Member # 132811
12volt circuits and tricks.
I have always need a quick circuit diagram when wiring since I don't use them day in and day out.
Use a single light buld for running and tail light. Two diodes and a resister 1watt ![]() Flashing circuits ![]() Diode information ![]() Resistor calculator http://www.the12volt.com/resistors/resistors.asp
1979 Bronco 390 swap c6 in process. |
Member # 157046
Ummmm, before this thread takes off, shouldn't some old threads relevant to electrical be moved here,
Like this one: /forum/general-4x4-discussion/858441-post-your-wiring-tricks.html I was expecting this to happen sooner, but I know everyone's busy... |
#3 (permalink) | |
Member # 17870
So will this work on LED tail lights???? ![]() I want to do running light and brake light with these...12 Volt LED Flexible Light Strips http://www.superbrightleds.com/cgi-b...-flexible.html
Arguing with a inspector is like wrestling with a pig in the mud. After a while you realize the PIG is enjoying himself! Last edited by pepe; 05-17-2012 at 08:16 PM. |
