High Misalignment joints/TRE Help? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 12-23-2006, 07:38 AM   #1 (permalink)
Member # 39921
Send a message via Skype™ to BigSi D90
We are building a light weight tube frame buggy at the moment with 4 wheel independant suspension - which is why I figured here was the best place to ask!
I don't want to run heim or rose type joints as they don't last long in mud - and we have a lot of mud. I'm therefore looing for joints sutiable for the TRE's and ends of the wishbones which are sealed and have a fairly high misalignment capacity.
I need at least 30 degrees of misalignment, but 35 would be better. They don't need to be all that big as the all up weight will be under a ton.
Most people advise just going to a store and doing a load of box-opening to see what looks best, but the shop owners round here don't keep stock of things like that and wouldn't let you open boxes if they did!
What kind of off the shelf joints are commonly used, even better if I can get an equivalent in europe and what kind of misalignment can I expect?
The intention at the moment is to fabricate/mill the uprights - but again, if there is good off the shelf it might be worth a look!
Thanks in advance,
Si
BigSi D90 is offline   Reply With Quote
Old 12-23-2006, 10:12 AM   #2 (permalink)
Brutpwr's Avatar
Member # 481
I don't think you are going to find a ball joint that will swivel as far as you need if thats what you are thinking of using. You should look at the joints that Hendrix sells with his chassis link kit or something like what they use on the links for the late model Jeeps. If you use good quality heims wear should not be a big problem.
Jason
Brutpwr is offline   Reply With Quote
Old 12-23-2006, 04:49 PM   #3 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
would a teflon lined heim work? yea yea "no heims"
Nordic1 is offline   Reply With Quote
Old 12-23-2006, 08:20 PM   #4 (permalink)
sam-man's Avatar
Member # 28700
Call Kurt Youngs at KAR-TEK OFF ROAD. HE HAS WHAT YOU NEED. 951-737-2999
sam-man is offline   Reply With Quote
Old 12-23-2006, 08:40 PM   #5 (permalink)
65Chevy4x4's Avatar
Member # 37016
just get the rubber boots that cover the heim joitns and just grease them to keep the dirt out of it. Or run some 1ton ball joints or cone balljoints if you need more misalignment.
65Chevy4x4 is online now   Reply With Quote
Old 12-24-2006, 02:27 AM   #6 (permalink)
Member # 39921
Thanks for the contacts - I'll give them a go.
Teflon joints just don't seem to last and the rubber seals for rose joints generally seem to limt the movement too much.
A Land Rover TRE is almost there at 26 degrees & I hoped something - like jeep would have one a little wider.
Si
Old 12-24-2006, 10:46 AM   #7 (permalink)
Member # 5110
Solid axle GM trucks (from at least 69-91) had drag link ends that have a double spherical joint in them and get quite a bit of angularity. They have 7/8"-18 RH or LH threads. I don't know the actual measurement of the angle...but it is quite a bit because of how short the drag link is.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote
Old 12-26-2006, 04:45 AM   #8 (permalink)
Member # 39921
Thanks Triaged - that's the kind of thing!
I'll pop down the local GM dealer when the shops re-open after Xmas!
Si
Old 12-30-2006, 10:12 PM   #9 (permalink)
fishingwithdynamite
Member # 30721
Contact Sandy Cone at 805.239.2663 or try Troy Johnson at The Fab School.
GatosBros · Crux Studio · Trails Less Traveled
JESSE_at_TLT is online now   Reply With Quote
Old 12-30-2006, 10:26 PM   #10 (permalink)
MudOnTheTireS10's Avatar
Member # 41474
Send a message via AIM to MudOnTheTireS10
DLEs have greater range than TREs, not sure if that helps much, but I know its the case with my 1 ton Chevy ends.
'97 S10: D44+Aussie/9"+Detroit | AMSOIL Dealer | <><
MudOnTheTireS10 is offline   Reply With Quote
Old 01-02-2007, 08:17 AM   #11 (permalink)
Member # 39921
As a follow-up, after a lot of box opening in my local store....
The DLE/TRE with the most movement that I can find in the UK is from GM/Vauxhall
Part number BA0804 or QR3167S
I've measured the offset at 37 degrees either side of central.
The thread on the taper is M12 x 1.5mm pitch and the thread on the shank is female M14 x 1.5mm pitch. Neither is particularly common - but available none the less.
This might be of use to someone else involved in a buildup.
Land Rover TRE's are about 26 degree and Suzuki Sidekick 33 degrees (which would have been OK, byt they are too small to use on wishbones)
Thanks for all your help!
Si
Old 01-02-2007, 11:21 AM   #12 (permalink)
Member # 41474
Good to know...wonder if those or a corresponding brand are sold in the States...
Old 01-02-2007, 06:56 PM   #13 (permalink)
Member # 41097
Check out www.evolutionmachine.com, they make some nasty big rebuildable.greaseable hiems and tre's that should meet your needs (btw they haven't had to replace a broken hiems yet )
mustange70 is offline   Reply With Quote
