Member # 57170
XRC8/ Mile Marker winch part source? Plug in for remote
Need a source for the socket that the remote plugs into on the control box.
I ditched the control box and mounted the solenoid in the bumper. I should have protected the switch better. The wires broke off the back of the plug. It looks like one of them broke off flush, so I cant solder them back on. The 6 o'clock position in the pic. There are 4 wires. Did two of them go two one position? Winch is a Smittybuilt XRC8, but the wire protector on the back of the socket said Mile Marker. 4 wires on the back, 3 holes on the front. There should be 4 wires soldered to the back that lead to the solenoid. ![]() ![]() Thanks Vince Last edited by SEREvince; 03-31-2012 at 05:52 PM. |
Member # 101802
That's a standard 3 pin XLR microphone connector. It's available at almost any electronics store....I think Radio Shack has them too. Unless you seal the entire thing in silicone there isn't really any way to weather-proof them. Yes, the terminal in the top of the photo can have a wire attached to it, but usually they're not used. I would guess that that top terminal would be a ground connection.
Member # 57170
So there are 4 wires that go from the remote to the solenoid.
I'm guessing. Power Forward Reverse Ground There are only 3 connections on the the back of the plug? Thought the bottom one broke off, but maybe there was never one there. Thoughts? |
#6 (permalink) | |
Member # 57170
Member # 101802
When I used to do commercial audio, I soldered hundreds of those damn things...The top connector looks like a round eye lug, while the rest are cups. Wrap the wire around the eye lug and solder normally. I suggest a healthy dose of silicone over everything when you're done.
My guess would be that the ground was up on the round eye lug, and the power was on the opposite, with the forward/reverse on the side lugs. But that's just how I would wire it....what would I know? You might have to put power to the winch and see what happens when you use a test light to check each line. When you find power, try jumping it to the other lines and see which way the winch goes. Then pull the plug on the controller apart, and using a multi-meter figure out which circuits are connected to what when you push the forward/reverse switches. |
Member # 57170
Picked up a female chasis plug at Radio Shack for $8.
Will plug in the remote then trial and error the wires on the back of the plug. Waterproof will be via silicone and heat shrink. Thanks If any one wants to pull their cover and take a pic of the wires on the back of the plug that would be awesome. Sent from my DROIDX using Tapatalk |
