Mohave Battery
Old 04-06-2012, 01:17 PM   #31 (permalink)
Member # 100288
Finally replaced the motor mounts with the fabricated units...
Mohave Battery
Old 04-08-2012, 10:00 PM   #32 (permalink)
Member # 204828
I'm liking where this rig is going. Sorry if you have already said but what axle shafts are you using for the front ttb? Stock or custom made?
Check out my videos of 4 wheelin, car audio, and random by looking for tom58c on youtube.
tom58c is offline   Reply With Quote
Old 04-09-2012, 09:33 AM   #33 (permalink)
Member # 100288
After I widen it they will need to be custom. They will be Yukon blanks machined by Dutchman most likely.
Mohave Battery
Old 04-13-2012, 08:48 AM   #34 (permalink)
Member # 100288
Got some more parts for the upcoming DDL install.
Mohave Battery
Old 04-13-2012, 09:05 AM   #35 (permalink)
KyleQ's Avatar
Member # 83837
Did those mounts raise up the motor at all?
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers
Bronco Build Thread
KyleQ is offline   Reply With Quote
Old 04-13-2012, 09:15 AM   #36 (permalink)
Member # 100288
Not that I noticed, but others have told me they do a little bit, maybe .500?
Mohave Battery
Old 04-14-2012, 09:11 PM   #37 (permalink)
International Dan
binderbound's Avatar
Member # 18592
Send a message via AIM to binderbound
I dig those 3 bolt flange plates on your shock mounts. Where did you get those?
Sweet build
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html
facebook.com/hardenedways
Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you.
binderbound is offline   Reply With Quote
Old 04-14-2012, 09:19 PM   #38 (permalink)
Member # 100288
Sweet build
Those are the mount plates that Giant uses. Anyone can cut something like them that has access to a CNC table.
Mohave Battery
Old 04-18-2012, 07:40 PM   #39 (permalink)
Member # 112397
Nice build. I think I ran into you in Baja, at the DA pit in borrego.
Keep up the good work.
-John
azcagiva is offline   Reply With Quote
Old 04-18-2012, 09:18 PM   #40 (permalink)
Member # 100288
-John
For the 1000? I was there. The trucks came in about every two hours so if I met you after nightfall or in the morning I apologize if I was loopy. Didn't sleep much!
Mohave Battery
Old 04-19-2012, 11:05 PM   #41 (permalink)
Member # 112397
Yeah for the last 1000. You were talking with a guy that had a real clean 80's ish ford truck. I stayed there helping out till the last DA truck came through.
-John
Old 04-20-2012, 11:30 AM   #42 (permalink)
Member # 100288
-John
Oh yea, that was Tom with the BajaF250. He was camped about 5 miles from us with all the other Bronco nuts.
You probably saw me run. That doesn't happen often.
Mohave Battery
Old 04-20-2012, 03:08 PM   #43 (permalink)
Member # 100288
Thanks Shockseals.com!
Mohave Battery
Old 01-03-2013, 03:03 PM   #44 (permalink)
Member # 165893
The ring and pinion only last about a year, and I've gone through 3 or 4 sets of the wheel bearings. At first I was bending the backing plates but that stopped once I went to the Currie retainers. The bearings just can't handle the 127# wheels and tires.
I broke the case once but no problems since upgrading to a Yukon nodular third.
go to 10"(9 3/4') r&p 40spline axles and set 80 bearings problem solved for about 2k
jpizol is offline   Reply With Quote
