a
Member # 68787
Weeding a renix 4.0 wiring harness
I put a 4.0 out of a 89 jeep cherokee in my yj and was wondering if there is some were I can send the harness to get it set up for my yj. I cant seem to find a plug and play harness for the renix engine.
Member # 6170
You won't, simply because almost everyone uses a 4.0HO.
What do you need done to the harness? Once you eliminate all the other none engine crap from the engine harness its really not that complex. I swapped a renix into my cj5 and I eliminated 2/3 of the harness it came with as it wasn't needed (headlights, wipers, running lights). Didn't latter YJs come with 4.0HO motors? Seems like that would have been a much simpler swap for you. Kevo |
#3 (permalink) | |
Member # 207169
http://www.hesco.us/ |
#5 (permalink) | |
a
Member # 68787
Member # 197194
I'm actually working on this right now for my Jeepspeed. I have all of the "demolition" complete on the existing harness it is now time to start filling in the holes and making some changes to better suit my needs. The good thing is, the injection system on these engines is stupid simple.
I found this manual that makes it 1000000000x's easier also. http://jeepgarage.free.fr/OWN/89JeepFI.pdf Next week i'll see if i can put together some more details for you. |
#9 (permalink) | |
Member # 86724
Unplug the ECM under the dash, follow everythig from the big connector and that's what you need to keep. CPS TPS Cam sensor MAP Injectors ASD relay Fuel Pump Relay IAC CTS (the one on the side of the block, one in the rad is just fan switch) Knock sensor (not critical) IAT that's about all you need for a Renix to run.
ko derf |
