Project Sadomaschositic - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 05-04-2008, 10:08 AM   #1 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
(fn title was supposed to read "Project Sadomasochistic")
Or, how to beat yourself up and have an awesome time doing it..
Picked up my new bug for my class 11 build.
1969 sunroof bug. IRS rear, BJ front.
Unfortunately VW never brought a Link pin/IRS car into the states, so I am destined to race a BJ
Looks like the tranny was gone through not too long ago, I have to either pull it apart or have some one pull it apart to see if it has had any out of spec parts added.
A "Freeway Flyer" tranny would suck in the desert.
First thing is to pull the pan and sandblast. Cage comes next (dam rules that say HREW is not allowed ) and then the motor.. 11:1 should be a good comp ratio, I can't wait to pass some Jeep speed dudes
http://forum.ih8mud.com/attachment.p...1&d=1209919233
http://forum.ih8mud.com/attachment.p...1&d=1209919626
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 05-04-2008, 10:10 AM   #2 (permalink)
Member # 5286
BTW, anyone have any good deals on 29" BFG at's??
DEAR MADAM:
Old 05-04-2008, 10:22 AM   #3 (permalink)
DHONDAGOD's Avatar
Member # 34369
Pics no workey....
Chris
[COLOR="Magenta"][QUOTE=Earl_of_Burl]
Q: What is Hell?
A: A place that is without God.
Q: How do you find God to avoid Hell?
A: Through his son, Jesus Christ.
Q: What does this mean to me?
A: If you are living your life without accepting Jesus Christ as your personal savior, you are on the road to Hell.[/QUOTE][/COLOR]
DHONDAGOD is offline   Reply With Quote
Old 05-04-2008, 10:27 AM   #4 (permalink)
Lifted Cracker's Avatar
Member # 26147
Is this Mace?
RIP Jason
NorCal Offroad
Lifted Cracker is offline   Reply With Quote
Old 05-04-2008, 10:36 AM   #5 (permalink)
Member # 5286
Yes sir
I url'd the pics till I set up a photobucket account..
DEAR MADAM:
Old 05-05-2008, 03:55 PM   #6 (permalink)
Moderhater
Halogrinder's Avatar
Member # 16980
Interco has some blem iroks in 245-75-16 flavor
85 bucks each
i was gonna put some on some spare 16 inch tires for my ford, and use em for street/tough truck comps
Im your BMW huckleberry
https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car!
gun facts that will blow your mind:
http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf
Halogrinder is offline   Reply With Quote
Old 05-05-2008, 06:08 PM   #7 (permalink)
Member # 5286
245's are too big. 235's are about as big as you can go and keep the fenders..
Also, I can't run a 16" rim. 15 x 4 or 15 x 5 is it..
Stock class is actually "stock"
I don't even have to run a fuel cell. The stock gas tank is perfectly fine
Got most of the outside parts off. All I have left to do is pull the cab off the pan and sandblast the pan..
I still have not figured out how I want to paint this thing. For some reason I have a big temptation to paint each panel a different color... Make it festive
The pan is as good as I thought it was. Pretty pleased with the base rig
DEAR MADAM:
Old 05-05-2008, 07:21 PM   #8 (permalink)
Moderhater
Member # 16980
lemme tell you about my baja bug experiance. i bought it when i was 12. my dad traded my motorcycle for it. it was the basis of why i love 4 wheeling so much. he showed me his love for 4wheelin. i learned to wheel in that thing, and how to read terrain. i think thats why i can wheel well.
i had a 63 ragtop, that was converted to a baja. now bear with me, i got rid of this thing when i was 17, so it was a few years ago, things are a little cloudy in memory.
