a kid who needs help with a baja rear end - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 01-31-2007, 09:45 PM   #1 (permalink)
Member # 40247
ok..i have a 69 vw bug that i am bajaing and i have the irs rear end...and i need to now the best way to lift the rear end with out messing anything up..so plz..if you can help me..plz do..thnx..
tugtug is offline   Reply With Quote
Old 01-31-2007, 11:30 PM   #2 (permalink)
No comment
camo's Avatar
Member # 4
Send a message via Yahoo to camo
with the IRS you adjust ride height by clocking the torsion bars and spring plate. as far as "messing things up " raising ride height will require you to compensate for new angles that will effect everything from your center of gravity to your axle and cv joint operating angles. one thing always leads to another. I suggest you reserch the topic until you understand everything going on with the suspension. there are many degrees of aftermarket parts available to upgrade your suspension from mild to wild. just reclocking your stock parts is not going to net you much gain.
camo is online now   Reply With Quote
Old 02-01-2007, 12:38 AM   #3 (permalink)
Adnimistrator
FatCity's Avatar
Member # 2870
This book will tell you every thing you need to know, as long as you just want to beat up a Baja and have the time of your life. If you want to suck all the fun out of it, then research it like camo said. (I'm all about the book)
http://www.amazon.com/Baja-Bugs-Bugg.../dp/0895861860
FatCity Off-Road Racing
FatCity is offline   Reply With Quote
Old 02-01-2007, 03:12 AM   #4 (permalink)
No comment
camo's Avatar
Member # 4
does that count as "messing everythig up" ?
Old 02-01-2007, 07:02 AM   #5 (permalink)
Member # 43562
They rock race too. Those jeeps had nothing on a Baja.
Filarski Bros
GoodTimes is offline   Reply With Quote
Old 02-01-2007, 09:18 PM   #6 (permalink)
Member # 40247
holy shit...that looks like fun..im really wanting to to baja mine out..im cutting everything to morrow with the plazma...i hope i cut the right shit..becouse i really have no idea wut im doing....and im taking it the me using a used baja kit for my first is a bad idea..becouse i have no sementions........well thnx guys....if i have any questions, im going to ask..and i will have them..so be ready...thnx..
Old 02-02-2007, 10:57 AM   #7 (permalink)
onetoncv's Avatar
Member # 2160
If you find your self later on needing more angle then the bus or bug c/v's will allow we are making new axles for these- they get allot of angle and work well- Jess
http://highangledriveline.com
Bringing Innovation to the market !
http://highangledriveline.com/HAD1.gif
530-877-2875
onetoncv is offline   Reply With Quote
Old 02-02-2007, 06:44 PM   #8 (permalink)
b2dude's Avatar
Member # 16270
Send a message via AIM to b2dude
where is that buggy from? got a full pic of it?
b2dude is offline   Reply With Quote
Old 02-08-2007, 06:45 PM   #9 (permalink)
Member # 40247
ok..if i put air shocks or coil overs..will they give me the hight to clear 31's..i really want to a all out bad ass desert racing baja bug...and i want it to be clen and cheap...so when i beat the shit out of it..i wont be giving an arm and a leg to fix it..do any of you have any suggestions on what i should do?
Old 02-08-2007, 07:03 PM   #10 (permalink)
Adnimistrator
FatCity's Avatar
Member # 2870
Originally Posted by tugtug View Post
..i really want to do an all out bad ass desert racing baja bug...and i want it to be clean and cheap
S-can that idea, and dont abuse the smilies
