Member # 22176
Ford 8.8 rearend Durability and Strength
So we are playing with a 1996 Ford F-150 4WD. It is designed to spend most of its life in the desert playing with suspension components. It is not (as of yet) a hardcore prerunner, but it will see some whoops, jumping and general tomfoolery.
It may be time to get gears as the truck is incredibly slow currently. How strong is the 8.8 that is in it? I am more worried about bending than I am it failing due to horsepower. Will I be able to utilize this axle for a year or two, or do I need to find a 9" before I spend any energy upgrading the 8.8 on this thing? Thoughts?
I can break a steel ball in a rubber room! |
Member # 21914
They have been succesfully run for many years in Stock Full - add a truss and 9" housing ends(Drew/Goat1 or Currie Ent.); spool or Detroit Locker (Reider Racing
); Good gears (Precision Gear ); and Uber Cool Custom axles (Alloy USA ) and you're good to go!!And I might know a guy who knows a guy who met a stripper who's old roomate used to race and met a guy that could help you with all that.
#3 (permalink) | |
Member # 8286
Is his name Ron
-Ryan |
#4 (permalink) | ||
Member # 22176
parts before I looked for them. No sense in investing energy and resources into the housing if it was going to be substandard when completed.I will discuss with Drew B this weekend at the Hammers. Quote:
#5 (permalink) | |
Member # 21914
I bet we could turn that beauty into one of these Of course a different shock co. hood decal
Member # 22176
I like it. The color even works for me.
We will be putting seats, harnesses and a cage in it shortly. I still think it would need more than that to get where yours was.
Member # 22176
Question,
What is the reason for changing the housing ends? I notice that parts are available for these in 28, 31 and 33 spline. I am assuming the truck uses 31 spline stock. It the different end to fit the larger shaft or is the factory 8.8 bearing crappy?
#8 (permalink) | ||
Member # 21914
I doubt you will ever break one - but with your driving history you may bend one JK Quote:
It's because the 8.8 is a c-clip axle. Reason there are so many c-clip eliminator kits--aka big bearing 9" housing ends--is because nhra rules don't allow cars running faster than 10.99 to have c-clip rearends. As you know, break a c clip axle--lose your tire. Plus, there are more choices for everything 9".
In vino veritas 70 turbocharged 351w fastback mustang 73 linked 5.8efi Bronco 99 QCLB 4x4 twin'd cummins on meth. Last edited by braxton357; 02-14-2007 at 12:17 PM. |
#11 (permalink) | |
Member # 33830
#13 (permalink) | |
Member # 21914
We do make a semi-top secret full size version of the Grande 88 Kit for the F-150's...limited quantities
#15 (permalink) |
Member # 26910
I'd be interested in the Grande 88 kit for the 150.
I talked to "another company" about there Super88 and they said they had no plans to make a full width 88 kit
'99 Explorer - Full Width 44/8.8 on 37's '05 F150 Super Crew- Tow Rig |
#16 (permalink) |
Member # 3775
I forgot to give it to TuRD, but I've got a couple stock 9" third members you can have, if you decide to go 9"... I've got a feeling you will.
I wheeled twice this year, that might be a personal record. |
#17 (permalink) |
Member # 8286
Oh and to answer the 8.8 question.
I spun the tubes in the center section and broke the yoke. And I didnt even go too big! I found a new reason to build a 4x4 pre-runner. 50% more chance of being able to drive it home! ps. Thanks for the help Jeff! Pss. DILLIGAF!
-Ryan Last edited by TRD; 02-18-2007 at 08:36 PM. |
#18 (permalink) |
Member # 22176
Yes, so our 8.8 is dead. We are looking to replace it with a 9".
I can break a steel ball in a rubber room! Last edited by Beat95YJ; 02-19-2007 at 03:02 PM. |
#21 (permalink) |
Member # 22176
Well it is here and on the rack. Both tubes are twisted, the drivers side is coming out and the thing is rather v shaped.
I am doing some on-line investigating, and the F-150 had a 9" from 78-86. Is any of these years more or less desireable? I have read that there is early and late big bearing. Does this matter? I know a little about 10 and 12 bolts, a little more about 60's and a bit about 44's. 9" are all new to me. I have heard that the trucks always have the nodular center, true/not true?
#23 (permalink) | |
Member # 56400
(I couldn't help it, it was there!)Your friends Jessie and Ian did a show all about different rearends this weekend. If only you would have seen that, you would know everything! BTW, any pics of the speed bump TuRD hit to break that thing? And tell us the truth was it just driver error?!
Anyone can say something won't work......The challenge is in figuring out a way to make it work! |
#25 (permalink) |
107
Member # 39660
i heard he was trying to brakestand in front of the highschool when it happened...
Big Boned Toyota Build The collective writing skills of the PBB is equivalent to a blind down syndrome-afflicted monkey with no hands and epilepsy. |