i put the body on a 69 pan to gain rear IRS. i kept breaking rear axle shafts with the stock rear suspension.i cut the front frame horn off of the 63 to have kingpin(linkpin or whatever you call it) for best of both worlds. i cut the factory front beams and put adjusters on them, extended shock mounts and control arms. still used the drums all the way around, cause i was poor, and the brakes were superb cause of the weight. i used beam strengtheners, that run from the beams to the front body mounts, as i jumped it regularly, and bent the front end coming down hard. lesson learned. front end had about 10 inches of travel. i cut the front clip off of the front end from the windshield forward. one peice glass front end that tilted forward. most eggselent when i rewired the car, cause i could sit on the tires and mess with the wiring the bad: the back of the dash was exposed to everything..... as in i could open the glovebox and watch the road..lol so i made a plastic cover and sealed it in. when it rained ( i drove it daily to skool) water came thru the vents and glovebox. out in the dirt it was dust city. the front end was so light you could pick up the front end by grabbing on the baja bars. it made life easy if you hit shit too hard, you normally just bounced off of it. it where i had to learn to use my turning brakes efficiantly since the front had so much understeer.
i used a big set of tierods and ends (cant remember what) and one of those quick steer setups for the steering block. worked great. front end was nimble like a go-cart and i was still able to steer it easily.
skat prodrag shifter, and i took two Ebrake handles, gutted them and turned them into cheap turning brakes
put a cheap little 4 point cage inside, put glass rear fenders on it, cranked the torsion bars like 4 splines and put some KYB's all the way around. the rear rode on the stops limiting it going up, but was cool cause i could jump the crap out of it and not worry about it..lol just annoying sounding. i had to put wheel studs instead of wheel bolts after ripping them out from landing hard, drifting, and doing burnouts (or attempting)
i used to jump it so hard it would pop the street tires on the front
if i remember correctly i ran 30x9.50's BFG AT's in the rear and whatever i could find for the front. took the stock engine, and put a 1635 set of jugs on it, a 2bbl pinto carb and dual port heads. heater box eliminators, and a set of headers w/ a stinger to annoy everyone.... put a skid sheild on it and solid trans/engine mounts. broke 3 transmissions nose peices off, and bent the shifter tubing, pulled the trans mount out of the body, and pulled the nose peice thru the back sheetmetal prolly made like 12 horsepower drove around well, but lacked in the HP department when trying hills and grades on the street. ran a oil cooler all the way to the front after toasting an engine. snorkled the intake under the back glass after a mud puddle incident with it. what a pain listening to the fucking carb suck all the time! wheeled with guys from highskool and kept up w/ their toyotas in the mud, trails and dirt. rocks is where they got me. dirt roads is where i dusted them gimmie a dirt road and it was over. its how i learned high speed dirt work w/ turning brakes. i learned my cutting teeth and making mistakes.
mistakes like: bugs roll like turtles i rolled it twice, both times i was able to flip it back over myself. one of the funnest cars of my life. miss that damn money pit money pit, as in i think i had about 3 grand in it. remember i was a broke ass kid.
Old 05-05-2008, 07:48 PM   #9 (permalink)
HeiserOilMotorsports
Po' riggity's Avatar
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
Awesome! I can't wait to see this build.. I've wanted a "baja" bug for a long time and I still do!.. I can't wait to see how this class 11 turns out!
HeiserOil Motorsports:
Crawlin' For Crohn's
Friends of San Bernardino National Forest (website not yet complete),
brought to you by Sbwinvps
Originally Posted by Alpine4x4 View Post
y'all know my flatbill hats make me the best desert racer out there!
Po' riggity is offline   Reply With Quote
Old 05-05-2008, 08:56 PM   #10 (permalink)
Member # 5286
This is not going to be a "baja" bug, that is entirely a different class, this is the stock bug class..
Something like this
DEAR MADAM:
Old 05-05-2008, 08:58 PM   #11 (permalink)
Member # 5286
hey Halo, you don't have any pics of how you did the turning brakes do you???
I am contemplating doing the exact same thing..
