Member # 8937
GM/Delphi Alternator Wiring
I'm wiring up a second alternator on a buggy and I'm using an alternator from an '02 Grand Prix. I know that some of the late model GM stuff requires a resistor on the excite wire. I don't really know why, but I've heard that you'll damage the alternator without the resistor. Anyone have info on this?
Jesse Haines Fabrication #199/4499 - Maxxis, PSC, Superior Axle and Gear, Trail Gear, Branik Machine Shop, Valley Transmission, High Angle Driveline, Warn, Sway-a-way. |
#2 (permalink) | |
Member # 77779
Read this link about converting an old Ford tractor, it actually explains the light and why it is a good idea. http://www.myfordtractors.com/delco.shtml
Retired Driver #4447 Bench racing with a keyboard |
Member # 8937
You used an LED or a standard bulb?
I aim to misbehave
Member # 180649
I hate to answer for the man but as low as a draw as an LED has I'd think it would almost have to be a regular bulb.
Want to sell your original Willys/CJ5? Living in the United States now is like being a Tampon. We're in a great place, just at a bad time. |
Low Range Drifter
Member # 7903
In that era, I think it'd be the cs130 alternator, not the older si10. The plugs are a bit different between the two.
http://www.hotrodlane.cc/newhtml/smallalt.html If you use the warning light, it should be a bulb to make the resistance right. We had found a small light at the local parts store that wasn't any bigger than an led warning light.
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig Thanks to Drivetrain Specialists and PAC Racing Springs for your support |
one handed mechanic
Member # 119289
i just did a similar setup; albeit on a 1939 ford 9n tractor 12v conversion, but i used a 194 bulb and soldered the bulb holder right in line w/the wiring for the alternator. early '90s dodge trucks used 194s as the front side marker bulb
Looking for a REASONABLY priced 12v cummins......... |
Member # 104517
194 bulbs are used in everything, everywhere.
But, I'd do a small resistor in parallel with an LED just so it won't ever burn out and has resistance. Also, there is a HUGE tech article on here. http://www.pirate4x4.com/tech/billavista/Wiring/Part2/
R.I.P. Jason Payne Last edited by chevy_man; 05-05-2012 at 07:14 AM. |
#10 (permalink) | |
Member # 117692
#11 (permalink) | |
Member # 176681
