#76 (permalink) |
Member # 11961
That Lexus t-case is sexy! Mine is a Jeepspeed so I am limited to a jeep t-case by the rules. I use a late model 249J and run in full time 4wd and it works way better than the 4-5 231's i have broken. The car is very good in 4wd, way better than 2wd.
#77 (permalink) |
Member # 73963
the problem with the 80 series case is that it is its own mounting bolt pattern-and its heavy. not a lightweight jeep part
![]() the lexus tcase is full time 4WD. there is a part time kit but it deletes the center diff.
IFS build http://www.pirate4x4.com/forum/showt...ht=starfighter turbod the Lexus http://forum.ih8mud.com/80-series-te...rbo-build.html Tons and 42's on the Lexus http://forum.ih8mud.com/hardcore-cor...j80-build.html |
#78 (permalink) |
Member # 87095
the real bad news is that 4wd is not nessisary for the desert racing we do.......once someone builds a badass 6 cylinder trophytruck with some money behind it and a good driver, the class will be dominated......
#79 (permalink) |
Member # 114258
The sad thing is that class will be dominated by a class 10 car with a v6 if anyone ever decides to do it. Class 10 cars allready beat the 7200's, double the horsepower with some bigger components. Watch out!!
#80 (permalink) | |
Member # 113405
The guys that have used the 80 viscious coupler have found it doesn't like the huge variation in speed that happens in a race so it appears in concept they are great but just not really up to the job long term when there is speed involved but will handle trail and slow speed without a problem. (The case with part-time conversions appears to be very strong) What I'm building should be under 4000lbs with 600hp and 36's. |
#81 (permalink) | |
Member # 84132
www.jaggedx.com www.crdesigns.com AEI Motorsports www.campbellent.com www.geiserbros.com |
#82 (permalink) | |
Member # 26821
landrover lt230 is stronger and is used in buggy's here in Oz. They are open diff full time 4wd with selectable locker....very simple/strong and easy to use. can get 3.2,4.1 and 4.8 low range gear sets...1.1,1.4 and 1.6 high range.... |
#83 (permalink) | |
Member # 73963
#84 (permalink) | |
Member # 98865
![]() This truck looks great. Nice work!!! I have never gotten stuck in my truck, but there sure have been some times I would have felt better with 4wd. Like the silt bed after Laguna Salada. I remember you telling me to just stay away from it altogether. Those words were burned into my brain. I would have slept better the night before if I knew I had 4wd on my side.
WWW.TORCHMATE.COM We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings. Buy your consumables here! www.torchmatestore.com Torchmate Racing Homepage: www.torchmateracing.com Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/ |
#86 (permalink) |
Member # 161331
Team MacPhearson did a lot of testing back in the day of AWD T-cases in the Little Mac 7 trucks. They ended up running a Cyclone AWD T-case with high only and a 35/65 front to rear split on it. It had it's own pump and cooler to combat heat. They ran 4X full time and won several championships and Baja 1000's........ On a mostly stock T-case..........
#87 (permalink) |
Member # 26821
now i know its not the power or abuse that you guys run, but some hotted up rovers : Range Rovers and Defenders have been run in classes in Dakar running the fulltime Tcase....
thinking about it more, im sure if the money was put into it 4wd could dominate.....there were some 2wd bikes runing in proto class about 2 years ago in Paris Dakar.....they where faster than the normal bikes..... |
#88 (permalink) | |
Member # 30432
JOSH
SHOP AND APPARTMENT FOR SALE [url]http://pirate4x4.com/forum/showthread.php?t=589523[/url] |
#90 (permalink) | |
Member # 141250
Just an update on the new truck. We had some cooling issues At the last race. So we didn’t want to push the truck and lose a motor. To be safe we have put are replacement motor in and having the other check out. ![]() Here are some picture of the front and rear diff that summit machine/tsa motorsports Have been working on for the last 1.5 years. We will fill everyone in on how they hold up after we get some more test miles on them. ![]() ![]() ![]() ![]() Here is the 4.0 motor built by Lee at hesco ![]() Here are some more picture of the chassis. Yes we are just taken a different approaches with this build than All the other 7200 trucks. It may work or it may not, but that is the fun of trying something different. ![]() ![]() Here is a picture of the Transmission plate that Hesco design and summit machine went though and cut a lot of WT off and made it look cool ![]() The accessory panel is a bulkhead that the bell housing of the tranny bolts to. A small drive shaft will attach the motor to the transmission which is set back about 2' from the engine.
We would also like to thank the following TSA Motorsports sponsors for all there support in 2009: HPI Racing,Camburg, BFG Tires, Summit Machine, Hesco, Red Olive, Findlay Toyota and Defined Engineering. To Learn more about TSA Motorsports go to [URL="http://www.tsamotorsports.com"]www.tsamotorsports.com[/URL] |
#91 (permalink) |
Member # 141250
Here is a short video of some testing we still have some shock tuning to do. By the end of the day things were getting alot better. But we have a long ways to go before it race ready.
YouTube - TSA Motorsports 7262
#92 (permalink) |
Member # 141250
Here are some picture of the truck from the BOR race.
#93 (permalink) |
Member # 141250
Here is some testing video from testing out at Jean,NV getting ready for the SNORE BAP next month. We may even run a few BITD 4400 races this year just for fun with the new truck.
YouTube - TSA Motorsports testing at Jean, NV
#94 (permalink) |
Member # 141250
We would also like to thank the following TSA Motorsports sponsors for all there support in 2009: HPI Racing,Camburg, BFG Tires, Summit Machine, Hesco, Red Olive, Findlay Toyota and Defined Engineering. To Learn more about TSA Motorsports go to [URL="http://www.tsamotorsports.com"]www.tsamotorsports.com[/URL] Last edited by TSA Motorsports; 01-24-2011 at 09:22 PM. |
#95 (permalink) |
Member # 141250
Here is more video from last weeks testing
YouTube - TSA Motorsports Testing at Jean, NV before the Snore BAP 2011
