2 gauges off one sending unit, is it possible? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-27-2012, 10:38 PM   #1 (permalink)
Member # 50177
Actually it is one gauge and an ecu. Long story is I am swapping a tundra motor into an FJ40, the tundra wiring runs the gauge signals through the ecu so I assume it wants to see them. There is an output from the ecu to the tundra instrument pack but I suspect it is a computer mumbo jumbo signal rather than a simple sender resistance signal. I want to run the factory FJ40 gauge cluster and I am wondering if it is going to screw with anything if I try to run two things off one sender. I know senders work off resistance to ground and it seems like it would be ok but I am doubting myself.
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
www.MayhemMetalWorks.com
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
http://www.pirate4x4.com/forum/showt...e33fc&t=488938
am4x4 is online now   Reply With Quote
Old 03-29-2012, 08:58 AM   #2 (permalink)
TR
TR's Avatar
Member # 2877
Send a message via ICQ to TR Send a message via AIM to TR Send a message via Yahoo to TR
than Likely the tundra temp sender is a 3 wire type and would not work with your cluster. Does the ecu have a seperate temp pin to the cluster? You will probably be better off adding the fj40 sender to the engine some where.
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote
Old 03-31-2012, 11:55 AM   #3 (permalink)
Member # 62360
Without knowing more about the ECU and sensor, I'm going to say that you probably can't do what you want to do. In fact trying to may even damage the ECU.
egdinger is offline   Reply With Quote
