Member # 71185
Planning build, need advice.
Ok I'm in the planning stages of my (re)build and could use some advice from the go fast guys.
The plan, take my 74 bronco and make it work really good at the dunes and still be decent for trails and not be to scary on the road. My plans, build new cage, bumpers, lighten up as much as possible 3 link w/panrod in front, coilovers and air bumps triangulated 4 link in rear, coilovers and air bumps stretch wheelbase as much as practical, 2"-3" front, 5"-6" rear, approx 100" overall What amount of travel should I shoot for in the front? Is 14"-16" realistic? I understand that rear travel should be 25% to 50% more then front, I take it getting the front setup first is the best way to go about it. Am I better off building it with less travel and spending more time with the valving? Quality better then quantity? What kind of numbers should I be trying to achive with the suspension? anti-squat, instent center, etc. Lots of info for crawling out there, not so much for gofast and jumping. What kind of weight distobution should I be shooting for? 50/50? 60/40? Where does it start to get ugly? How do you choose air bump travel? Is it a % based off of wheel travel? Sorry for all the questions but I'm trying to build this for the last time, I built this up the first time in the early 90's and it works OK but there is a lot of room for improvement. Brewchief Last edited by brewchief; 03-17-2008 at 04:53 PM. |
#2 (permalink) | |
Member # 15404
I know where to find some of the info you are looking for... I have been looking for it myself...
From this thread: http://www.race-dezert.com/forum/sho...t=33128&page=4 Post #35 TeenyCar does a great job of summing some things up but the whole thread is good! I tried to get someone to go a little deeper into how to estimate a good height for the roll center but no one has responded yet... Quote:
Life begins where the pavement ends! |
14" is about the most youll be able to get with traditional steering.
are you planning on 1:1 motion on the rear? bumps should be for heavy bottoming out. for reference JRs bumps are destroked to 2" check this video out ... if youll notice the suspension shot he not on the bumps hardly at all. http://youtube.com/watch?v=7WdhXlLCFgY
going back to the basics simple and easy tacoma 3-link setup WANTED - 2x12" FOX coilovers We are all born Arminians. It is grace that turns us into Calvinists -George Whitefield |
#4 (permalink) | ||
Member # 71185
Brewchief
Member # 5110
For the rear links you need to be about 1/2" below the centerline. You can do more but the links get very complicated become and rock magnets...which is one reason I'm not a big fan of the standard "bent tube sand canoe" links on most trucks. Attached is one that I designed. 1" sphericals at both ends and the shocks are both 1/2" below centerline. The giant cut-out for the shocks was so that standard rod-ends could be used. You can make the cut-out smaller if you use +2" or +3" rod-ends on the shocks.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893 Last edited by Triaged; 03-18-2008 at 11:56 PM. |
#6 (permalink) | |
Member # 71185
When mounting this type of link should it be attached under the axle or can it go in front? I realize that mounting in front will cause the axle to try to rotate and it will put more stress on the uppers but ground clearance would be much better. Since I would like this truck to still be a decent trail rig more ground clearance would help a lot. I've seen desert trucks where the upper links are joined into a wishbone setup, any downside to this? On an early bronco the frame width is pretty narrow and getting enough angle on the upper links to locate the axle may not be possible, this looks like it may be a solution. How do you calculate for a wishbone upper? Do you just use the four link program and set the upper link seperation at the axle at zero? Brewchief
#7 (permalink) | |||
Member # 5110
Edit: the front of the link is to the left in the pic. 3 points if anyone can figure out what the tab on the top is for I'm still tossing around 2 different names for it.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893 Last edited by Triaged; 03-23-2008 at 06:27 PM. |
