snow!
Member # 142927
you'll need a whole engine wiring harness, assuming you are wiring savvy you can find a wrecked vehicle that originally had the 5.0 in it and pull the wiring out of the front and seperate what you need and dont need,such as the efi wiring .
Member # 141909
Ok thanks reason i asked was guy i work with said someone he knows goes it in rails and only used 3 or 5 wires and i was also wondering about the o2 sensor
hillbilly
hillbilly |
Member # 83837
I just did a swap in my EB and there really isn't a whole lot to hook up. Beyond the sensors that plug into the motor there is a few 12v wires, a 12v rank wire and a few grounds. Beyond that there is nothing - I hooked 3 power wires up, two grounds and that was it.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers Bronco Build Thread |
#7 (permalink) | |
I make websites!
You can see my old mess here, and I`ll have to get some new pics of how it's setup now, all nice and clean ![]() I actually purchased all new electronics minus injectors and had IHO Jeff re-do the entire harness, mounts, and EVERYTHING on the engine. It's AMAZING how much better it runs
#8 (permalink) | |
Member # 210335
>only used 3 or 5 wires and i was also wondering about the o2 sensor If you keep the TFI setup, you can buy generic bungs from Summit and use the replacement Bosch, it should be a simple non-heated 1 wire type (ECC-IV) vs. 4 wire OBDII. Just keep the connectors clean of grease and such as it breathes through the wiring harness. Personally, I would go with the blue box duraspark and convert it to carb, but, that is me. Some people like the EFI alot. |
Member # 83837
Here is a thread on my EFI swap - I had everything hooked up correctly on my first try, I didn't realize they previous owner used a switch to turn on the fuel pump, as the wiring was no longer hooked up to the relay.
http://classicbroncos.com/forums/sho...d.php?t=198768
