suspension question - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 02-19-2007, 05:54 AM   #1 (permalink)
Member # 86620
Send a message via AIM to chevymudtruck
suspension question
well I'm not building a desert truck but want a long travel suspension . . . and seen something that interested me before but haven't found it again . . . a system for the rear that had the coil over shock and spring mounted sideways and had a pivot point with a bar running down to the rear end .. . where u could get leverage and use a shorter shock to get the same amount of travel. . . has anyone seen this anywhere is am i jut crazy
chevymudtruck is offline   Reply With Quote
Old 02-19-2007, 12:49 PM   #2 (permalink)
ShaggyDoo's Avatar
Member # 41776
Your not crazy. It's called a canti-lever.
[URL=http://www.polyperformance.com]POLY PERFORMANCE---------------> We Got What You Need![/URL]
[SIZE="4"][FONT="Impact"](805) 783-2060[/FONT][/SIZE]
ShaggyDoo is offline   Reply With Quote
Old 02-19-2007, 04:49 PM   #3 (permalink)
Member # 44438
We have been running it on our rockcrawler for about 2 years and love it. You can take a look at www.teamsharkattack.com.
billforce is offline   Reply With Quote
Old 02-20-2007, 05:44 AM   #4 (permalink)
Member # 86620
sweet . . . works good? . . also noticed ur specs say u have 14 inch king coils . . how much rear suspension travel ya getting? and did you have to run a stiffer shock setup and higher spring rate with the setup?
Old 02-20-2007, 06:01 AM   #5 (permalink)
wheiler007's Avatar
Member # 83897
Would you mind posting more pics and specs on that suspension. Thanks
Neil
Beat 95 K1500 - DD
New Rig: 79 K10 350-350-203-44/12
MTU 4 Wheelers - [url]www.mtu4wheelers.powweb.com[/url]
wheiler007 is offline   Reply With Quote
Old 02-20-2007, 05:30 PM   #6 (permalink)
Member # 44438
We have about 23" of travel before the diveline bottoms out. for the spring rate yes. 250 over 350 with a 90 helper. We could go to a 12" coilover and it would have the same travel, but we had the 14" kings all ready. For pics I will try to post some over on the team forum for you guys.
bill
Old 02-20-2007, 06:43 PM   #7 (permalink)
Member # 87150
As long as we're on the subject, all my suspension knowledge comes from racing mountain bikes, and the frame companies I worked with were always trying to get as low a ratio as possible. They did it to make the shocks last longer, is there a duribilty issue when you try to get 23" of travel from a 14" shock or is it a non-issue with truck suspension?
[QUOTE=Dieselmh;11422920]This thread is like McDonalds. It fucking sucks and doesn't deliver. :([/QUOTE]
maxyedor is offline   Reply With Quote
Old 02-20-2007, 08:23 PM   #8 (permalink)
Member # 41306
For off road, 2:1 is fine, 3:1 or more is undesirable. 1:1 is not uncommon, but it limits travel to shock length, and it causes very high shaft speeds.
chevymudtruck, if you search dezertrangers.com, you will find a lot of info on those setups. There are full blown designs like the Baldwin TT, to simple under bed shocks on a bell crank.
Scott F is offline   Reply With Quote
Old 02-20-2007, 10:54 PM   #9 (permalink)
Member # 87150
Makes sense, on bikes it works about the same way, 3:1= a blown shock 2.5:1 is pretty common and a few companies are just starting to look at 2:1 and 1:1
