Member # 49159
catheter tech?/ stories
So the last time I rocked a catheter I was rushed putting it on and had the misfortune of having to get out and fix something at the start. Needless to say the reason I'm starting this thread is I had an issue. LOL the tube between hose and cath pulled out. So what tricks are out there to keep from pissin yourself?
My normal program is to use a small piece of duct tape holding the plastic tube, hose and catheter together then another strip of tape holding the hose to my thigh keeping some slack in the bend from wiener to thigh. More tape holding the end of the hose to the heal of my left leg. Incredibly uncompfortable but worked so far. (didnt get to do this last time )So how bout some stories. I heard one where driver and co-dawg were wizzing at a pit and new guy trying to save the day dove under the truck tying to figure out where the leak was coming from. He figured it out...lol
THINGS I NEED:92-93 Ford srw dana 60 knuckles. Everything balljoints out. W56-C toyota trans |
Member # 19705
One of our part time drivers had his fall off, peed all over himself before he realized what was happening!
Dust Junkies Racing 2009/2010/2012 Baja 1000 Class Champions |
Member # 87095
i remember the first time i raced KOH we had to use mine at one of the many breakdowns to FIX the "RIG".......SWEAR!
PETE SOHREN now on facebook......race truck adventures, YES, you drive....BAJARACINGADVENTURES.com |
Adnimistrator
Member # 2870
I never wear one in the race car. If I have to go I just let it go. Ocaisionaly i get some on my ankle, but most of it hits the ground...
FatCity Off-Road Racing |
Tech Editor
Member # 1656
Taping or tyeing the hose to your ankle is key. I also wear my dirt bike shorts under the fire suit to help hold everything in place.
HENDRIX MOTORSPORTS.COM Threaded Panel Tab Sale tinbenders.org camo is my hero, even if he is gay DirtChoppers.net |
Member # 28878
There is a new supplier of cath kits that makes both a better "hoodie" and better tube. I didn't catch what makes the "hoodie" so much better (something to do with the material quality that it doesn't slip) but the tubing is less flexible and can't get pinched off. Finally a cath you can wear with a d-cell.
![]() The only story with a kit I have is from KOH a few years ago. I never got in the car but had a great time convincing my wife it was her duty to get me warmed up to get the "hoodie" on. The other story without a kit is from this past weekend at the MORE race. I drove the second half in the C1. Turns out our starting driver decided before the race started to relieve himself just to get it over with. 200+ miles later I get in to a soggy, nasty ass seat.
Member # 6443
ALL OF THE CATHETERS I HAVE WORN HAVE BEEN JUST A WASTE OF MONEY!!! BUT THEN http://racecatheter.com/ CAME ALONG AND THEY TOOK THE TIME TO ACTUALLY MAKE A GOOD THING BETTER THE HOSE IS NOT SURGICAL TUBING IT A HARDER RUBBER HOSE SO NOT TO KINK WHICH LEADS TO BLOW OFFS, AND THE CODOM ACTUALLY HAS A BETTER GLUE IN IT TO HOLD IT ON THE FIRST TIME. TALK TO SOME OF THE PEOPLE WHO HAVE USED THEM THEY WILL TELL YOU HOW MUCH BETTER THEY ARE OR JUST GIVE THEM A CALL AND TRY IT THE ONLY THING THAT YOU HAVE TO LOSE IS A WET SEAT!!!
#8 (permalink) | |
Member # 50632
The clear vinyl tube and the way it attatches to the condom are the key. The tube does not pinch and stop flow and they stay on without the need to remove flesh while taking them off. The only bad thing is you can't use the tube to make a sling shot and kill dinner if you are broken in the desert ![]() wayne
AllTech Motorsports Fuel systems, shock work, custom fiberglass and more (951) 970-3399 www.alltechmotorsports.com wayne@alltechmotorsports.com new e-mail address! Congratulations to Alltech customers Erik Miller, 2012 KING of the Hammers Rick Mooneyham 2012 2nd place John Currie/Gerald Lee 1st place EMC Derek West for 4 pole positions in 2012 And all our customers who finished or took the green flag! |
Member # 41764
I used a race catheter for the first time at SS300. The thicker non-kink tubing is a stress reliever. Even with it taped to my thigh and my ankle once I've got my D-Cell on, I'm in the seat and strapped in with my 5 point you never know how the hose is doing. With the thicker tubing I didn't have to worry about it and I could concentrate on calling out hazards and turns, not trying to piss myself.
I used the generic versions before and I won't be doing it again.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5 Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between No one is ever gone if they are always remembered. JasonPayneMemorial Last edited by bggrnchvy; 05-24-2011 at 08:46 AM. |
Member # 11961
The tube is the tube and Jasons tube is the bomb.
As for catheters, I've been using these for the past year and they are by far the most comfortable thing going. At the Baja 1000 I wore it for 24 hours and had zero issues. I won't go back to the condom style, they just plain hurt. You don't even need a fluffer to install, a huge advantage on race morning. http://www.bioderm.us/index.php?opti...=52&Itemid=168 Edit, I don't use the bag, just put the tube on the end. There is a check valve on top too so the piss drains all the way out the tube quickly so it doesn't seep forever. Last edited by Bigburlynakedguy; 05-24-2011 at 09:17 AM. |
Member # 106808
KOH last year was my first time with the "racecatheter.com" unit. I was very happy with its performance. Pissed a couple times and no problems. I must have done something wrong when removing it because it took me a solid 30min to get it removed. I used the supplied removal stuff, but that sob was stuck. Any ideas to fix that?
