larger wire weather pack or disconnect - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-29-2012, 07:41 AM   #1 (permalink)
aka WIZZO
phi564's Avatar
Member # 31550
for the dash in my buggy i made it so the whole dash is removable to work on. so all the wires between it and the main harness are in weather packs. i have a 10 or 12 gauge wire that comes from the main kill switch up through a weather pack and then onto a fuse block. i'm having problems with the connectors in the weather pack. either it is arcing or getting hot at the pins.
so i'm wondering if there is such a thing as a quick disconnect like a weather pack, it must be insulated, that i can use that will handle the higher voltage draw. the main thing i would like is for it to be quickly detachable.
any ideas?
dash pic
weather packs and pins i'm using
buggy, LQ4 6.0L, th350, atlas 3.0, 60&14, 5.13's, spools, psc steering, bilstein coilovers & bumps, etc.
thanks to some good folks that have helped me out along the way:
phi564 is offline   Reply With Quote Quick reply to this message
Old 03-29-2012, 08:40 AM   #2 (permalink)
Member # 50177
I use these, they have pins that are rated for up to 10ga. The plug body is not much if any bigger than a weatherpack and you can even use the same crimpers. Make sure you get the wire retainer, it is a sepperate piece, not hinged off the plug body like a weatherpack. also look at this place for weatherpacks if you need any more, odds are you are paying too much if you are getting them anywhere else.
http://www.delcity.net/store/Metripa...ies/p_8591.a_1
Some crappy pics I took, the pins on the right are the largest weatherpack and the left are the 10ga metripacks.
top is metripack, bottom is weatherpack
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
am4x4 is offline   Reply With Quote Quick reply to this message
Old 03-29-2012, 09:06 AM   #3 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
Anderson connector
pick your size
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 03-29-2012, 11:51 AM   #4 (permalink)
aka WIZZO
phi564's Avatar
Member # 31550
thanks doc! those look like the way to go, got some on order!
Old 03-29-2012, 12:32 PM   #5 (permalink)
BigBlue&Goldie's Avatar
Member # 113019
I just picked up a bunch of those on ebay for a fair price from a guy that sells them as kits (2 plugs, 4 pins).
BigBlue&Goldie is offline   Reply With Quote Quick reply to this message
Old 03-29-2012, 05:45 PM   #6 (permalink)
usmcdoc14's Avatar
Member # 13344
has usualy where I get them as well. I also have them at the front and rear bumper for easy jumping people and converted a set of jumper cables with one of their pull handles.
It makes jumping someone easy as you dont have to turn around or pop the hood.
Old 03-29-2012, 06:26 PM   #7 (permalink)
Member # 113019
What gauge cable did run to the back for jumping? Is there any kind of circuit protection?
Old 03-29-2012, 06:44 PM   #8 (permalink)
jsawduste's Avatar
Member # 77571
Weather Pack is rated for a max of 20 amps. FYI
Sent with smoke signal.
jsawduste is offline   Reply With Quote Quick reply to this message
Old 03-29-2012, 07:03 PM   #9 (permalink)
usmcdoc14's Avatar
Member # 13344
8ga.
jumper has a polarity box thigie on it.
entire vehicle is fused at the batteries so I am not too worried.
Old 04-01-2012, 06:12 AM   #10 (permalink)
Member # 130300
http://www.ebay.com/itm/Anderson-Pow...item27bcca92ca
They lock together to make any size plug you would like.
Mikes79bronco is offline   Reply With Quote Quick reply to this message
