Equal vs. Unequal Length Arms - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 10-26-2006, 07:03 PM   #1 (permalink)
Mom Says I'm Special
Fawk Awph's Avatar
Member # 26857
Send a message via MSN to Fawk Awph
since this forum has come about Ive been looking at cheap builds on other forums, mostly rangers. and some guys run unequal length front swing arms or beams, or whatever they call them. how and why is this desirable? to me i would build each arm cantilevering from as far across the frame as possible to alleviate so much camber change throughout suspension cycle.
i have an idea of how i would build a swing arm suspension, and i have not seen it done yet, more than likely because it cant be executed strong enough.
Callen
ECV 7-11
Fawk Awph is offline   Reply With Quote
Old 10-26-2006, 08:17 PM   #2 (permalink)
Member # 43562
Filarski Bros
GoodTimes is offline   Reply With Quote
Old 10-26-2006, 08:44 PM   #3 (permalink)
TRD
TRD's Avatar
Member # 8286
There are companies that make equal length beams
Giant Motorsports is one of them.
The reason most people have unequal length is because that is how they come from the factory (Rangers and F-150/250 's)
Equal length beams cost about $5k because you need the custom beams and the custom steering. Check out Giant Motorsports website to see what I am talking about.
Most people are able to get away with different length beams which cost about $1800 and do not require a serious change in steering.
I'm new to the whole beam thing but I did a lot of research on it last month. Some of the desert racers might have more comments.
-Ryan
TRD is offline   Reply With Quote
Old 10-26-2006, 09:25 PM   #4 (permalink)
Fawk Awph's Avatar
Member # 26857
oh, i didnt realize (ive never actually looked at a factory TTB or whatever, all this is in my head) that the beams were of unequal length from factory. it seems to me that you could make a swing arm that held its camber withing a degree or two jsut as easily as you could design a rear 4 link. i dont have any programs to explain myself better. ill see what i can muster up on Paint here in a min.
Callen
ECV 7-11
Old 10-27-2006, 01:51 AM   #5 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Callen
When you say "swing arm" are you talking about an A-arm suspension rather than beams? I can't imagine you using beams and keeping camber within a degree with any travel. The reason beams are popular are because 1, they're easier (sans the steering part) and 2, more travel. To get mass travel out of A arms you have to center mount them or have a stupid wide trackwidth.
Plus beams just look cooler.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is online now   Reply With Quote
Old 10-27-2006, 09:40 AM   #6 (permalink)
Fawk Awph's Avatar
Member # 26857
i was talking beams, but none the less how does having unequal lenth beams actually work?
Callen
ECV 7-11
Old 10-27-2006, 10:54 AM   #7 (permalink)
Member # 9666
unequal = stock pivot points/ beams are extended
equal = pivot changed/ custom beams
notice the difference
Honestly I cant tell the difference in the two ride wise w/ coilovers...but hey Im a Ford arm guy
77Blaza is offline   Reply With Quote
Old 10-27-2006, 11:18 AM   #8 (permalink)
Member # 43413
Send a message via Skype™ to BHTool
un = length beams came about in the early 80's when ford switched from = length king pin to un = length king pin then to un = lenghth balljoint beams.
the theory behind it is that one beam pivots infront of the other but the radius arms pivot in the same spot (opposite eachother). if you draw a triangle from spindle to rad arm pivot to beam pivot for drivers and pass side un = length setups triangles intercet in the center of the truck where as = length setups intercet of to the side of the center. somehow ford deturmened that un = length setups handeled beter for street driving, thus the change
hope that makes sence
BHTool is offline   Reply With Quote
Old 10-27-2006, 09:06 PM   #9 (permalink)
Moderhater
Halogrinder's Avatar
Member # 16980
fuck no that didnt make any sense!
Im your BMW huckleberry
https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car!
gun facts that will blow your mind:
http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf
Halogrinder is offline   Reply With Quote
Old 10-27-2006, 09:25 PM   #10 (permalink)
Fawk Awph's Avatar
Member # 26857
haha, someone had to say it. maybe ill back through it and take out all symbols and replace them with words.
