#2 (permalink) | |
Member # 11801
But at about 275 -300 they start to fade
Shaffer's Offroad & Performance Phone (510)999-7766 1924 Willow St Alameda CA 94501 [url]www.Transfercaseexpress.com[/url] [url]www.Shaffersoffroad.com[/url] [url]www.Torchmateracing.com[/url] [url]www.Twitter.com/shaffersoffroad[/url] [url]www.Torchmate.com[/url] [url]www.Powertank.com[/url] |
#3 (permalink) | |
Member # 22641
Do the seals hold up okay at those temperatures? And, do external bypass cylinder oil coolers help? |
Member # 8286
Mr Shaffer.
Where (on the shock) and how are you measuring those temps? *and what shocks? Brand, Size, Style Thanks
-Ryan Last edited by TRD; 10-22-2006 at 01:27 PM. |
fishingwithdynamite
Member # 30721
There was a good discussion about this over on RDC a while ago. Here's a link.
#6 (permalink) | |
Member # 22176
Mike, Are you using temp strips or something more sophisticated to determine the temp of the shock? Also Where on the shock are you recording temps?
I can break a steel ball in a rubber room! |
#10 (permalink) | |
Member # 2457
ShaffersOffroad.com (510)533-5202 Shaffer-Motorsports.com Torchmate.com Torchmateracing.com |
Member # 22176
Thanks. What brand of shocks are you running? According to the post on rdc the heat gun may not work well with Bilsteins or newer SAW. I always use temp strips because that's what I have access to. I do not like the fact that they only show peak temp. I will be adding realtime data logging to a truck at work for this very reason.
You may want to have your guy check them near the rodguide as that seems to be the hottest part when we are durability testing shocks.
#12 (permalink) |
Member # 22641
Heat strips sound like a good choice, but Max. Temp. only measurements. The reason I asked is that I had one shock that I rebuilt that showed evidence of a hot spot: about 1/4" Dia. area of the brass rod bearing was melted. Brass melts at almost 1700 F. The shaft and seals were okay, so the hot spot must have been confined to a local spot only. It looked like the heat was trapped and couldn't dissipate to the outside. I plan to machine cooling fins into the housing that holds the brass bearing.
#13 (permalink) | |
Member # 2457
#14 (permalink) |
Member # 68824
There's no way a shock got even remotely close to 1000, not to mention 1700 degrees. It was warped/damaged because the temp was increased and there was rubbing.
Another thing, reservoirs are not intended to cool the shocks down. You rockcrawler guys should stick to the rocks and leave the highspeed man stuff to us. When you guys are grown up enough, come on over to www.dezertrangers.com |
#15 (permalink) | |
fishingwithdynamite
Member # 30721
#17 (permalink) | |
Member # 5639
Just Add Lightness I'd rather be simple-and-wrong than complicated-and-wrong. |
#19 (permalink) |
fishingwithdynamite
Member # 30721
Most shocks would shit their pants when the temperature gets up past 400 to 500-degrees and reservoirs have a dividing piston in them to keep the shock fluid from mixing with the nitrogen, not to keep the shock cool.
#20 (permalink) | |
Member # 2457
#21 (permalink) | |
Administrator
#22 (permalink) | |
Member # 81128
Typical Dezert Ranger "Flatbiller" playground smack. DGAF except to talk crap. |
#23 (permalink) | |
Member # 5639
Why not put the piston in the shock? Moving it to a reaservoir does what, increases the oil capacity of the shocks?
#24 (permalink) |
Member # 32726
It seems that the extra oil capacity would, in the end make a cooler shock. however i don't know shiat, but just throwing that out there.
5/8 Yotabuggy - duals + 4.7, 5.29's, locked, 40's, linked rear/fox airs, shift knob ΜΟΛΩΝ ΛΑΒΕ |
#25 (permalink) |
fishingwithdynamite
Member # 30721
Sometimes they do put the dividing piston inside the shock. That's called an internal reservoir as opposed to an external reservoir. The biggest difference is that if the shock is using an internal reservoir, the eye-to-eye dimensions of the shock must be longer.
