Opinions on Dakota Digital ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-15-2012, 06:56 PM   #1 (permalink)
Member # 214091
Hi, I am about to order a Universal Speedometer Signal Interface to fix a problem I have.
I swaped in a dodge Durango engine, transmission, and T-Case into my ZJ.
since Ive done this, well I have no O/D since on the ZJ the speed sensor is on the T-case, and on the Durango its on the rear diff. So now I've been told I could use a Dakota Digital Universal Speedometer Signal Interface to use one of my ABS signals and convert it into the correct signal for the speedometer therefor fixing my problem (already unplugged my ABS anyways and not using it) . So I think this is a good plan...
Anyone here can confirm to me if this is even possible?
Cheers to all
zjrick812 is offline   Reply With Quote
Old 03-18-2012, 05:39 PM   #2 (permalink)
talonxracer's Avatar
Member # 194195
It should work fine, I have used Dakota convertors on several vehicles, just not your combination, but it still should work.
I took an oath to defend the Constitution, not the Govt !!!
talonxracer is offline   Reply With Quote
Old 03-19-2012, 05:30 PM   #3 (permalink)
Member # 214091
aright great thanks !!! I was waiting on a positive reply befor ordering . . thanks alot , cant wait to try it out .
Old 03-25-2012, 12:25 PM   #4 (permalink)
Member # 21815
I've used DD for both speedo and speed sensor inputs in the past, they work great!
WWDD?
N6YBH
"If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford
Use Goodsearch and support the Rubicon Trail Foundation.
resqme is offline   Reply With Quote
Old 06-27-2012, 06:21 PM   #5 (permalink)
Member # 178297
Cheers to all
Did the Dakota work for you? I own multiple jeeps but I am trying to help a buddy whose (get ready to flame) Subaru speedometer does not work, I have narrowed it down to the Trans Speedo Gears are stripped, it has a VSS sensor that is spun by the gears to 4000 pulses per mile via Sine Wave (from what I read), I took the VSS wires and hooked them to the ABS sensor wires and got the speed to work, but it shows 80mph when I am doing 20mph...... so I am hoping the Dakota system will work.... Any thoughts ?
Thanks,
Bryan
bryweb is offline   Reply With Quote