KOH 2010 [COLOR="Silver"]Advance Adapters[/COLOR], [COLOR="Red"]Aurora [/COLOR], [COLOR="DeepSkyBlue"] Griffin [/COLOR],Baja Designs [COLOR="Blue"]Bilstein, CTM,[/COLOR] [COLOR="DarkOrange"]Currie[/COLOR], [COLOR="Silver"] D.J. Safety[/COLOR], Howe, J.E.Reel, [COLOR="Silver"]P.R.P Seats[/COLOR], [COLOR="Red"]Raceline Wheels[/COLOR], [COLOR="Orange"]Reid Racing[/COLOR], [COLOR="Plum"]Royal Purple[/COLOR],[COLOR="Silver"] Ruffstuff, [/COLOR] custom splice, Warn, 12volt guy |
#12 (permalink) |
Administrator
I have worn a lot of catherters but most are not up to the task of a LONG race like the 1000. The hoses are too thin, etc. Racecatherter.com's catherter is much thicker than the others and that shit is like super glue
which is AWESOME because if you have to get out to change a flat tire, etc and step on your pee hose, etc it don't get yanked off. My catherter made it all 1,050 miles of iron manning the Baja 1000 and my pants were still dry. I'll take the agony of removing it AFTER the race instead of losing it DURING the race.
#13 (permalink) |
Member # 25375
We used Jason's racecathater at the Silver State. I think Brad I lost count how many times we took a leak, best I've ever used. Had a few laughs. Those things stay stuck.. I pulled as hard as I dared on that thing it didn't budge.. READ and Follow the directions.
![]() KOH.. The tubing can be used as a siphon, right Dallas?
#14 (permalink) |
StinkyFab Racing
Member # 4946
I'm so glad the truck started again.
Dallas Ashley StinkyFab Racing (SFR) - Custom Fabrication Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more! Overall Winner, 2012 KOH EMC. Gettin it done in a stocker! Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008 |
#16 (permalink) |
Member # 49159
I've done the soggy seat thing twice. Once my wiz and once some one elses. Best part is we lost the trans in the pine forest(mexico) in a section that was inaccessable by chase vehicle. I got to marinate in my own piss and the tree sap I took a nap in for 8 hours...
LOL That was before I knew about cath kits. I got the bladder of a 5 year old everyday. beat my kidneys a bit and I gotta piss every 5 minutes. Are the race catheters only available on the website or does Mckenzies and kar teck have em too?
#17 (permalink) |
Member # 104653
^ x 100 for www.racecatheter.com It worked awesome and stayed put all day... although taking it off was interesting.
They sent me two for the price of one since I was thier first on-line order or something. Its a good thing I had that extra one since on race morning my co-driver dicked up (pun intended ) putting his on.
BroadSword Racing 4503U.S. Marine OIF/OEF Veteran Race Team Become a fan on Facebook Follow us on Twitter www.BroadSwordRacing.com 2013 Ultra4 Mod-Class Build by Dirt-Fab Racing |
#18 (permalink) | |
Member # 5639
Just Add Lightness I'd rather be simple-and-wrong than complicated-and-wrong. |
#20 (permalink) |
Member # 9868
WOW...thanks for all the props. Our race catheters were created because of all the campfire stories and frustrations.
Our kit solves the problems previously encountered with external catheters and here is why... -larger area of adhesive -no hard plastic adapter between hose and catheter (causes kink) -drain hose that will bend but resists kinking and will not collapse under seatblet. -kit comes with 3m medical tape to tape on inside of thigh and around ankle -kit comes with adhesive remover for catheter and tape We don't just sell a catheter, it is a complete kit. The only complaint we have had is some people have had some trouble getting the catheter off. Although adhesive bonds to different peoples skin types, here are a few suggestions. Make sure you are "cleaned" up. Hair caught in the catheter can be painful upon removal. We suggest rolling the catheter off, however most people are telling me that they just grab both sides and yank and get the job done quickly. This might work for most, but we don't suggest anything that is painful. Its like pulling off anything with adhesive, such as a band-aid, sometimes quicker is better. HOWEVER, we completely understand the "equipment" which you pulling it off of is very sensitive...that is the main reason for the adhesive remover. You might want to take some time during removal. Like Lance mentioned above, it might take a little longer to get it off at the end of the race, but that is better than coming off during the race. They have been tested for a year before coming on the market. |
#21 (permalink) |
I've never had an issue with pissing myself over all the years racing until this past RCQ. After lap 3 waiting for my turn to winch I said f it and let it fly. I was already muddy and wet from racing so it wasnt that bad but man it felt warm.
TEAM YUKON GEAR and AXLE #4413 Bulldog Winch, Raceline, Maxxis, FOA, Tom Woods, Everlast Welders, Ruffstuff Specialities, Cool Shirt, Stage 8, Baja Designs, PSC Steering, AJIK Overland Exchange, Reid Racing, Artec, Powertank, DynoMax, Hinchman Racewear, DJ Safety |
#22 (permalink) | |
Well Done Man!
![]() Buy Jason's stuff. I've tired different medical items, tape and adhesives, none worked as good.
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
#23 (permalink) |
Member # 84132
If catheters are a big concern for you, you may need to try a smaller size.
I've always run whatever the fawk PCI sells and have never had anything resembling an issue personally...one of those things I try to not put too much thought into. .02
www.jaggedx.com www.crdesigns.com AEI Motorsports www.campbellent.com www.geiserbros.com |
#24 (permalink) |
Bazinga!
Member # 10903
catheter tech... :shudder: I understand now why I never grew up to be a race driver.
John '91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's Build Pics & Build Thread happy..happy..happy.... |
#25 (permalink) | |
Member # 9868
http://www.mckenzies.com/ |
