what size breaker for camper - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-24-2012, 11:56 AM   #1 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
im fixing up a old 1967 24foot camper. has 120v, anyways one of the breakers is screwy. the bedroom lights dont work sometimes unless you go and wiggle it. so i figure im just gonna replace them all. this is the breaker i need
http://www.homedepot.com/Electrical-...&storeId=10051
BUT i see no amps anywhere on the breakers or anywhere in the breaker panel , looks like they are on the front of the new breaker just not these old crusty turds. would i be safe to just buy 20 amps for all 4 slots?
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 04-24-2012, 12:11 PM   #2 (permalink)
bigun's Avatar
Member # 29037
Can you tell what size the wire is/
“I will not be wronged, I will not be insulted and I will not be laid a hand on. John Wayne “The Shootist.”
bigun is online now   Reply With Quote
Old 04-24-2012, 12:16 PM   #3 (permalink)
Member # 157046
For homes, #14 wire, in conjunction with 15 amp breakers is the standard minimum size.
I seriously doubt that a 60's camper used #12 wire, which is the minimum you can use with a 20 amp breaker. 15 amp would be a safer bet.
When you pull the breakers, look for burntness on the buss bars where the breakers clip on. It would be caused by arcing and heating from the poor contact. If the bus bar has eroded too much from arcing, the new breakers may not clip on tight enough to make a good connection.
Oh, and that price seems seriously cheap.
xmptsunami is offline   Reply With Quote
Old 04-24-2012, 12:34 PM   #4 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
the wire says on the side of it "12/2 with ground type nm"
i checked those prongs on all 4 of them and they all look like new. this camper is insanely clean for how old it is. seems like someone bought it and never used it just let it sit and rot.
it seems like its the actual breaker itself if you trip and reset the breaker then like push the switch a hair up and down thats when the lights flicker.
im glad its cheap, i went to true value here in town and they wanted 12.99 for one
Old 04-25-2012, 07:51 PM   #5 (permalink)
Member # 104517
#12 is rated for 20A in houses, so I'd call it good for an RV too.
Honestly, in an RV I'd go a little crazy and put in a commercial series panel with bolt-on breakers. But you should be just fine for a lot of years just tossing those new breakers into your panel.
R.I.P. Jason Payne
chevy_man is online now   Reply With Quote
Old 04-25-2012, 09:23 PM   #6 (permalink)
Member # 101802
Take out another breaker that doesn't have the same problem, then compare the slot where the breaker stabs into the main power buss in the panel with the breaker slot that you currenlty are having problems with. If the hole looks any different, ie edges chewed up, different proportioned, etc; then this is most likely your problem. It looks like a standard Federal Stab-Lok breaker.
Then again....for the cost of the breaker, it wouldn't hurt to just go out and pick one up. If anything, you can put it in a drawer in the camper and keep it just in case one bites the dust while you're out in the middle of no-where.
yyc_ranger_4x4 is offline   Reply With Quote
