Jeep Wrangler Reverse/Backup LED Bulbs! Several Model Options! Plug & Play Install - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Diode Dynamics
Old 04-13-2016, 09:08 AM   #1 (permalink)
P4x4 Vendors
Diode Dynamics's Avatar
Member # 451658
Arrow Jeep Wrangler Reverse/Backup LED Bulbs! Several Model Options! Plug & Play Install
Jeep Wrangler Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different model options for your Wrangler's reverse light or backup light bulb. We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Bulb Design
HP48: This bulb is non-polar, CK compatible, with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS to fit your Jeep Wrangler model year selection.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP11: Slightly higher brightness than OEM bulbs. (310 lumens)
XP80: Much brighter than OEM bulbs. These are bright! (510 lumens)
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction.
Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
/ (314) 205-3033
Lighting Experts
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 05-10-2016, 06:15 AM   #2 (permalink)
P4x4 Vendors
Member # 451658
Customer Submitted Comparison
Stock Incandescent on Driver side
LED on Passenger Side
Nick C.
/ (314) 205-3033
Lighting Experts
Old 01-05-2017, 10:50 AM   #3 (permalink)
P4x4 Vendors
Member # 451658
Questions? Chat with an expert on our site!
Diode Dynamics
/ (314) 205-3033
Lighting Experts
Old 01-10-2017, 06:47 PM   #4 (permalink)
P4x4 Vendors
Member # 451658
Contact@diodedynamics.com
/ (314) 205-3033
Lighting Experts
Old 01-11-2017, 04:21 PM   #5 (permalink)
P4x4 Vendors
Member # 451658
Diode Dynamics is on SnapChat!
Nick C.
/ (314) 205-3033
Lighting Experts
Old 01-12-2017, 11:54 AM   #6 (permalink)
P4x4 Vendors
Member # 451658
PM Responses sent!
Thanks,
Nick C.
/ (314) 205-3033
Lighting Experts
Old 01-20-2017, 08:16 AM   #7 (permalink)
P4x4 Vendors
Member # 451658
/ (314) 205-3033
Lighting Experts
Old 01-23-2017, 07:15 PM   #8 (permalink)
P4x4 Vendors
Member # 451658
Diode Dynamics
/ (314) 205-3033
Lighting Experts
Old 01-25-2017, 02:09 PM   #9 (permalink)
P4x4 Vendors
Member # 451658
PM Responses sent!
/ (314) 205-3033
Lighting Experts
Old 01-26-2017, 09:40 AM   #10 (permalink)
P4x4 Vendors
Member # 451658
Don't forget to send us a PM for the free-shipping code!!
(U.S. members only)
Thank you,
Nick C.
/ (314) 205-3033
Lighting Experts
Old 01-30-2017, 06:57 PM   #11 (permalink)
P4x4 Vendors
Member # 451658
Diode Dynamics: Authorized Dealer Locator Tool
Looking for professional installation? We've added several new authorized dealers to our locator map!
Nick C.
/ (314) 205-3033
Lighting Experts
Old 02-02-2017, 01:39 PM   #12 (permalink)
P4x4 Vendors
Member # 451658
If you've taken pictures of your car with Diode Dynamics products installed, please send them to: contact@diodedynamics.com
We enjoy seeing our customer's vehicles!
Thank you,
Nick C.
/ (314) 205-3033
Lighting Experts
Old 02-06-2017, 07:44 PM   #13 (permalink)
P4x4 Vendors
Member # 451658
PM responses sent!
Thank you,
Nick C.
/ (314) 205-3033
Lighting Experts
Old 02-14-2017, 05:12 PM   #14 (permalink)
P4x4 Vendors
Member # 451658
(314) 205-3033
/ (314) 205-3033
Lighting Experts
Old 02-17-2017, 09:10 AM   #15 (permalink)
P4x4 Vendors
Member # 451658
(U.S. members only)
Thank you,
Nick C.
/ (314) 205-3033
Lighting Experts
Old 02-22-2017, 04:05 PM   #16 (permalink)
P4x4 Vendors
Member # 451658
/ (314) 205-3033
Lighting Experts
Old 02-23-2017, 01:27 PM   #17 (permalink)
P4x4 Vendors
Member # 451658
Diode Dynamics
/ (314) 205-3033
Lighting Experts
Old 02-24-2017, 08:24 AM   #18 (permalink)
P4x4 Vendors
Member # 451658
PM Responses sent!
/ (314) 205-3033
Lighting Experts
Old 02-27-2017, 05:42 PM   #19 (permalink)
P4x4 Vendors
Member # 451658
Diode Dynamics YouTube Channel
Subscribe to see new content!
/ (314) 205-3033
Lighting Experts
Old 02-28-2017, 04:25 PM   #20 (permalink)
P4x4 Vendors
Member # 451658
PM responses sent!
/ (314) 205-3033
Lighting Experts
Old 03-01-2017, 07:10 AM   #21 (permalink)
P4x4 Vendors
Member # 451658
The output from one 6" Stage Series Wide pattern light bar is perfect for auxiliary reverse lighting!
Resz Fabrication
Nick C.
/ (314) 205-3033
Lighting Experts
Old 03-02-2017, 11:17 AM   #22 (permalink)
P4x4 Vendors
Member # 451658
Like us on Facebook!
Diode Dynamics Timeline
Nick C.
/ (314) 205-3033
Lighting Experts
Old 03-03-2017, 07:30 AM   #23 (permalink)
P4x4 Vendors
Member # 451658
Questions about a product? Need information?
Give us a calll!
(314) 205-3033
/ (314) 205-3033
Lighting Experts
Old 03-06-2017, 02:34 PM   #24 (permalink)
P4x4 Vendors
Member # 451658
PM responses sent!
Thanks,
Nick C.
/ (314) 205-3033
Lighting Experts
Old 03-07-2017, 01:34 PM   #25 (permalink)
P4x4 Vendors
Member # 451658
(314) 205-3033
/ (314) 205-3033
Lighting Experts