Callen
ECV 7-11
Old 10-27-2006, 09:57 PM   #11 (permalink)
Moderhater
Member # 16980
i was talking about this clusterfawk
Old 10-27-2006, 10:14 PM   #12 (permalink)
TRD
TRD's Avatar
Member # 8286
I think I got it
He is saying the roll axis is off center with equal length beams. And that ford switched to unequal length beams to make the roll axis centered.
-Ryan
Old 10-27-2006, 10:31 PM   #13 (permalink)
Fawk Awph's Avatar
Member # 26857
unequal length beams came about in the early 80's when ford switched from equal length king pin style beams to unequal length king pin style, and then to unequal length ball joint beams.
the theory behind it is that one beam pivots in front of the other but the radius arms pivot in the same spot (opposite each other).
if you draw a triangle from spindle to radius arm pivot to beam pivot for drivers and pass side unequal length setups triangles intercept in the center of the truck where as equal length setups intercept off to the side of the center. somehow ford determined that unequal length setups handled better for street driving, thus the change
hope that makes sense
so was i
i understand what hes saying though. i tried to do a rough sketch in paint.
Callen
ECV 7-11
Old 10-27-2006, 10:37 PM   #14 (permalink)
TRD
TRD's Avatar
Member # 8286
Here is another pic
Top view of suspension:
-Ryan
Old 10-27-2006, 11:26 PM   #15 (permalink)
Fawk Awph's Avatar
Member # 26857
Originally Posted by TRD
Here is another pic
how is that correct? that shows the beams being the same length, but not lining up in the center. is that to show how the center would be off if both beams were the same length and why for went with the unequal length beams?
Hell, you need to get some paint skilz, all that fancy shits killin me. ha.
Callen
ECV 7-11
Old 10-28-2006, 07:22 AM   #16 (permalink)
TRD
TRD's Avatar
Member # 8286
That is to show equal length beams do not have the roll center in the middle of the vehicle.
And if you imagine the left beam getting shorter you will see that changes the roll center to the middle of the vehicle.
-Ryan
Old 10-28-2006, 10:26 AM   #17 (permalink)
fishingwithdynamite
Member # 30721
There's some good information on this topic in THIS DISCUSSION on desertrides.com.
GatosBros · Crux Studio · Trails Less Traveled
JESSE_at_TLT is offline   Reply With Quote
Old 10-28-2006, 10:29 AM   #18 (permalink)
fishingwithdynamite
Member # 30721
Here's ANOTHER ONE (there's also some good including about Radius arm mounting points in there).
Old 10-28-2006, 03:11 PM   #19 (permalink)
Member # 56400
Callen[/QUOTE]
I know this is a rough sketch, but you really don't plan on having the beams cross like this do you? Just a thought, but there may be a bit of an interferance problem.
Anyone can say something won't work......The challenge is in figuring out a way to make it work!
Curious1 is offline   Reply With Quote
Old 10-29-2006, 05:47 PM   #20 (permalink)
Fawk Awph's Avatar
Member # 26857
how do you go about running equal length beams without crossing them? is just one (the rear beam) bent so the spindles end up in the same place?
in TRD's post is shows the spindle positions in different locations, is this difference compensated in the spindle or what?
Callen
ECV 7-11
Old 10-29-2006, 06:01 PM   #21 (permalink)
Member # 67473
this is probably wrong but maybe ford figured they could save money and get the same results with different lenght I-beam arms
chris walker is offline   Reply With Quote
Old 10-31-2006, 10:59 AM   #22 (permalink)
Member # 17610
....just subscribing to this thread
KK
www.crawlinaz.com/forum for AZ crawling and trail runs
85runnerAZ is offline   Reply With Quote
Old 10-31-2006, 04:54 PM   #23 (permalink)
Fawk Awph's Avatar
Member # 26857
found some pics on those links you gave me.
this is what i was wondering. it seems as though you mount the beam-ends in a different place than i was imagining.
these pics pretty much explain the differences pretty good.
EQUAL LENGTH BEAMS
UNEQUAL LENGTH BEAMS
Callen
ECV 7-11
