Great multi function relay - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2012, 12:16 PM   #1 (permalink)
angryblack's Avatar
Member # 142394
Not sure if anybody has used these in a 12 volt app..But they re pretty common in the industrial field.. During my build i found one that is set for 12 volt operation..
I use it as a cool down switch to continue to run my fans after I shut the truck off.I plan on getting one to allow my tow pig to run after i get out to let the turbo oil not to cook
http://www.mcmaster.com/#6964K15
Ive seen them in grainger but not in the 12 volt form..Ive been runing mine for a few months and it always works..
On-Delay (Delay-On-Make)
Off-Delay (Power-Off Delay)
Interval
Switch-On Initiated Interval
(Single-Shot)
Switch-Off Initiated Interval
(Delay-On-Break)
Repeat Cycle
are all settings you can run with it.
Here is a pic on a small plate i installed in my truck.You can get an idea how large the relay is.The spdt relays control my fans,rocklights, and whatnot.I use a push button to start the timer in the relay
I will have to search around for the instructions and scan them.
Unfortunately there is no end to human stupidity -- making things foolproof only creates more ingenious fools
angryblack is online now   Reply With Quote
