'79 Chevy PreRunner/Trail Build/Help - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 10-19-2006, 09:47 PM   #1 (permalink)
Member # 54046
Send a message via AIM to BigF250on44s
Ok so here is the truck that I'll be working on. Its a '79 Chevy Reg Cab Short Bed. Its has a built 454 BBC and a built TH400 in it. The front axle is a D60 along with the rear axle. The 39.5s that are on it currently I just sold and picked up some 38" Parnelli Jones Dirt Grips.
I'll get to the pics and then post the plans.
Plans for now:
56" Long 4" Front Springs
63" Long 3" Rear Springs
Dual Shocks Up Front
Dual Shocks Out back
Front Fiberglass
Rear Bedsides
32 gallon fuel cell
I figured that would be a good basis for me to has as a daily driver and do some trails and fun running in the dunes.
When I get out of basic training I'll be sending the truck to Blitzkrieg Motorsports. When it gets to them I'm going to have them install their front kit and 4-link the rear. Also, at that time I'll be installing a 572 fuel injected BBC and a rebuilt full manual reverse TH400. Also, I'll be getting a 9" rear end.
The truck is a daily/trail/prerunner truck. I'm going to be driving this truck daily but still want to be able to go out and have some fun.
Let me know what you guys think and what tips you have for me?
'79 K10: 700whp 454, Built TH400, NP200, 2.5 Ton Rocks w/ USA6X6 2.5 Ton Brakes, 1 Ton MC/Booster, Driveline E-Brakes, Hydro-Assist High-Steer, 47" LTBs or 44" Boggers
BigF250on44s is offline   Reply With Quote
Old 10-20-2006, 01:16 AM   #2 (permalink)
fabtoys's Avatar
Member # 19760
Indiana is a long way from the desert!
first leaf springs are great with deavers you can get a lot of travel.
when you build a desert truck its hard to make it a rockcrawler at same time .
When you build a desert truck you going to want to build the suspension for 30%droop and 70% bump. with the chevy chassis you want to have long shackles for more travel out of rear .goto racedezert.com and find a lot of info there
IF ITS SMOOTH YOUR AIRBORNE!
FABRICATION REQUIRED TRANSPORT 925-382-1058
89 broncobuggy d60 42 tsl
LEMON RACECAR www.24hoursoflemons.com
www.norcalprerunners.com
fabtoys is offline   Reply With Quote
Old 10-20-2006, 07:10 AM   #3 (permalink)
Member # 48716
Send a message via AIM to VerticalTRX
A 572 will be way to heavy on the front end for what you seem to want. Put the money that you'd spend on a 572 and drop it into a stroked, forced induction small block and you'll be much happier.
Kickin' it old school: '79 Ford, Q78 TSLs and a Q-jet
VerticalTRX is offline   Reply With Quote
Old 10-20-2006, 09:59 AM   #4 (permalink)
Member # 54046
why would I want to do that? The truck is already setup for a BBC and I get a discount on all GM Crate engines. The front end won't be too heavy.
I know what it takes to build a dezert truck. This isn't the first one I've done/helped with. This IS the first solid axle one though. I've got most of the info I need on how to do it.
Old 10-20-2006, 12:54 PM   #5 (permalink)
Member # 51634
Those are some mighty big tires for a pre-runner. Dune runner? maybe. I live in the socal desert and we sure don't build them like that here. But hey, whatever floats your boat.
savageracing is offline   Reply With Quote
Old 10-20-2006, 01:20 PM   #6 (permalink)
Member # 54046
the tires that are on it now are sold. I'm just waiting for the guy to come get them. The 38" PJs that I had ordered were back ordered for 2 months so I cancelled and just picked up 6 37" BFG ATs. I know those aren't to big because i know quite a few people run those.
Old 10-20-2006, 01:49 PM   #7 (permalink)
CORNFED's Avatar
Member # 2557
If you can get gm parts deals why not go with an ls-7 motor? Way less frontend weight to make up for and 500 horse stock.
Team Tetanus Racing
http://community.webshots.com/user/cornfed102
70 1 ton suburban - whats left at least
CORNFED is offline   Reply With Quote
Old 10-20-2006, 03:35 PM   #8 (permalink)
Member # 51634
I think you'll be happier with the 37" AT's. They are alot closer to a true prerunner tire. I'm with the rest of the guys with the big block as well. If you plan on making this truck fly then the big block will make it way nose heavy, unless you want to cut the firewall and drop the motor back 8 inches or so but the cab on that truck is not that big. go with a small block, 383, LS7, ramjet 350, something lighter and it will be better balanced.
Old 10-20-2006, 03:58 PM   #9 (permalink)
Member # 54046
I just have always liked my BBCs and have always been acustomed to the sayin "no replacement for displacement."
I'll look into the LS7 though.
Old 10-21-2006, 05:24 PM   #10 (permalink)
Banned
Member # 68715
Silver lake is about 5 hours from me............ cant wait to see some progress.
This is a good forum section.....ah desert and sand
strokeddodge is offline   Reply With Quote
