120V Relays?
I've done enough with 12V relays to feel comfortable with it. But I've got a project where I want to switch a bunch of 120V stuff - basically a control panel for A/V and computer stuff.
Seems like it would be fairly simple - 120V 15A to 20A stuff. But my searches are turning up a pretty wide range of prices - anywhere from $10 for a relay up to $70 and then some going to $100s... I must be missing something here. Simple solution would be to wire up light switches, but I want a small control panel up front with the relays tucked back into things. Besides, light switches would be the ghetto way out...
GET INVOLVED - Join the Blue Ribbon Coalition SIGN THE PETITION - SAVETHEHAMMERS - #85 '93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
Member # 132020
I've used and worked on equipment with inexpensive to high dollar relays. Manual and PLC controlled. You can use the relatively cheap ones for what you stated. The plug-in ones probably be your best bet. If it fails just pull & replace. Like the old fashion tube type equipment. Something like these from McMaster-Carr.
http://www.mcmaster.com/#general-purpose-relays/=gt09rs |
hate keeps me warm
Member # 151139
There ain't no good in an evil-hearted woman And I ain't cut out to be no Jesse James And you don't go writing hot checks down in Mississippi And there ain't no good chain gang |
Thanks for the input - and the source, Grumpy.
Looks like these will do the trick - for under $5 a piece. Not sure what I was making so difficult that I was turning up the bazillion dollar versions before.