DEAR MADAM:
Old 05-05-2008, 11:10 PM   #12 (permalink)
Member # 912
Sweet, how can you still be married with all these projects? I don't think it will fare to well at the Hammers though.
sixty is offline   Reply With Quote
Old 05-06-2008, 05:27 AM   #13 (permalink)
Moderhater
Member # 16980
got another stock handle, cut the guts out of both of them, set them next to each other and put on cable on each one..... put a little spacer under them, so they could be grabbed instead of them laying on the tunnel. sorry, it was pre-digital picture time
Old 05-06-2008, 07:55 AM   #14 (permalink)
Member # 5286
Like hell it won't. There are a bunch more open whooped out roads in JV than rocks
Thanks Halo, I think I am going to take some barstock and do the same thing..
DEAR MADAM:
Old 05-06-2008, 08:41 AM   #15 (permalink)
Moderhater
Member # 16980
bar stock? just take 2 ebrake handles, they bolt in!
just make sure you ditch the ratchet parts
if i woulda done it again, i woulda bent them outward a little, so it was easier to grab when flyin down a road, but i still had no issues getting the rear to swing out left to right, left to right at a seconds notice. seriously, my buddies trucks had no fawking chance keeping up.
Old 05-06-2008, 11:04 AM   #16 (permalink)
Member # 5286
Sweet
DEAR MADAM:
Old 05-06-2008, 11:48 AM   #17 (permalink)
Member # 60
Start of thread may 2008. Last page of thread predictions?
I am guessing sometime around 2010 he will drop the motor in and fire it.
Twisted Customs Chassis-347/C-4/Dana 300/HP60's- Maxxis-Burnsville Off Road-Racefuel by Chem442
Mike Knorr is offline   Reply With Quote
Old 05-06-2008, 01:10 PM   #18 (permalink)
Member # 5286
You're a funny dude
2 years is a good estimate tho..
DEAR MADAM:
Old 05-09-2008, 07:39 AM   #19 (permalink)
Member # 1515
Yeah, I know the "baja" and class 11 bugs are totally different, but the vehicle itself is similar, and I love me some old bugs
Scott
Old 12-20-2008, 07:34 PM   #20 (permalink)
Member # 5286
Interior is painted, the front beam was cut n turned 9/16" rear arms boxed in, tranny is off to RC trans for some lovin, The cage is bent up and ready to be welded in, I picked up a POrsche 924 for some extra special "race parts", Seabass (12 volt guy) is sending me a switch panel, Got some Beard suspension seats and some RCI platinum seatbelts..
Oh yeah, and a 17" steering wheel because I can't run Power steering
Pics tomorrow afternoon...
DEAR MADAM:
Old 12-21-2008, 12:06 AM   #21 (permalink)
Gravel Maker's Avatar
Member # 51387
Send a message via Yahoo to Gravel Maker
So this is what you have been doing!
I always wanted one too! I grew up in Phoenix and everyone had one, I was a little more into the street scene though with a BB Z28 after blowing the 302 3 times......Had an uncle with a porshe powered VW thing baja'ed out, that was as close as I got back then.
We are going to have to share notes Jason, we are building a desert truck (7200) now, not quite a bug but you always find the most interesting parts and put things together in an interesting way! Post away....
Dan Fredrickson www.ruffstuffspecialties.com
......"The NEW Industry Standard"
Tech/Sales 916.600.1945
You can SAY anything, its what you DO that matters!
The Official Repair Station of KOH!
Gravel Maker is offline   Reply With Quote
Old 12-21-2008, 07:44 AM   #22 (permalink)
Member # 19705
Hundreds of miles of dirt roads in JV to run it on. Lucerne A & B courses just for starters.
Dust Junkies Racing
2009/2010/2012 Baja 1000 Class Champions
bob91yj is offline   Reply With Quote
Old 12-21-2008, 08:29 AM   #23 (permalink)
Member # 5286
RIGHT ON!!
What series of races are you going to be running?
Any thing I can do for you amigo
DEAR MADAM:
Old 12-21-2008, 09:58 AM   #24 (permalink)
Administrator
Lance's Avatar
Member # 1
Send a message via Yahoo to Lance
Cool.
Lance is offline   Reply With Quote
Old 12-22-2008, 07:30 PM   #25 (permalink)
Member # 5286
Porsche for parts
Anyone want the car after I am done with it???
DEAR MADAM:
