head light switch makes cluster go crazy 90 yj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-10-2012, 01:44 PM   #1 (permalink)
Member # 74368
1990 yj
My gauges go crazy when I turn on my head lights. Both my head light and dimmer switches have been taken apart and cleaned repacked with D grease.
I have been able to track it down to the middle contact in my head light switch that feed the dimmer switch. In the Manuel it labels as 72 18BL/RD. It goes to the dimmer switch as 90 18/pk/or and then turns into 52 180or/bk. I have traced it to the Gauge package circuit board connector. And cut it. The gauges still go crazy when I turn the head light on.
I then was wondering if power is back feeding from the dome circuit. I pulled the fuse. It reduces the amount of action on the gauges. But still screws them up.
I was going to try cutting the common ground 99 18BK? Wondering if power is back feeding in.
I have a feeling the issue has something to do with the dome circut. And my wipers dont work any more?
HAS ANYONE HAD A SIMMILAR PROBLEM? ANY SUGESTIONS?
Kole
1990 yj RENAGADE
5.7 TBI, SM465 NP241C wJB SYE
HP Dana60 front D60 Rear w5.38 locked and loaded
39.5 IROKS on 17 bling bling
project_mud is offline   Reply With Quote
Old 05-11-2012, 10:23 PM   #2 (permalink)
89breaker's Avatar
Member # 64213
Define crazy.....in detail.
89breaker is offline   Reply With Quote
Old 05-23-2012, 10:03 AM   #3 (permalink)
Member # 74368
when I turn on my head light it makes my cluster jump all over.
I have tried to cut the power to the cluster and it is still makeing the gauges have faulse reading.
I have to find a back feed of power. I think I have a ground that is back feeding power througt the cluster. It gets energized with the head light switch. There is a blue wire #72 I think that goes from hl switch to Dimmer switch. I have cut it and the spike still happens. I think I am going ot try to put a diod on the ground and see what happens.
I could do with knowing how to test the switchs and relays to trace the source of the problem.
Kole
1990 yj RENAGADE
Old 05-23-2012, 10:15 AM   #4 (permalink)
vayacondios
beefdawg's Avatar
Member # 87698
This is usually cause by a bad ground. I had one once where the filament in the taillight bulb broke and was laying across the T/S filament and when I turned on the lights the indicator would come on. if the dash had a poor ground something like this would feed through the gauges. Try disconnecting or removing bulbs one at a time.
Hope this helps
80 cjunk7, with stuff--SOLD
new build... 90 yjunk, longer, wider, more stuff,
fasten your seat belt, it makes it harder for the aliens to suck you out of your rig
NRA LIFE MEMBER
beefdawg is offline   Reply With Quote
Old 05-23-2012, 07:57 PM   #5 (permalink)
89breaker's Avatar
Member # 64213
Buy a chilton's manual and verify all wires and connections are in good shape before anything.
Then get a voltmeter and start testing.
